BYeaton Samba Member
Joined: November 27, 2007 Posts: 365 Location: El Segundo
Posted: Sat Dec 04, 2010 3:11 pm Post subject: |
Oh okay. So they're kind of suspended by the 2 screws where the sled is attached to the case? |
bartman Samba Member
Joined: February 22, 2004 Posts: 767 Location: palatka, fl
Posted: Sun Dec 05, 2010 8:26 pm Post subject: |
Wow those look really solid! You definitely answered my question about being able to mount them on the head somewhere.
Well played sir. |
thefladge Samba Member
Joined: July 25, 2005 Posts: 1294 Location: Anaheim, CA
Posted: Sun Dec 05, 2010 8:55 pm Post subject: |
Another solution: Modified water-cooled Vanagon push rod tube protectors.
_________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
AlteWagen Troll
Posted: Sun Dec 05, 2010 10:19 pm Post subject: |
thefladge wrote: |
Another solution: Modified water-cooled Vanagon push rod tube protectors. |
Part number please. If not what year and engine?
Thanks |
Posted: Mon Dec 06, 2010 12:04 am Post subject: |
thermostat fit under there? |
Posted: Mon Dec 06, 2010 5:18 am Post subject: |
I don't have the part numbers, but they should be the same on all gas powered, water cooled Vanagons. Mid-1983 to end of production.
Two of the tabs that attach to the exhaust studs have to be modified to fit a Type 1 engine.
These are very thick and strong.
The thermostat will not work with this. _________________ 1957 Vintage Baja Bug.
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Jan 03, 2011 11:17 am Post subject: |
Hey Glenn,
What are part #3 and #4 from the left on the top row? Trying to get my tins in order for my Chico motor. I have a set of industrial tins, need to get 2 lower sleds, and trying to figure out what else I need to source.
_________________ 1957 Beetle
1966 Bus |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Mon Jan 03, 2011 11:19 am Post subject: |
those pieces attatch to the rear edge of the cylinder tin to keep the air flowing around the barrels.... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Mon Jan 03, 2011 11:43 am Post subject: |
gotcha.
You guys run these with this setup too?
1966 Bus |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79784 Location: Sneaking up behind you
Posted: Mon Jan 03, 2011 11:45 am Post subject: |
GLHTurbo wrote: |
gotcha.
Yes, most important. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
You can run those but the cool tins work better...... _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
Posted: Mon Jan 03, 2011 11:49 am Post subject: |
RockCrusher wrote: |
You can run those but the cool tins work better...... |
You use those little deflectors with the sleds. cool tins replace them.
You cant use the sleds with the cool tins.
If you're running a thermostat, you need the sleds
GLHTurbo wrote: |
Hey Glenn,
That thread of mine shows a pretty good closeup of parts #3 and #4 of your pic installed
Glenn  Mr. 010
I guess we disagree on that. Cool Tins are Type 3 tins and in my opinion don't cool as well. _________________ Glenn
Member #1009
#BlueSquare
Posted: Mon Jan 03, 2011 11:58 am Post subject: |
Glenn wrote: |
I guess we disagree on that. Cool Tins are Type 3 tins and in my opinion don't cool as well. |
Ok Mr. Smarty pants.....then why do the call the "cool" tins?
I think we can agree to disagree. We (RC) do so many engines that are NOT for sedans that cool tins far outweigh gathering all the little bits and pieces that you still can't use with headers. If I were building anything like a stocker with heat I WOULD NOT use cool tins.  _________________ [email protected] Please use email for all general inquiries.
Glenn  Mr. 010
Posted: Mon Jan 03, 2011 12:05 pm Post subject: |
Back in the 80's JSC (Johnny's Speed and Chrome) bought something like 80,000 of them and started to market them as "Super Cool Tins".
If you're talking about using them on open bay vehicles like Bajas and Dune Buggys then maybe. But on Sedans they do not cool better than the stock Type 1 tins.
Super Cool tins are actually Type 3 tins and are designed to be used with the Type 3 pancake fan shroud.
This has been debated many times and I won't be revisiting that again.
If they work for you then that's just fine and dandy. _________________ Glenn
Member #1009
#BlueSquare
Posted: Mon Jan 03, 2011 12:09 pm Post subject: |
Glenn wrote: |
If they work for you then that's just fine and dandy. |
The smarty pants was supposed to be a joke in case it didn't come off that way...  _________________ [email protected] Please use email for all general inquiries.
Glenn  Mr. 010
Posted: Mon Jan 03, 2011 2:25 pm Post subject: |
The smarty pants was supposed to be a joke in case it didn't come off that way...  |
No harm, no foul....  _________________ Glenn
Member #1009
#BlueSquare
