Air shock info
Page: 1, 2, 3  Next
airhead22
airhead22 is offline
PostPosted: Tue Jan 25, 2011 7:05 am    Post subject: Air shock info Reply with quote
I searched the forums and couldn't find what I was looking for so I did some research and decided to post it for all to read.
I have a '72 Westy that I have done a number of things to over the years. I have an adj. front beam that gave me some lift, for my camping adventures. I adjusted the rear springplates as much as I could to level her out. She sits pretty good, till I load all my camping crap in the back then she ends up with a saggy rear and NO ONE wants a fat chick with a saggy rear! So I searched the forums with no luck and ventured out on my own and found some shocks that will work.
I had 19 1/8 inches center to center on the shock bolts and I wanted to raise the rear approx 1/2 to 1 inch, of course I am using 12mm bolts.
Here is the web site I used http://www.monroe.com/catalog/documents/08_MountingLengthSheet.pdf
Monroe pt# MA 758 have a compressed measurment of 14.125" , extended measurment of 23.00" and travel 8.875". Now the only draw back is the mounting loop. The inside diameter is 12mm which is great but the loop is approx. 1/2" wider so your upper shock bolt will not work. You will need a 12mm-1.5x120 ( that breaks down like so 12mm diameter - 1.5 thread pitch x 120mm long ) My bolt was 100mm long and only threaded in 1 or 2 mm. There was a lot of crap in the threads so I used a tap to clean 'em up. IMPORTANT... When installing the upper bolt put a heavy flat washer under the bolt head and between the shock and the mount. The washer between the shock and the factory mount will provide a nice gap between the shock and the body. I purchased 100mm long bolts for the bottom as well.
Monroe air shocks were not in stock so I had them crossed over to a Gabriel High Jacker air shock pt#49215. These worked great and lifted the bus with no problem. They advertise they can lift a vehicle with an added 1500lbs. This is just what they advertise. I suggest you use common sense when installing and using air shocks.
I am curently building a small trailer to haul my caming gear in and will use the air shocks for nothing more then to level out rather then carry added weight. I will post some pictures of everything as I progress. Hope this helps anyone looking for air shock info.
tat2ace
tat2ace is offline
PostPosted: Tue Jan 25, 2011 8:55 am    Post subject: Reply with quote
Sounds awesome, I've been thinking air-shocks ever since I got my bus 3 years ago. The reason I didn't is because of the warnings about coil-overs, that they will kill your shock towers. Is it differant than air, do you think? I will greatly anticipate some long-term use feedback.
rsbadura
rsbadura is offline
PostPosted: Tue Jan 25, 2011 9:39 am    Post subject: Reply with quote
I've installed these air shocks with an additional air pressure gauge set from Monroe:
Works fine - level adjust up to 8cm.
As front shocks I've red Koni...
Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools collection
1977_L63H_P27
1977_L63H_P27 is offline
PostPosted: Tue Jan 25, 2011 10:02 am    Post subject: Reply with quote
Did you also have to get different bolts? Or did you find a direct replacement? If you did, we need a part number Wink. Good info people!
busdaddy wrote:
...and try a few chubby ones until you find one you like.
1977 Westfalia P27 Green Bay Bus
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club
rsbadura
rsbadura is offline
PostPosted: Tue Jan 25, 2011 2:39 pm    Post subject: Reply with quote
Oops, yes, I got new bolts from my parts dealer - sorry no part number.
You need only one set - the normal top could be used for the bottom.
Use only high-strength bolts as the original!!!
Monroe air shock set with addional bolts:
additional gauge set:
Rolf-Stephan Badura
2017 VW CrossPolo
airhead22
PostPosted: Tue Jan 25, 2011 5:35 pm    Post subject: Reply with quote
rsbadura: how long have you been using air shocks on your bus and approx what air pressure do you maintain in your shocks.
I plan on keeping the min. of 20psi unloaded and then bumping up to 40psi when loaded. I plan on using these air shocks to assist the suspension rather then replace the suspension.
rsbadura
rsbadura is offline
PostPosted: Wed Jan 26, 2011 1:04 am    Post subject: Reply with quote
I finished the restoration in early August - have a first journey of 2200 miles and some shorter trips and dealy use till the snow in december.
The instruction sheet wrote 1.4 kg/cm2 (20 psi) up to 8 kg/cm2 (110 psi) - as you see on the gauge.
http://www.vw-t2-bulli.de/data/documents/monroe-ride-leveler-19.04.01.72.pdf
http://www.vw-t2-bulli.de/data/documents/monroe-ride-leveler869T-rev-4-04.pdf
Rolf-Stephan Badura
2017 VW CrossPolo
Tuna Tim
Tuna Tim is offline
PostPosted: Thu Jan 27, 2011 2:56 pm    Post subject: Re: Air shock info Reply with quote
Airhead, did you have any difficulties mounting the Gabriels? I am looking at an uninstalled set now, and the diameter of the top half looks like it might hit the body when mounting. Fatter than the Monroes pictured above.
If the garage was heated I would just go out there and swap it in, rather than typing on a warm keyboard.
