vdubeetle Samba Member
Posted: Fri Oct 22, 2010 4:00 pm Post subject: Pulley |
Ok so did some searching around here to look at different timing marks on pulley and couldnt find one like mine sorry for poor pic image :
so question is the dent is TDC to the left of it is a notch and to the right of the dent are four notches (white erase marks are four notches) that my pulley has what are they or how should i time my car?
Im running 34pic3 carb 009 distributor and my car 68' struggles on hard acceleration as in when i floor it it stumbles bad _________________ will you loosen up or will I have to take out the persuader(sledgehammer) |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80627 Location: Sneaking up behind you
Posted: Fri Oct 22, 2010 4:02 pm Post subject: |
Those are home made marks. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
volksbug70 Samba Member
Joined: August 22, 2005 Posts: 126 Location: Tallahassee, FL
Posted: Fri Oct 22, 2010 4:04 pm Post subject: |
Do the "pencil test" on cylinder #1 to find TDC (top dead center). Then you will know for certain where TDC is and can go from there. _________________ ~Dave (Brother of Matts70Bug)
1970 Beetle
Undergoing Full Restoration as of February 2017! |
EXJAY Samba Member
Joined: October 04, 2009 Posts: 1109 Location: Myrtle Beach, SC
Posted: Fri Oct 22, 2010 4:16 pm Post subject: |
| volksbug70 wrote: |
| Do the "pencil test" on cylinder #1 to find TDC (top dead center). Then you will know for certain where TDC is and can go from there. |
Or you can pull your distributer cap off along with your valve covers to check that way. Also while their off, check your valve clearance...
good video on how to do this--->
http://www.youtube.com/watch?v=Ozht-_iu3Ew _________________ EXJAY
'74 Superbeetle (Family owned since new)
'73 181 Thing (sold)
Glenn  Mr. 010
Posted: Fri Oct 22, 2010 4:19 pm Post subject: |
| volksbug70 wrote: |
| Do the "pencil test" . |
But read abut all the a-holes that dropped it in before.
Remove the crank pulley and the keyway is at 9:00 when it's at TDC. _________________ Glenn
Member #1009
#BlueSquare
EXJAY Samba Member
Posted: Fri Oct 22, 2010 4:28 pm Post subject: |
| Glenn wrote: |
| volksbug70 wrote: |
Remove the crank pulley and the keyway is at 9:00 when it's at TDC. |
Heh...I know someone who did this and the eraser fell out inside the chamber. _________________ EXJAY
'73 181 Thing (sold) |
Posted: Fri Oct 22, 2010 4:32 pm Post subject: |
| EXJAY wrote: |
| Glenn wrote: |
| volksbug70 wrote: |
Heh...I know someone who did this and the eraser fell out inside the chamber. |
yea happened to a friend and thats why i check tdc with the distributor _________________ will you loosen up or will I have to take out the persuader(sledgehammer) |
Posted: Fri Oct 22, 2010 4:35 pm Post subject: |
Remove the crank pulley and the keyway is at 9:00 when it's at TDC.[/quote]
thanks will check this out tomorro _________________ will you loosen up or will I have to take out the persuader(sledgehammer) |
Glenn  Mr. 010
EXJAY Samba Member
Posted: Fri Oct 22, 2010 4:37 pm Post subject: |
| vdubeetle wrote: |
| EXJAY wrote: |
| Glenn wrote: |
| volksbug70 wrote: |
yea happened to a friend and thats why i check tdc with the distributor |
Not me....I swear. _________________ EXJAY
Cusser Samba Member
Joined: October 02, 2006 Posts: 33556 Location: Hot Arizona
Posted: Fri Oct 22, 2010 5:11 pm Post subject: |
Glenn's photo rotated to show notch at 9 o'clock position and TDC at top. Remember, this could be TDC for either #1 or #3, look at the valves or the distributor rotor position to be sure.
And don't use a pencil; if you feel you need to do something like that, use a plastic drinking straw. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8857 Location: sound it out.
Posted: Fri Oct 22, 2010 5:15 pm Post subject: |
| Cusser wrote: |
| And don't use a pencil; if you feel you need to do something like that, use a plastic drinking straw. |
bingo... can't tell you how many times over the years I've suggested a drinking straw to someone only to later read their thread on "how do i get a broken pencil out of my cylinder".....
