SA and IRS guys. How have you mounted your rear shocks?
Lowdown Dirty Rat
Lowdown Dirty Rat is offline
PostPosted: Fri Jan 28, 2011 1:21 pm    Post subject: SA and IRS guys. How have you mounted your rear shocks? Reply with quote
Would like some pics and descriptions of various setups to look at the options.
Cheers
Concept1
Concept1 is offline
PostPosted: Fri Jan 28, 2011 2:15 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=380453
Page 19.
I would assume something similar would work on an IRS set up as well.
C-1
Lowdown Dirty Rat
PostPosted: Fri Jan 28, 2011 4:36 pm    Post subject: Reply with quote
Dude that is a nice setup. Would be a shame to not use those old shock mounts.
Lowdown Dirty Rat
PostPosted: Fri Jan 28, 2011 5:52 pm    Post subject: Reply with quote
The KCW singlecab
http://www.kustomcoachwerks.com/gallery/main.php?g...alNumber=1
Jacks
Jacks is offline
PostPosted: Fri Jan 28, 2011 10:59 pm    Post subject: Reply with quote
I really like the kwc mount but the shock travel looks to be about 1" to 1 1/2", while the spring plate range is 3" to 4".
Franz
Franz is offline
PostPosted: Sat Jan 29, 2011 7:25 pm    Post subject: Reply with quote
Any good IRS pictures out there?
https://www.vervemotorworks.com/
Lowdown Dirty Rat
PostPosted: Sun Jan 30, 2011 2:13 am    Post subject: Reply with quote
Pics guys? You'd think there were only stock buses out there.
Here's another SA, not the best pic. It's from that super low Japanese bus.
The more usual method. Just weld on a mount to the chassis legs.
mr. warehouse
mr. warehouse is offline
PostPosted: Tue Feb 08, 2011 12:43 pm    Post subject: Reply with quote
I just did a run of those upper shock mounts...I copied an original Split window bug piece.
That's what I use.
Blauhaus
Blauhaus is offline
PostPosted: Tue Feb 08, 2011 1:41 pm    Post subject: Reply with quote
Very sweet Greg!
www.blau-haus.com
QUALITY CLOTHING. PRODUKTS. FÜR THE PEOPLE.
** WANTED **
Haines VW dealership (Sacramento) license frame
mr. warehouse
PostPosted: Tue Feb 08, 2011 1:56 pm    Post subject: Reply with quote
Blauhaus wrote:
Very sweet Greg!
Thanks, I can make them longer for barndoors if needed. Also working on the lower mounts for non lower shock mounts trans (early split / pre-a / barndoor) I'll be making them "stock" and longer.
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Tue Feb 08, 2011 6:27 pm    Post subject: Reply with quote
Those ends where the shocks mount don't seem very stout... They look good though
mr. warehouse
PostPosted: Tue Feb 08, 2011 10:37 pm    Post subject: Reply with quote
Copied from an original. Same dimensions same thickness metal, etc.
More on that in the split section here...
http://www.thesamba.com/vw/forum/viewtopic.php?t=449796
BulletBus
BulletBus is offline
PostPosted: Fri Feb 11, 2011 8:08 am    Post subject: Reply with quote
Will the new, longer ones enable me to replace my lever shocks on a stock barndoor setup with regular shocks? If so, I have a set of levers if someone wants them once these are on.
53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen.
mr. warehouse
PostPosted: Fri Feb 11, 2011 11:20 am    Post subject: Reply with quote
If it's not lowered you don't need longer ones. The above upper mounts and a set of triangle mounts for the bottom will do the trick.
I should have the lower mounts done next week sometime.
joe56vw
joe56vw is offline
PostPosted: Fri Feb 11, 2011 12:12 pm    Post subject: Reply with quote
will those work on newer buses with narrowed rear end or those offset springplates?
and how much are they going to be sold for?
'60 15 window walkthrough
why is there no sarcasism button on here?
mr. warehouse
PostPosted: Fri Feb 11, 2011 2:46 pm    Post subject: Reply with quote
With enough determination and fabrication anything can be made to work.
These however are made to bolt on through the existing lever shock holes and the triangles bolt on through the axle / spring plate holes.
I've used the upper mounts in early cars running later transaxle's that have lower shock mounts as well. Works very good.
As for a price, the uppers run $150 a set, not sure on the lowers. There will of course be a package price if they are bought together.
barnduude
barnduude is offline
PostPosted: Mon Feb 14, 2011 2:01 pm    Post subject: Reply with quote
alo,
here is how i did it Cool
there are others pics in my gallery
grtz to all.
www.everyoneweb.com/luftwaffenracing
'54 BD kombi.
'68 APAL samtrack.
hell is empty, all devils are here.