1974 Bay
CSII
091
Dual 40 Dells
Unilite
Thunderbird Extractor
fusername
fusername is offline
PostPosted: Thu Jan 27, 2011 3:30 pm    Post subject: Reply with quote
I would think a spacer up top could fix that. this is some awesome info. I always feel bad for my CVs cause i have the rear jacked up pretty high, because when i need ground clearence most is generally when i am camping with a lot of gear in the back. If i hadn't already broken off my shock tower twice (and may ore may not have kinda boxed and welded in one of the shocks) i would look into these.
next bus, prolly a good investment tho!
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
airhead22
PostPosted: Sat Feb 12, 2011 10:40 am    Post subject: Reply with quote
I just used a flat washer between the shock tower and the shock itself. After reading other posts I am starting to become concerned with damage to the shock tower. I am only using these to stabilize and raise approx. half an inch or so. I am very satisfied with the way the bus handles with the air shocks. I have not checked the amount of air pressure but it is minimal. I'll keep this thread up to date if I experience any problems with shock towers but damage to the bus is something that I will definetly avoid.
I am not sure if anyone has ever paid any attention to a semi truck. On the back of the cab they have very small air bags mounted between the truck frame and the cab to absorb shock and vibration.
I wonder if you could replace your bump stops with a small air bag like these. Not so you can dramatically adjust your ride height but rather a way to make subtle adjustments to ride height and keep a good shock such as a KYB gas-a-just on the rear. I know sone fabrication will be required but its an idea.
The reason why I chose to use air shocks is because I tried to adjust my spring plates many times. The problem that I am experiencing is after I get the proper angle on the springplate I can slide it up the the torsion tube and then I have to lift it up with a jack to get it inside. When I lift it up there is to much tension and the spring plate will no longer slide. Tried to hammer but stopped when damage occured to the metal. Thought about trimmin off the stop off the torsion tube to get the spring plate to slide all the way in but thought that might not be the best way to solve a problem.
devesvws
devesvws is offline
PostPosted: Sat Feb 12, 2011 11:02 am    Post subject: Reply with quote
i remember the day that a pair of hijackers air shocks was the thing you had to have. the hijacker rabbit sticker was a big deal too. wow have not thought of them in years.
THE FEW THE PROUD THE ORIGINAL VW WATERBOXER -> looking for a original 91 vanagon owners manual with 1991 on the cover http://www.youtube.com/watch?v=pmuiG2tUsP4&feature=share https://picasaweb.google.com/101290228103300323836/BostonBobFlywheelVideo#5543000332201103922
porn king
porn king is offline
PostPosted: Tue Mar 29, 2011 2:16 pm    Post subject: Air ride rear Reply with quote
Are you still using your air shocks on the rear ?
lonewolfone
lonewolfone is offline
PostPosted: Fri May 18, 2012 2:14 pm    Post subject: Reply with quote
Old topic, but installed air shocks on the rear of my sunroof bus. Someone said you could get bolts at a parts house but I was unable to find any. Found a part number for an Audi binder n 909 242 02, its a m12x1.5- 120 mm perfect for the upper shock mount as the bushings are slightly longer than the originals. So I'd your wanting to install some on your bus I figured I would share my info for others.
63 bug "black beauty"
79 bus "sunny" (sold)
76 westy tdi swapping
65 sundial "trailer special"
75 riviera "red rocket "
Volksfreak62
Volksfreak62 is offline
PostPosted: Thu Oct 10, 2013 8:14 pm    Post subject: More on the Air Shock Topic! Reply with quote
If anyone is interested I can put a step by step kit together for one fair price if you are interested, please e-mail me for questions or concerns, or comments. Kris
68 Bayfer
68 Bayfer is offline
PostPosted: Mon Sep 14, 2015 6:09 am    Post subject: Reply with quote
Where did you purchase the Bolts? I am having no luck finding that length with enough thread.
Tcash
Tcash is offline
PostPosted: Mon Sep 14, 2015 8:02 am    Post subject: Reply with quote
https://www.google.com/webhp?sourceid=chrome-insta...20242%2002
rottenkid
rottenkid is offline
PostPosted: Tue Nov 17, 2015 9:43 am    Post subject: Re: Air shock info Reply with quote
Does anyone have pictures to show where you ran your air lines into the engine compartment . Do you need to have the engine out in order to get the lines into the engine area? I have the shocks mounted on my 1978 VW bus. I just would like to know if there is an easy way to get the lines into the engine compartment.
levi20AE
levi20AE is offline
PostPosted: Sat Jan 09, 2016 10:02 pm    Post subject: Re: Air shock info Reply with quote
Installed a set of Gabriel's today. With the additional 12x1.50 - 120 bolt mentioned above it was straightforward.
1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs
View user's profile Send private message Instagram Classifieds Feedback
LivinInnaVWBus
LivinInnaVWBus is offline
PostPosted: Sun Jan 10, 2016 5:20 pm    Post subject: Re: Air shock info Reply with quote
What PSI did you put in them?
rottenkid
PostPosted: Sun Jan 10, 2016 7:45 pm    Post subject: Re: Air shock info Reply with quote
I put 40 psi in mine, but I have not tried the bus out since installing them. I just did that to make sure there are no leaks. I have to wait for spring to do a road test. I will reduce them to 30 psi for the road test. They are the same shocks as on my Astro van. I leave the Astro van shocks at 30psi. The Astro van rides nice with air shocks so I'm hoping my bus rides the same.
Page: 1, 2, 3  Next
