JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Tue Jan 04, 2011 1:00 am Post subject: Do they ICT's really need the balance tube? |
| I have my carbs off right now and I was thinking about drilling and tapping the intakes for the balance tube. Or just ordering CB performance's intakes with the port already installed. The lazy ass in me just wants bolt them back on and leave it alone. Any thoughts... |
MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1813 Location: Warm and sunny coastal CT
Posted: Tue Jan 04, 2011 8:42 am Post subject: |
Definitely installed the balance tube. Required for dual singles. _________________ Greg
Model Citizen
| johnnypan wrote: |
| I digitize myself in the privacy of my own home. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Tue Jan 04, 2011 10:22 am Post subject: |
Yes!
Stay tuned for the resounding No! from those that don't run them. _________________
| Mitey62 wrote: |
| Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2163 Location: Salt Lake City
Posted: Tue Jan 04, 2011 10:25 am Post subject: |
| Just drill'em, you'll be happy you did. ICT's are a pain to take on and off. |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1064 Location: St. Louis, Mo
Posted: Tue Jan 04, 2011 11:58 am Post subject: |
| wompninja wrote: |
Agreed!
I have the port higher in the throat so i use it to run my svda as well as balance tube. I just used a T...hope this is actually helping my set-up. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
| skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out  |
DavidKvapil Samba Member
Posted: Tue Jan 04, 2011 12:27 pm Post subject: |
Don't run the vacuum advance off that line, you will get full vacuum advance at idle that way as vacuum is high. _________________ '62 Turkis Kombi FOR SALE. Please see my ad. |
Posted: Tue Jan 04, 2011 12:35 pm Post subject: |
| DavidKvapil wrote: |
| Don't run the vacuum advance off that line, you will get full vacuum advance at idle that way as vacuum is high. |
Should the vacum line be run from the port on the base of the carb? And would it only need the vacum from one carb? Possibly the Left side, just because it's closer? |
Posted: Tue Jan 04, 2011 12:47 pm Post subject: |
Yes, just run the vacuum port from the left side carb, and use the port on the carb, that's what it is for. _________________ '62 Turkis Kombi FOR SALE. Please see my ad. |
mharney Samba Member
Posted: Tue Jan 04, 2011 4:35 pm Post subject: |
| The balance tube is not necessary, but it sounds like I am outnumbered. |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Tue Jan 04, 2011 6:16 pm Post subject: |
doesn't the balance tube really only minimize the 2 cylinder idle issue that you get with dual single barrel carbs? _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
Posted: Tue Jan 04, 2011 6:31 pm Post subject: |
No it does a few other exciting things.
- makes you idle in progression unless you modify the carbs
- makes throttle response more soggy down where the balance tube affects things
- makes it easy to be out of adjustment and think you are not
- risks gas condensation in the tubes
- makes extra plumbing available for leaks. |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Tue Jan 04, 2011 8:29 pm Post subject: |
I've never ran duals before, but everyone i've talked to who's ran duals, and installed a balence tube said that they definately make the motor run smoother. a buddy of mine installed one, and it definately smoothed it out.
My guess is that it will mask the fact that the carbs might not be jetted/ adjusted correctly. whatever the reason, it does seem to run better. I was always told to clamp off the tube before adjusting tho, ir it wil be impossible to adjust the carbs correctly. Again, i'm not sure of this as i've never ran duals personally, but an old VW mechanic friend of mine told me this. this is prolly one of those "1000 ways to do something" kind of deals. _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
Posted: Wed Jan 05, 2011 9:40 am Post subject: |
| ^This is exactly what you are supposed to do. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4673 Location: Oklahoma City, OK
Posted: Wed Jan 05, 2011 1:25 pm Post subject: |
| The one advantage to a equalizing tube with single duals is it allows for the use of a vacuum gauge, best way to precision tune unless you have a AFM. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16825 Location: State College, PA
Posted: Wed Jan 05, 2011 1:35 pm Post subject: |
Don't know ICTs, but Kad (single barrels) kits come with them. That being said - I have Kads on 3 engines and until I learned how to really set up the carbs, I can see why people used them. BUT properly synched and adjusted Kads do NOT need a balance tube. Then only thing a little different is that my idle is closer to 1000 RPMS, but I like the responsiveness of the engine better. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Posted: Mon Jan 31, 2011 7:07 pm Post subject: |
| I called Redline Weber and they were actually kinda helpful. They told me the ICT's don't really need the Balance Tube. And after Mharney mentioned the possible problems I got lazy and I put them back on without the balance tube. (Mark is from TN and his vote counts twice) It ran fine like always, But when I upgraded to the Digital Magnaspark Distributor it now needs a vacum. It came with plates to sandwich between the carb and intake, but they fit dual 2-barrels. So Damn, I took them off again. Okay, next question. Should I drill and tap two fittings or one? One for Balance tube and another for the distributor. Or drill one and just T the shit out of it. I don't think I want to T from the balance tube because of condensation and debris. But I dont want to tap the intake twice and cause it to create weak spots. Of course I would tap on opposite sides. Any takers?.... |
Posted: Tue Feb 01, 2011 5:00 am Post subject: |
OK - once again - I dont know ICTS, just Kads. The balance tube on a Kad is below the carb and will only pull manifold vac. This is NOT the signal you want for a vac advance. _________________ D-Dubya Manx clone 1914. Ex wifes car.
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2207 Location: Gardnerville, NV
Posted: Tue Feb 01, 2011 8:08 am Post subject: |
i dont know if the bug world is different but on type 3s its absolutly necessary to run a balance tube between the manis on icts _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4261 Location: San Diego
Posted: Tue Feb 01, 2011 8:12 am Post subject: |
| Quote: |
| on type 3s its absolutly necessary to run a balance tube |
What is your reasoning for this? |
Posted: Tue Feb 01, 2011 8:55 am Post subject: |
| Yeah, I'd like to know too. Why is that? |
