NOS PARTS Samba Member
Joined: June 24, 2001 Posts: 377 Location: behind the wheel, safari's open
Posted: Fri Nov 07, 2008 5:12 pm Post subject: 64-67 rear hatch hinge-replacement |
picked up this 13 deluxe and in need of a rear hatch hinge replacement
wondering if anybody has any details instructions to remove,replace
thanks
mintonman Samba Member
Joined: October 20, 2003 Posts: 4247 Location: between Trenton NJ. & Philly Pa.
bushaus Samba Member
Joined: November 18, 2007 Posts: 809 Location: Long Beach, Calif
Posted: Fri Nov 07, 2008 5:55 pm Post subject: |
This was one of my first repairs, can be kinda dangerous. Also check this thread http://www.thesamba.com/vw/forum/viewtopic.php?t=296278
for more info.
HELPFUL HINTS- 1)post a classified ad, you should be able to find the parts from someone on here (remember to specify which side), 2)take pics of the hinge and pin location before disassembly, 3)wear gloves and be wary of high tension! _________________ 1967 13 window walkthru bus
1965 Karmann Kabriolett beetle
| hitest wrote: |
| Even if completed, the abarth's gonna belch spluey all over your Eriba. |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Fri Nov 07, 2008 7:00 pm Post subject: |
wish I would have found those easy instructions before I did mine!  _________________ 1967 13 window walkthru bus
| hitest wrote: |
Posted: Sat Nov 08, 2008 11:00 am Post subject: |
| bushaus wrote: |
wish I would have found those easy instructions before I did mine!  |
well with the easy instructions and the tool drawings, its easier than the previous info I got before.... "get a BIG screw driver, wear gloves, be careful..." |
islandveedub  Samba Member
Joined: March 10, 2003 Posts: 158 Location: Honolulu, Hawaii
Posted: Sun Jan 17, 2010 7:49 pm Post subject: |
Glad I ran across this thread. I did this once before without the instructions and even though we were successful, it was the scariest thing I've ever done. I saw the tool, so I figured out how to make one of my own out of a factory jack handle.
The tool worked like a champ. However, that's still a lot of freakin' tension. With the tool and instructions, this job is now the second scariest thing I've ever done.  _________________ Alex
60 Doublecab
62 23 Window Walkthrough Bus |
tubdub Samba Member
Posted: Sun Jul 11, 2010 1:38 pm Post subject: |
| picked up the homemade tool from islandveedub and it took about 1/2 hour to pull the assembly from a parts bus roof and install it on my bus. if anyone in the sacramento area needs to use it let me know. |
tubdub Samba Member
Posted: Sat Nov 20, 2010 7:18 pm Post subject: |
bumping this so chris roop will find the instructions  |
chris roop Samba Member
Posted: Sat Nov 20, 2010 7:38 pm Post subject: |
| Most excellent! After 25 years of commercial fishing I still have all my fingers and would like to keep it that way. |
SocalRico Samba Member
Joined: February 09, 2010 Posts: 1 Location: West Covina
Posted: Tue Dec 12, 2017 3:24 pm Post subject: Re: 64-67 rear hatch hinge-replacement |
Here is a video how to install the hinge. I know it's in Spanish but it's pretty straight forward. One thing to note, the guy in the video says never try to do this alone, you need 2 people.
[/youtube] |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2225 Location: SW Nova Scotia, Canada
Posted: Mon Apr 02, 2018 9:34 am Post subject: Re: 64-67 rear hatch hinge-replacement |
Just installed my hatch hinges and thought I would add a little here as the instructions I found were not that clear. I was dreading the job but it turned out to be quite easy once I figured out how the rods went in.
First I installed the hinges and used some tape to keep them out of the way. Don't forget the clips. Easier to put them in now without the arms in the way.
The rods are different. The end that hooks into the roof support is leaned over a bit. This is the rod for the right side hinge.
The rod can be hooked into the support slot and then the end allined with the hole. Move it around and wiggle it and it should slide in.
On the other end of the rod slide on the arm.
I built a simple tool to wind the bar. I didn't need as much hook on the end. You will definitely need something like this to install the rod safely.
Hook the tool in the rod. Keep some space between the tool and the arm. You will likely need the try it a few time to get the arm lined up with the support.
While standing at rear hold the rod about 6" from the arm with one hand and push down and forward on the tool to rotate the rod. You can guide the rod up into the forward slot in the support. Notice support is between the arm and the tool.
Once in place wind the rod a bit more to insert the arm pin. Insure the pin is all the way in before removing the tool.
Pull down on the hinge to release the tool. Install the clip on the pin so it doesn't work out
After the second rod can be hooked into the support by pulling down on the left hinge a little. You could hook both rods in at the start but I thought it might be easier if it wasn't in the way. _________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
Danny79 Samba Member
Posted: Sun Feb 09, 2025 7:19 pm Post subject: Re: 64-67 rear hatch hinge-replacement |
Ha, now I find this post. Well, it was not here 11 years ago when I bought my bus in Watertown NY and towed it home in a snow storm, back to Pittsburgh.
I got a replacement hinge off a donor bus, and I procrastinated 10 years until today !.. Fixed.
I installed half the hinge first, using a pipe over the one end of the hinge.
Get the hinge on the torsion rod so when you bend it down, it will go inside the fixed hinge part of the roof. That is one very important detail so it fits. Once I aligned it, the pipe brought it down and I could install the rod in that little cut out attached to the roof.
Then I used the big sears screwdriver to bend down the end of the C shape of the rod which dropped the first half of the hinge out of the way, and I got the second half of the hinge in place and put those pins in the proper place and fully seated. The are elongated oval, and have to sit in the hinge it's self.
Had to tell someone ! Then after I did that, I realized the one hinge not bent is a different design than the one I just installed ! ...they were not symmetrical in pointing to the sky. I'll fix that in the daylight...yea, sun had set. |
