Rear Heater Replacement Checklist
VWeGoBeachNow
VWeGoBeachNow is offline
PostPosted: Tue Jan 11, 2011 2:17 pm    Post subject: Rear Heater Replacement Checklist Reply with quote
So I plan on changing out my old rear heater core with a new one from VC. It says it comes with a bleeder screw and o-ring.
Some questions I have are.
Is the Rear Seat Heater Core Bleeder Valve the same as the bleeder screw?
Should I replace the Rear Seat Heater Core Control Valve and Heater Core Hose Tee as well?
I will be replacing the the o-ring between heater core and control valve too.
Thank You!
88 Wolfsburg Limited Edition Vanagon GL Tin Top
Vesuve Grey underneath cheapo Vesuve Grey paint job
2.1 L
4spd
pioneer1
pioneer1 is offline
PostPosted: Tue Jan 11, 2011 6:09 pm    Post subject: Re: Rear Heater Replacement Checklist Reply with quote
[quote="VWeG
1- Yes
2- not if the control works fine
3-no
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
tschroeder0
tschroeder0 is offline
PostPosted: Tue Jan 11, 2011 6:25 pm    Post subject: Reply with quote
While you're at it replace the T's that the lines come off of, they will be brittle by now (TK sells them) they are another one of those parts that can stop you in your tracks if they break...btw use the correct one's not the one's that can be bought at the FLAPS, trust me I know!
VWeGoBeachNow
PostPosted: Wed Jan 12, 2011 12:46 pm    Post subject: Reply with quote
How many T's do I need to replace? Is the T underneath or inside the car?
How messy is this job? Should I be ready for coolant spilling out?
Thanks to all!!!!
2.1 L
4spd
Wildthings
Wildthings is offline
PostPosted: Wed Jan 12, 2011 1:10 pm    Post subject: Reply with quote
Thanks to all!!!!
There are two tees underneath and yes you are going to loose some coolant.
VWeGoBeachNow
PostPosted: Wed Jan 12, 2011 10:18 pm    Post subject: Reply with quote
Thanks to all!!!!
I couldn't find the 2 tees underneath. Anyone have a picture?
Thanks
2.1 L
4spd
Terry Kay
Banned
Terry Kay is offline
PostPosted: Wed Jan 12, 2011 10:58 pm    Post subject: Reply with quote
The T's are on the passenger side, under the Van, kinda along side the trans--maybe a little behind it.
If you haven't crawled under the Van you aren't gonna see them.
Follow the heater hoses forward from the engine--you'll find them.
T.K.
VWeGoBeachNow
PostPosted: Thu Jan 13, 2011 12:07 pm    Post subject: Reply with quote
Thank You TK Very Happy
It's nice and warm here in so cal so I get a chance to mess around
underneath.
2.1 L
4spd