I use a positive stop, myself... _________________
| [email protected] wrote: |
| With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
justaguy Samba Member
Joined: May 07, 2008 Posts: 457 Location: Cambridge, Ontario
Posted: Fri Oct 22, 2010 5:36 pm Post subject: |
I didn't drop a pencil in the cylinder, but it did break off as I was trying to slowly cycle the engine to get it to TDC. I was however a good excuse to do a teardown and rering the cylinders and freshen up the engine  |
Posted: Fri Oct 22, 2010 5:39 pm Post subject: |
| justaguy wrote: |
| I didn't drop a pencil in the cylinder, but it did break off as I was trying to slowly cycle the engine to get it to TDC. |
haha...the key is to hold the pencil so it comes up straight... the pencil has a tendancy to drop to the bottom edge of the cylinder... damn gravity.... this puts the pencil in a bind as the piston comes up.... _________________
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16790 Location: North Florida, USA
Posted: Fri Oct 22, 2010 8:07 pm Post subject: |
This pic shows you that the stock timing marks are along the front (front of car) edge of the pully.
Also, if your distributor and pulley have not been kept as a matched set, the timing mark on the pulley may not be correct for the distributor you have installed.... lots can happen over the decades since our cars have left the factory.
| vdubeetle wrote: |
| ... thats why i check tdc with the distributor |
That works when you are familiar with the motor and KNOW that the distributor drive gear is indexed correctly. But if you are unfamiliar with the motor, I'm not sure you should trust that the rotor will point to the mark on the distributor body rim when the cam/crank is set for TDC on #1. Also different distributors point to different posts for #1 cylinder. And the installation of an electronic point module can change where #1 fires. _________________ AshMan40
Glenn  Mr. 010
Posted: Fri Oct 22, 2010 8:09 pm Post subject: |
Or if the engine was rebuild and the builder installed the driveshaft 180 off and then just moved the wires to accommodate it.
Never ASSume. _________________ Glenn
Member #1009
#BlueSquare
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Fri Oct 22, 2010 8:18 pm Post subject: |
| bugninva wrote: |
| justaguy wrote: |
haha...the key is to hold the pencil so it comes up straight... the pencil has a tendancy to drop to the bottom edge of the cylinder... damn gravity.... this puts the pencil in a bind as the piston comes up.... |
the real key is to leave the Muir manual in the shithouse and the Bentley in the shop...people seem to gravitate to Muirs worst proceedures..hell I gotta pencil in the shop,I use it to write shit down,crank position and valve position is the only way to tell TDC 1,on compression. |
TonyPgh Samba Member
Posted: Fri Oct 22, 2010 8:22 pm Post subject: |
| johnnypan wrote: |
| bugninva wrote: |
| justaguy wrote: |
I like the Muir for just reading for enjoyment. Like a comic book. But since I just got my Bentley recently..."wow", thats like having a vw mechanic in the garage with me. _________________ 1968 Type 1
https://youtube.com/c/SladesVWBeetle |
Posted: Fri Oct 22, 2010 8:47 pm Post subject: |
| johnnypan wrote: |
| [the real key is to leave the Muir manual in the shithouse and the Bentley in the shop...people seem to gravitate to Muirs worst proceedures..hell I gotta pencil in the shop,I use it to write shit down,crank position and valve position is the only way to tell TDC 1,on compression. |
I gotta be honest johnny.... I've never read Muir, and I don't even think I've ever had a copy in my hand... the pencil idea wasn't Muir's, its been around longer than muir...in a standard V8 or I4's and I6's, it's a viable indicator of when the piston is at TDC... I agree that valve position varification is the only way to know if you are on TDC on compression or exhaust.... that said, I pointed out earlier that I never suggest someone stick a pencil in their plug hole, if they need the visual(since pullies seem to vary) then use a drinking straw... I use a positive stop to check all my pullies(aftermarket) for accuracy, not a straw or pencil... _________________
burdpete Samba Member
Joined: October 24, 2007 Posts: 544 Location: Nebraska
Posted: Sat Oct 23, 2010 12:32 pm Post subject: |
Why not just go by the pulley. Have any of you ever had a stock pulley that was made with the TDC mark or the keyway in the wrong place? How about an aftermarket? I guess Ive never heard of it. _________________ 72 Beetle |
