deronmoped Samba Member
Joined: November 18, 2006 Posts: 375 Location: San Diego
Posted: Sat Dec 11, 2010 6:40 pm Post subject: Widest stock wheel? |
1) What is the widest stock wheel they made with the wide five pattern in 15".
2) Can a wide five wheel be purchased aftermarket that allows you to use the stock hub cap?
3) Has anyone welded the center of a wide five wheel onto another rim?
Trying to come up with a wider wheel that goes on a wide five pattern and uses the stock hub cap.
Thanks, Deron. |
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Sat Dec 11, 2010 6:49 pm Post subject: |
My buddy took his stock Nova rims and had them split and widend. Is that spelled right? |
durfeec Samba Member
Posted: Sat Dec 11, 2010 7:25 pm Post subject: |
there are a ton of ppl that take their stock wheels to a shop and have the centers cut out and put on a wider barrel. there is actually a place in california that everyone there seems to love but idk the name. someone else will though im sure.
but yes its pretty common now. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42553 Location: at the beach
Widened - one more E _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
SGKent  Samba Member
Posted: Sat Dec 11, 2010 7:38 pm Post subject: |
P.S. If you are going to widen wheels, better make sure you have the correct width tires to go on it and the correct load range for a bus. It is a utility truck that has quite a bit of weight in the rear. The guy who sold me my CJ7 in 1982 put a set of wide Enki rims on it. They were beautiful but the first rain storm I was all over the place like a hockey puck on a skating rink. The tires were pulled so that they were U shaped and had very little footprint. Wider tires solved the issue but it was pretty scary for the first few weeks while I figured out what was going on. You don't want to widen them until you know the optimal width for the tires you are going to buy.
Here is a chart from online. I cannot vouch for its numbers but it is probably good. Normally the optimal wheel width is 1/2 way in between the allowable range.
http://customwheelsmarket.com/rimwheelwidth1.html _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Desertbusman Samba Member
Posted: Sat Dec 11, 2010 10:27 pm Post subject: |
Sure, centers and rims can be taken apart, switched, and welded. Also the rims themselves can be cut and a insert welded in. _________________ 71 Superbug
71 Westy |
WestyPop Samba Member
Joined: February 08, 2005 Posts: 1734 Location: SoCal
Posted: Sun Dec 12, 2010 3:09 am Post subject: Re: Widest stock wheel? |
deronmoped wrote: |
Thanks, Deron. |
Answer to your #1 question... 5" wide was the maximum in a 15" diameter (early-to-mid-1960s?) IIRC, but the good answers already given to your questions #2 & #3 illustrate a better way to go. Make sure the guys who widen the wheels for you give you the correct back spacing also, to avoid possible brake & steering component interference.
Check out the widening operation carefully; some have reputations for shoddy work. Not an area of replacement parts in which one wants to gamble. _________________ Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others) |
Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Sun Dec 12, 2010 4:48 am Post subject: |
Stockton Wheel Service in Stockton, Ca. is who you need to talk to. They have a site and are very good at what they do. I remember a Friend with a '55 Bug and it had rear tires on it that looked to be 8 inches wide. Stockton did the wheel and they looked like stock VW. _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
Posted: Sun Dec 12, 2010 10:14 am Post subject: |
I agree with aiming for the center of the acceptable widths. Too wide and your wheels will be what scuffs against a curb or bangs a rock and too narrow and you may have issues with keeping the tread flat. For good handling it is usually important to keep the offset close to original.
If you run a 215/70R14 tire on either a 5.5" wide rim or a 7.0" wide rim, so long as the rims have the same offset the tire will run with about the same clearances. While if you go with a different offset you may have problems even if you don't change the width of the rims. |
