1957_SC Samba Member
Posted: Mon Dec 20, 2010 4:30 pm Post subject: Dash Board Changes |
I have seen some references on the site as to the shape of the pod being slightly different.
Having a dash put in now, and I am reasonably sure I have the right one. Just wondering if anyone can outline the differences - maybe with pictures?
thanks in advance. |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 1006 Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota > Babcock Ranch
Posted: Mon Dec 20, 2010 4:38 pm Post subject: |
Not sure I am aware of 'Pod' changes in split window busses other than Barndoor?
But I am by no means an authority... _________________ Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
My '66 after the crash.
Click to view image |
Posted: Mon Dec 20, 2010 4:42 pm Post subject: |
| KevinAlbrecht wrote: |
But I am by no means an authority... |
My understanding as well. Last week I noticed a couple of older posts mentioning a change, but of course I can't find them now. |
my65vert Samba Member
Joined: November 09, 2003 Posts: 6187 Location: Middleburg, Florida
Posted: Mon Dec 20, 2010 4:43 pm Post subject: |
rounded top corners on the pod= late
pointed top corners=early _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Mon Dec 20, 2010 4:49 pm Post subject: |
A couple of changes I can think of off the top of my head.
Post barndoor to July 61 had a pointy speedo pod. August 61 to 67 had a rounded speedo pod.
Early (55-61?) Commercial, and Standards did not have a factory grab handle.
Some de Luxes did, but I don't know when that started.
August 62 was the start of the gas gauge in the dash.
67 had a different hole for the radio and different block off plate.
Thin lipped parcel tray up to about May 61. Some real late pointy speedo pods had the bigger notch for thick lipped parcel trays.
Other minor changes like an additional hole for 4 way flasher indicator on late models.
Doubtless there will be an expert along soon to detail more minutia on dash changes throughout the years. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Mon Dec 20, 2010 4:59 pm Post subject: |
| my65vert wrote: |
pointed top corners=early |
So this -
late
and this -
early? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 21005 Location: Sandpoint, ID
Posted: Mon Dec 20, 2010 5:07 pm Post subject: |
^^^ yes _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Mon Dec 20, 2010 5:37 pm Post subject: |
Single cabs also do not have a hole in the pod for a rear dome light switch.
I can't remember for sure, but I think there are differences where the turn signal wire harness goes through it too. |
Posted: Mon Dec 20, 2010 5:59 pm Post subject: |
| 1957_SC wrote: |
| my65vert wrote: |
So this -
late
and this -
early? |
correct! _________________ OGJHC
Kombisutra;
Lind Samba Member
Joined: November 06, 2000 Posts: 10278 Location: idaho
Posted: Mon Dec 20, 2010 6:09 pm Post subject: |
post-BD:
'55-'59ish pointy top, thin lip tray, turn sig. wire hole
'60ish-april '61 pointy top, thin lip tray, turn sig. wire indent (at bottom of pod)
april '61 - july-ish '61 pointy top, fat lip, turn sig. wire indent
august '62 - 'july '67 rounded top, fat lip, turn sig. wire indent
grab handle standard on deluxes august '58.
grab handle standard on all models april '61. _________________ .
Wanted:
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Mon Dec 20, 2010 6:10 pm Post subject: |
| roachdub58 wrote: |
| Single cabs also do not have a hole in the pod for a rear dome light switch. |
Later ones do!
Posted: Mon Dec 20, 2010 6:13 pm Post subject: |
| Lind wrote: |
| '55-'59ish pointy top, thin lip tray, turn sig. wire hole |
And I'm pretty sure the hole got larger in '57 with the transition from 3-wire switch to the 6-wire. |
Posted: Tue Dec 21, 2010 4:29 pm Post subject: |
| Got it! thanks guys. |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2996 Location: San Diego, CA
Posted: Tue Dec 21, 2010 4:57 pm Post subject: |
| Radio hole block off plates changed during the '55 to '67 period as well. |
Posted: Tue Dec 21, 2010 5:39 pm Post subject: |
| Anchovy wrote: |
How so? I know about the 67 delete plate being bigger, but what about any other changes? _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Wed Dec 22, 2010 7:38 am Post subject: |
| cdennisg wrote: |
| Anchovy wrote: |
How so? I know about the 67 delete plate being bigger, but what about any other changes? |
early 67 still used the 66 style radio opening and block off plate. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Wed Dec 22, 2010 9:03 am Post subject: |
| bill may wrote: |
early 67 still used the 66 style radio opening and block off plate. |
I always heard this, too. But in this thread you can see that '67 bus with VIN 000706 has the later radio hole. |
Clara  Samba Member
Posted: Wed Dec 22, 2010 9:20 am Post subject: |
gas guage hole standard hole 62 on
red light hole left of speedo pod near gas guage for e blinker 63-65 us spec buses.
euro spec buses may not have hole for e flasher switch. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2179 Location: Florida
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Sun Dec 26, 2010 9:14 am Post subject: |
^^^^^^that is a beautiful dash! _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
| dawerks wrote: |
| Perfection only comes with delusion. |
http://www.oacdp.org/ |
