Brakes to the floor... occasionally
Pittoale
Pittoale is offline
PostPosted: Wed Oct 18, 2006 3:32 pm    Post subject: Brakes to the floor... occasionally Reply with quote
Sounds like a typical brake problem after a quick search here in the forums, but no one had this particular problem I think.
When I push the brake pedal, it surprises me every time with how far it goes. Sometimes it grabs right away, sometimes halfway, sometimes to the floor. Pump it once and it is usually back to grabbing about a quarter of the way down. Drive it a little ways, start over again.
We have recently adjusted the shoes and bled the lines to fix it before. It has started getting worse again. I am on my way to check for leaks on the cylinders, etc.
Please let me know if you have had this problem and what I should look for / do.
xeno
xeno is offline
PostPosted: Wed Oct 18, 2006 3:41 pm    Post subject: Reply with quote
Almost always an air pocket or fluid escaping. rarely is it water in the line or contamination.
Pittoale
Pittoale is offline
PostPosted: Wed Oct 18, 2006 3:51 pm    Post subject: Reply with quote
I see no leaks of brake fluid, and the reservoir is still topped off to the same level we left it at.
Woreign
Woreign is offline
PostPosted: Wed Oct 18, 2006 4:36 pm    Post subject: Reply with quote
Your brake master cylinder is probably leaking internally. I recommend replacing it with a new cylinder. Rebuild kits rarely solve the problem...
Pittoale
Pittoale is offline
PostPosted: Wed Oct 18, 2006 4:52 pm    Post subject: Reply with quote
That was what I was thinking, possibly a new master cylinder would fix it. From previous posts, it looks like I should spring for the German version.
Some posts mentioned replacing the master and wheel cylinders, lines, and hoses all at once. I am a little confused about the lines/hoses. The Thing Shop lists both, I don't know the difference. I also don't know if I am up to replacing all of that on my own, what is the process for each part (master, wheel cyl x2, lines/hoses)?
Thanks for all your help!
Captain Spalding
Captain Spalding is offline
PostPosted: Wed Oct 18, 2006 5:20 pm    Post subject: Reply with quote
If you own a 33 year old car and you aren't sure of the maintenance history, it makes sense to replace aging brake system components as a matter of due dilligence. If you have recently had parts replaced, of course there's no need to do it again just for the benefit of saying you did it all at the same time. Let common sense be your guide.
If you feel that repairing your brakes is over your head, I urge you to get the BugMe Video tutorial (Volume 4 covers the brakes.) It really walks you through step by step. After watching it you will feel totally at ease doing all the work yourself.
Woreign
Woreign is offline
PostPosted: Wed Oct 18, 2006 7:02 pm    Post subject: Reply with quote
Brake lines are the metal tubes that attach to the master cylinder and stop short at each wheel. From there the brake hoses, which are made of flexible rubber, attach to each wheel cylinder. The brake hoses allow the wheels to turn and the move with the suspension. Rust will attack the lines and hoses will become brittle and cracked with age.
Replacing these parts is fairly easy, as is bleeding the system of air and adjusting the shoes. Take your time and you shouldn't have any problems.
bucko
bucko is offline
PostPosted: Thu Oct 19, 2006 3:56 am    Post subject: Reply with quote
I second (or third) the suggestion about the brakes. While a visual inspection may provide you with the illusion that the rubber "flex lines" from the back of the drums to the metal lines look good, they get soft internally, causing swelling which blocks the fluid to the wheel cylinders, or they can/will flex wider causing a spongy brake pedal feel.
After 30 plus years, they are all overdue for replacement. Add to your list the special flare wrench so that you do not strip the nut ends (rubber flex lines to metal). Soak these overnight with your favorite lubricant to help out.
You will find that your brakes are new again and problem free once this replacement has been done. Don't forget to replace the master cylinder with a good German unit too.
Pittoale
Pittoale is offline
PostPosted: Thu Oct 19, 2006 8:57 pm    Post subject: Reply with quote
Thanks for the help, I will hopefully be working on it soon, we'll see if I can afford to do the whole brake system or not.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Thu Oct 19, 2006 11:08 pm    Post subject: Reply with quote
You can't afford NOT to have good reliable brakes.
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Video Bob
Video Bob is offline
PostPosted: Fri Oct 20, 2006 12:18 pm    Post subject: Reply with quote
Brakes are everything. Here's a photo of my start on brake restoration. Only new parts in photo is the shoes and cylinder. Everything else was restored by sandblasting and polishing with a vibrating polisher. Hi temp engine paint used for painted parts including brake drum (not shown)
Check out the sandblasted shock with orange metal flake paint.
https://www.thesamba.com/vw/gallery/pix/310265.jpg
Ya can't have too many Vdubs!
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22
markie61
markie61 is offline
PostPosted: Fri Oct 20, 2006 12:28 pm    Post subject: Reply with quote
I put money into "stopping" before putting money into "going".
Mark
Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!?
Pittoale
Pittoale is offline
PostPosted: Fri Oct 20, 2006 12:36 pm    Post subject: Reply with quote
Wow, great picture! Good job on that brake restoration.
Ian Epperson
Ian Epperson is offline
PostPosted: Mon Oct 23, 2006 9:54 am    Post subject: Reply with quote
Did you adjust the caster? It looks as if the beam is leaning back a bit.
Great looking job! I hope I can get mine looking as good.
Video Bob
PostPosted: Mon Oct 23, 2006 10:43 am    Post subject: Reply with quote
No beam adjustment. Only the brake components were removed for cleaning, replacement and painting. Suspension was blasted and painted in place.
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22
Worknclassbug
Worknclassbug is offline
PostPosted: Fri Nov 26, 2010 7:03 am    Post subject: Reply with quote
I'm draging this post up from the past. I'm having the same problem as the OP. The brake pedal is very random. The PO of my car had a shop rebuild the the brakes at each wheel and they did a great job. They replaced all of the cylinders, shoes and hardware at all wheels. I've adjusted the shoes and the pedal is nice and firm and the car stops straight and great. The problem is that the point that the brakes engage is random on the pedal. Sometimes they go straight to the floor but the next pump of the pedal they are up to the top. Sometimes they are half way down and at times they are at the top like they should be. It's very random. The master cylinder appears to be the original so I think my first step will be to replace it but I was curious as to what the OP of this thread did to correct the problem. I have no problem replacing the m/c but I don't want to do it if I don't have to. Any advice would be great. Thanks.
73 Thing
71 Karmann Ghia (2.2L Subaru Conversion)
72 Deluxe Transporter
Huntington WV
Member of The Wagenfolks
BNMike
BNMike is offline
PostPosted: Sun Nov 28, 2010 12:06 am    Post subject: Reply with quote
This is one of the projects that Hermann is going to get this Winter. I've got all 4 new wheel, and a Master cylinder.
BNMike
alex77
alex77 is offline
PostPosted: Sun Nov 28, 2010 5:53 pm    Post subject: Reply with quote
it sound like your brake master cyl is loosing pressure. That is why the second time you press on the brake pedal it feels better. Do you have a functional brake warning light?
91 mexibeetle
kubelmann
kubelmann is offline
PostPosted: Sun Nov 28, 2010 8:50 pm    Post subject: Reply with quote
Other than OE German master cylinder units the other (country of origin) outlander units fail just some sooner than others.
Wildthings
Wildthings is offline
PostPosted: Sun Nov 28, 2010 10:11 pm    Post subject: Reply with quote
Press the pedal slowly and see what happens.
