ShotMagnet Samba Member
Posted: Sat Sep 08, 2007 12:31 am Post subject: Kill Switch Questions |
I have done searches on this site and others and I cannot find a picture or diagram, nothing. Remember I am new to the wiring thing be nice and simple if it all.
Thanks in AdVance
Craig |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10147 Location: Abiquiu, NM, USA
Posted: Sat Sep 08, 2007 9:21 am Post subject: |
You need to explain exactly what you wish to do, under what conditions, etc. Details.
And always begin any request for help by telling the year/model/equipment of your ride. They're not all the same, not by a long shot. Creating a signature line at the end of your posts including your vehicle info is a good way to do that automatically. |
Posted: Sat Sep 08, 2007 9:01 pm Post subject: |
thanx for the advise. It is a VW 82 Vanagon W/ westy camper. Aircooled if that helps |
Dogpilot Samba Member
Posted: Sun Sep 09, 2007 9:54 am Post subject: |
What he meant, besides the kind of car, is what you aim to achieve. A kill switch on a dragster is a different creature from lets say; an anit-theft type installation. If your going to actuate it from a keyless entry system or alarm or so on.
If your looking to do simple, cutting the power to the fuel pump is an easy one. There is also the power to the ECU makes the van dead as a doornail. The fuel pump is the most straight forward. I don't have any schematics for the 82, so you will have to resourceful on your own. However, it is not rocket science to run a pair of wires down to the pump and make a break point. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Sun Sep 09, 2007 4:06 pm Post subject: Re: Kill Switch Questions |
ShotMagnet wrote: |
Thanks in AdVance
Craig |
Lucy, you got some 'splaining to do.... _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Posted: Mon Sep 10, 2007 9:37 am Post subject: |
Dogpilot wrote: |
If your looking to do simple, cutting the power to the fuel pump is an easy one. There is also the power to the ECU makes the van dead as a doornail. The fuel pump is the most straight forward. I don't have any schematics for the 82, so you will have to resourceful on your own. However, it is not rocket science to run a pair of wires down to the pump and make a break point. |
lol I know it isnt rocket science. I am afraid of screwing something up. And I am blushing right now " I dont even know what a fuel pump looks like" How embarassing for me to say that! _________________ Thanx in Advance,
Craig, Holly and Ross
'82 Westy Vanagon air cooled
http://vanagonshananigans.blogspot.com/
"There is more to life than increasing its speed." Mahatma Gandhi (1869 - 1948) |
kevinbassplayer Samba Member
Posted: Mon Sep 10, 2007 9:44 am Post subject: |
Look under the van on the passenger side just behind the fuel tank. There will be a short piece of hose that may or may not have a filter attached, then you will see a roughly 6 inch or so long round thingy that the hose from the tank is attached to. that is the fuel pump. There is a clip with two wires that is attached to the fuel pump, these wires are what deliver power to the fuel pump. The basic idea behind a fuel pump cutoff switch is to cut one of these fuel pump wires and attach a switch in between them. dosen't matter which wire, either one will break the circuit when the switch is in the off position and not allow the pump to run. Switch on, all good. The more you learn about your van the better off you will be, this forum is probably the best "Vanagon University" I know of. (How about a t-shirt, Vanagon University class of xx? anyone out here make shirts, I'd buy one!) |
Posted: Mon Sep 10, 2007 9:51 am Post subject: |
Just get a big dog and let him live in your van. A better security system has never been devised. Ask the cops, they'll tell you the same: if you don't want your car stolen, you need active security, i.e. something that will rip a thieve's friggin arm off if he's stupid enough to stick it in the car. |
bucko Samba Member
Posted: Mon Sep 10, 2007 9:59 am Post subject: |
tencentlife wrote: |
And make it a hungry dog...one that has not been fed for a day or so.... _________________ Current VW drives: 1984 Westfalia
Posted: Tue Sep 18, 2007 3:08 pm Post subject: |
thanx everyone _________________ Thanx in Advance,
Posted: Tue Sep 18, 2007 3:10 pm Post subject: |
thanx everyone going to install it tomarrow _________________ Thanx in Advance,
Posted: Tue Sep 18, 2007 3:33 pm Post subject: |
The dog? |
Posted: Tue Sep 18, 2007 4:54 pm Post subject: |
yep a pack of them (will 10 chawawas (sp) work) _________________ Thanx in Advance,
Posted: Tue Sep 18, 2007 5:46 pm Post subject: |
Only if they're wirelessly linked to coordinate their attacks.
