My 3rd stupid question this week
aeromech
aeromech is offline
PostPosted: Tue Oct 19, 2010 12:55 pm    Post subject: My 3rd stupid question this week Reply with quote
I told you guys it wouldn't take me long to come up with another stupid question so here goes...
Type 1 engine, full flowed and using an external filter. Can the original oil strainer (screen) be eliminated? Would the oil pick-up tube still function properly?
From the gallery
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Oct 19, 2010 12:57 pm    Post subject: Reply with quote
Keep it in there.
bsairhead
bsairhead is offline
PostPosted: Tue Oct 19, 2010 12:58 pm    Post subject: Reply with quote
You can get rid of it but it does no harm in place.
babysnakes
babysnakes is offline
PostPosted: Tue Oct 19, 2010 1:01 pm    Post subject: Reply with quote
My 1600 is full flowed with external oil filter and I'm keeping the strainer.
aeromech
aeromech is offline
Randy in Maine wrote:
Keep it in there.
Any particular reason?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VDubTech
VDubTech is offline
PostPosted: Tue Oct 19, 2010 1:53 pm    Post subject: Reply with quote
Keep it in there.
I can't in 1000 years imagine why you would want LESS protection in filtering the oil. Why would you want to remove the screen?
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
aeromech
aeromech is offline
PostPosted: Tue Oct 19, 2010 2:09 pm    Post subject: Reply with quote
VDubTech wrote:
Keep it in there.
It seems redundant. What's the screen going to catch that the filter misses?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VDubTech
VDubTech is offline
PostPosted: Tue Oct 19, 2010 2:11 pm    Post subject: Reply with quote
aeromech wrote:
VDubTech wrote:
Keep it in there.
You never know. It's also redundant in the T4 which came from the factory with a screen and a filter, and the screen still catches stuff and should be cleaned with every oil change. With oil filtration, I'll take as much redundancy as I can get.
aeromech
aeromech is offline
PostPosted: Tue Oct 19, 2010 2:12 pm    Post subject: Reply with quote
VDubTech wrote:
aeromech wrote:
VDubTech wrote:
Keep it in there.
That's a good point
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
El_Güero
El_Güero is offline
PostPosted: Tue Oct 19, 2010 4:51 pm    Post subject: Reply with quote
aeromech wrote:
VDubTech wrote:
Keep it in there.
Now your onto your fourth "stupid question".... are you trying to set a record here???
Desertbusman
Desertbusman is offline
PostPosted: Tue Oct 19, 2010 5:12 pm    Post subject: Reply with quote
You're on a roll Gary Razz Laughing
If nuts, bolts, bearings, or anything else falls to the bottom of the case it will prevent them from going thru the pump. And if you don't have it you'll probably never pull the drain plate to inspect for any particles, sludge or whatever. Also the sump plate studs then might be too long and the acorn nuts bottom out instead of sealing.
71 Superbug
71 Westy
aeromech
aeromech is offline
PostPosted: Tue Oct 19, 2010 5:33 pm    Post subject: Reply with quote
Much better points and all well taken.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
78Kombi
78Kombi is offline
PostPosted: Tue Oct 19, 2010 5:38 pm    Post subject: Reply with quote
aeromech I understand where yer coming from, if anything is so big that a screen that size needs to catch it, well yer fukked anyway..
78 hightop 2.0 FI
Wildthings wrote:
no engine that I know of will run off of hype.
Wildthings
Wildthings is offline
PostPosted: Tue Oct 19, 2010 7:08 pm    Post subject: Reply with quote
Even I would leave the screen in place, who knows what lurks in the depths on your engine. Pulled one engine I had previously assembled apart to find a fir code in the sump thanks to some squirrel looking for a place to store his winter feast. I have certainly found a bunch of other weird crap hiding in pans and sumps over the years.
I have heard of people leaving the screens off to increase oil flow, but I have never heard of anyone actually having a starvation problem with them in place.
I would leave it there and then just not clean it more than once every 50K or so after the initial break in period.
atom
atom is offline
PostPosted: Tue Oct 19, 2010 7:41 pm    Post subject: Reply with quote
Just want to reiterate the point made here, with some pictures of modern oil pick-up tubes. Seems like a good plan to keep the screen with filter, since that engineering is still used. I clean these when replacing oil pans, so with a filter, they don't need regular cleaning, but also not forgotten.
VDubTech wrote:
aeromech wrote:
VDubTech wrote:
Keep it in there.
Desertbusman
PostPosted: Tue Oct 19, 2010 8:46 pm    Post subject: Reply with quote
Next question? Laughing Laughing Laughing
71 Superbug
71 Westy
Hoody
Hoody is offline
PostPosted: Tue Oct 19, 2010 10:00 pm    Post subject: Reply with quote
The best reason to keep it? Old German engineers decided it should be their.
Hoody
Hoody is offline
PostPosted: Tue Oct 19, 2010 10:05 pm    Post subject: Reply with quote
Just put a coffee filter in there and you will be good Laughing
Wildthings
PostPosted: Tue Oct 19, 2010 10:06 pm    Post subject: Reply with quote
Old German engineers also didn't bother to use a filter on an engine sold well into the 1970's. Inexcusable oversight if you ask me.
BusterBrown
BusterBrown is offline
PostPosted: Tue Oct 19, 2010 10:08 pm    Post subject: Reply with quote
aeromech;
You only asked what many of us have wondered about. I changed my oil, filter, and cleaned the sump screen just this past weekend, and wondered that very thing.
I too anticipate your next silly question. And it's OK for you to ask them, 'cause you're not a noobie!
1978 Sage Green Westfalia (Happy Trails, SOLD)
1977 Transporter
Life is short. Can I have some of yours?
