npbusguy Samba Member
Joined: February 08, 2006 Posts: 1661 Location: Budapest, Hungary
Posted: Sat Nov 06, 2010 1:40 am Post subject: |
Looking great Jim!
I am back from my big trip in case you need a hand, let me know. |
vws-microcars4jim Samba Member
Joined: September 25, 2005 Posts: 357 Location: Chicago
Posted: Wed Nov 17, 2010 9:28 pm Post subject: |
I have now welded up over sixty small holes in the nose of this bus, all left from some old-school bodywork techniques. I have also been slowly hammering many dents out, while trying not to stretch the metal too much.
Maybe saving this nose is too big an effort. I have been looking at the less-than-great noses that are on the market for $1K or more, to me it seems this is worth trying to save.
I was thinking once the nose was done this project would be smooth sailing.
Then I took off the red paint from the rear corners for another surprise.
Someone thought brazing was a good idea.
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1576 Location: stoughton, WI
Posted: Wed Nov 17, 2010 9:45 pm Post subject: |
That corner looks like a fat old lady cottage cheese thigh. _________________ Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com |
kombicol Samba Member
Joined: January 11, 2008 Posts: 212 Location: Perth Australia - Now in Texas y'all
Posted: Wed Nov 17, 2010 9:56 pm Post subject: |
Great thread and epic resto.
If your going to try and repair that nose and rear corner, get yourself a shrinking disc if you havent got one already. |
spookymulder Samba Proletariat
Joined: January 02, 2004 Posts: 3298 Location: I'm either at 95608, 97537 or 94708 only my CPA knows for sure
Posted: Wed Nov 17, 2010 10:01 pm Post subject: |
JOGR wrote: |
That corner looks like a fat old lady cottage cheese thigh. |
Sounds like you have some experience with them  |
Gmiee5 Samba Member
Joined: December 06, 2008 Posts: 389 Location: Portland Oregon
Posted: Thu Nov 18, 2010 12:32 am Post subject: |
WOW what a great job on the bus!! I thought my bus had allot of work
You are definitely spending the time and not cutting the corners.
As for the nose I say replace it...
If you fix the nose it will be the one place that will bug the crap out of you knowing that it probably should have been replaced. IT’s just my two cents. _________________ _______________________
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2158 Location: Florida
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2378 Location: In the woods, Ontario
Posted: Sat Dec 04, 2010 2:29 pm Post subject: |
I am really enjoying this thread. Great to see someone go to so much effort to save an early westy... |
sethm Samba Member
Joined: November 10, 2005 Posts: 206 Location: Jacksonville, NC
Posted: Sat Dec 04, 2010 3:12 pm Post subject: |
JOGR wrote: |
Sack of nickles  _________________ 66 Westy/Dormobile convert |
bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Fri Dec 24, 2010 8:26 am Post subject: |
Great work, keep it going  _________________ 1954 Barndoor
1955 Oval |
Tistlo Samba Member
Joined: July 14, 2008 Posts: 80 Location: Voss, Norway
Posted: Fri Dec 24, 2010 4:33 pm Post subject: |
Good thread!! Keep up the good work
Lots of good pics 'n tips. You should get yourself a slapper and dolly for the nose and that extremely straigt corner of yours
looking forward for updates here |
Posted: Wed Dec 29, 2010 2:57 pm Post subject: |
Thank you all for the encouragement. It has been slow going lately and I have nothing to blame except myself, and the cold garage working conditions.
brettsvw wrote: |
I love your build thread and look back at it often to give me the extra will power to push forward. |
Thanks Brett, I look at your thread for inspiration too, but I can't get over the wood chip work area, perhaps it is more forgiving than concrete.
I have been doing little projects (until my fingers go numb).
Scored this sand green crank start apron from the Holcombs garage, thank you Brian!
It had been hacked for beetle tailpipes, and had rust.
I noticed it comes apart, which is handy for repairing!
I have been assembling all the parts that make up a '58 shift assembly, and I'm afraid I'm not done yet.
Thanks to Bill from FL for the shifter.
Thanks to Rich for the early front shift rod.
Thanks to Hazetguy for the M-spring, although there is no cutout for it on my shift plate.
You can see in that photo where I cut-and-spliced the earlier rod.
I got it all together and it shifts, although not super-smoothly.
I don't know if the plate is correct or will affect this.
Is this correct or should there be a different "link"?
The rear bushing (at the transmission) that is installed is the one that was on the bus when it came apart. I found another in my parts stash, is either correct?
Thank you to all that have posted on TheSamba, it is very helpful.
Jim |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71585 Location: Phoenix 602
Posted: Fri Jan 14, 2011 3:24 pm Post subject: |
I stopped by Jim's yesterday and checked out the progress on the bus. Jim was busy cleaning the garage and taking advantage of a relatively warm day to have the garage door open, I think it was about 20 degrees?
Anyways, it is looking good buddy, getting it in primer really is fun and makes it look better! I think its time to start welding the gerson metal in.. you can't measure forever! Measure it up and weld that shit in.. We'll build a rotisserie and finish the underside later, just start putting it together, don't be skeered!
It looks awesome, we'll be camping in no time.... _________________ Josh The Bus Guy formerly known as JOGR
Posted: Fri Jun 17, 2011 9:35 pm Post subject: |
Any updates on this bus? Was looking great at last post.. |
Posted: Sat Aug 13, 2011 8:16 pm Post subject: |
Was thinking about your bus today.. Any progress? _________________ Josh The Bus Guy formerly known as JOGR
Posted: Sat Aug 13, 2011 9:28 pm Post subject: |
Not much to report lately. My wife is divorcing me, turns out all the funky green metal and other parts purchased for this bus will likely be consideted marital assets. I may lose it all so I haven't done more work. Buzz the bus cat / project inspector has been taken from me . Saturation with alcohol also isn't helping get much done.
Jim |
Cuñado Wear Samba Member
Joined: December 10, 2006 Posts: 1145 Location: The "O"
Posted: Sat Aug 13, 2011 10:51 pm Post subject: |
Jim,
Hang in there brother! I've been down this same road and its long.
Sorry to hear this.I gave her everything in my case except my vert and tools.
the drinks didnt help me much either.
Good luck. and take care. _________________
Bulli Klinik wrote: |
I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
63’ ez-camper
63' 15 Window Deluxe
65’ Notchback |
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1792 Location: Sanford, FL
Posted: Sun Aug 14, 2011 4:37 am Post subject: |
vws-microcars4jim wrote: |
Jim |
Sorry to hear this.
Sell the parts and metal cheap to a friend. I'm sure they'd donate it back to you. |
Posted: Sun Aug 14, 2011 2:47 pm Post subject: |
I have room for funky green storage.
What about the 360? What a mess... Stay strong brother! _________________ Josh The Bus Guy formerly known as JOGR