(it's Chihuahuas) |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Fri Nov 05, 2010 5:02 am Post subject: |
Okay, I'm reviving an old thread here, but I just did this today and this topic is still relevant.
My approach: Rather than mess with the fuel pump power supply, I added a switch to the fuel pump ground.
The following has more detail than needed if you are adept at 12 volt systems, but is wordy to aid my fellow 12 volt noobies.
Shopping list, get most of it at the car parts store:
- stout metal toggle switch, simple on-off with 2 connection points
- 1 roll 16 gauge black or brown wire (black is not mandatory, but it reminds you it's a ground wire.)
- 3 female spade connectors, blue plastic (for med/16 gauge wire, 2 for toggle switch, 1 for fuel pump)
- 1 ring connector, for ground wire to bolt connection
- small bolt and nut, about 1' long (to mount switch and be a ground)
- dozen zip ties
- roll of metal plumbers tape
Step by step:
1) Pulled off the spade connector for the fuel pump ground wire. (Left it in place for possible later use in case I screwed this up =^)
2) Crimped on a spade connector onto 16G wire, and plugged new spade connector onto fuel pump ground.
3) Routed wire along passenger side above gas tank, then out to the front right jack point, up thru small plastic plug in the body, allowing access to the pillar behind the front passenger seat.
4) Pulled off the little air vent thingy, and mounted a stout toggle switch inside the pillar. Wire comes up from fuel pump, connects to one side to the toggle switch, then another short bit of wire (about 6") connect the other side of the switch to a ground bolt.
5) I made a mount for the toggle switch out of about 8" of metal plumber's tape, the ultra handy stuff that is a roll of flexible metal with small holes in it every inch or so. Not very pretty, but this switch will not get much use and will never be seen, so no worries. I had to enlarge the mounting hole a bit with a drill (1/2" bit?) to get the plumber's tape to fit the switch.
I thought a lot about the best place to mount the actual switch. Anyone who has pulled off the little air vent thing on either front door that allows easy access to the pillars probably has wondered about using this cavern as some sort of stash spot. It seemed to me a perfect place to hide the switch, giving fast and easy access from the front of the van yet still fairly stealth.
Tip: When working in the pillar, be sure and stuff a rag down inside below your work area to prevent small dropped items from getting lost forever, ask me how I know this.
If any part of this wiring ever gets cut, damaged, etc, all I need to do is pop off the new spade I added from the pump and reconnect the original spade, about a 10 second process.
I hope this write up helps someone give this project a try. If you are new to 12 volt projects this one is very simple, and a good place to get your feet wet.
-CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15346 Location: Syracuse, NY
Posted: Fri Nov 05, 2010 7:57 am Post subject: |
very nice solution and execution to this Climberjohn.
Abscate wrote: |
BlackDogVan Samba Member
Joined: December 21, 2007 Posts: 855 Location: Vancouver Island
Posted: Fri Nov 05, 2010 8:08 am Post subject: |
The guys at my work learned long ago to just come tell me when I leave my lights on...
Don't forget to update your location in your profile when you're detailing your kill switch information. _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka... |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Fri Nov 05, 2010 9:38 am Post subject: |
Climberjohn, excellent write-up. Thanks. |
msinabottle Samba Member
Posted: Fri Nov 05, 2010 1:09 pm Post subject: Thank you! |
That is a nice write-up. I need to get on that, myself. Thank you!
Posted: Fri Nov 05, 2010 1:36 pm Post subject: |
BlackDogVan wrote: |
Don't forget to update your location in your profile when you're detailing your kill switch information. |
Hee hee, you're funny. Just for that post, I'm going to add another kill switch to the ECU that you'll NEVER find  _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
