Twin Plug Dual distributor build
Page: 1, 2, 3 ... 10, 11, 12  Next
Ninamashr
Location: City of Round Rock in the Great State of Texas
Ninamashr is offline
PostPosted: Tue Feb 15, 2011 1:01 pm    Post subject: Twin Plug Dual distributor build Reply with quote
I've decided to run twin plugs on my 36'er. Obviously I'll need to get a hold of a dual dist. Since all the ones I've seen are too modern looking I've decide to make my own drive.
My plans are to make it out of 2 blocks of 6061 aluminum, use two modified "019" dizzy's to fit the drive. It will be a sidewinder style with one shaft driving the other off-set to one side, gear driven, with oil lubrication taken from the engine.
Day one.. Preliminary housing machining
Here are the gears sized up in the housing
Once the cover is done, i'll post an update. This is gonna be fun Very Happy
1957 Karmann Kabriolet "Franky"
1957 Allstate trailer
grueni
grueni is offline
PostPosted: Tue Feb 15, 2011 1:08 pm    Post subject: Reply with quote
beautiful!
i will also go twin plug but dizziLESS. when i see this i wish go back to dizzi Wink
will watch this beauty with interrest.
i think you will not need the oiling from engine. do it like roots blowers, just its own oil. and it will drive "only" half engine speed. my spercharger drive 3,2 time engine speed with own chamber for oil.
have fun with it.
1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile )
Ninamashr
PostPosted: Tue Feb 15, 2011 1:41 pm    Post subject: Reply with quote
have fun with it.
So how fast would you estimate the dist shaft to rotate on the engine? The gears I am using recommend that I use use a lighter viscosity oil the faster they spin. I am also concerned with removing heat from the gears so I plan on having the oil exit and drop back down into the case.
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Tue Feb 15, 2011 2:13 pm    Post subject: Reply with quote
Very Happy
You might want to check with shieldsj. I believe he has a dual distributor setup.
Precission Matters makes a dual ignition setup for 356's. Here's a pic of the insides.
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Last edited by gimmesomeshelter on Tue Feb 15, 2011 2:24 pm; edited 1 time in total
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Feb 15, 2011 2:16 pm    Post subject: Reply with quote
Bosch made a dual distributor back in the 60's
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
grueni
grueni is offline
PostPosted: Tue Feb 15, 2011 2:19 pm    Post subject: Reply with quote
you can do it this way. but the 1/2 rpm of engine speed of the dizzy with nearly no load will not make that much heat. the chamber for the 3 gears is big enough and via the rotating there will be oil all over.
just a question. why using 3 gears and not 2? space?
Ninamashr
PostPosted: Tue Feb 15, 2011 2:29 pm    Post subject: Reply with quote
gimmesomeshelter wrote:
Very Happy
Paul
I already spoke to Jim. His setup is very different than mine and I'm not at liberty to tell anyone how he made his. Very Happy
Ninamashr
PostPosted: Tue Feb 15, 2011 2:36 pm    Post subject: Reply with quote
I'd love to see a pic , BTW, I'll be cutting down two 019 dists, close your eyes Glenn. Laughing
Ninamashr
PostPosted: Tue Feb 15, 2011 2:50 pm    Post subject: Reply with quote
So the dist shaft rotates at half the engine speed? If that's true then lubricating with some thin oil should work.
I am using 3 gears because I need both dist shafts to turn in the same direction. The center gear will turn the outside gear in the right direction.
earthquake
earthquake is offline
PostPosted: Tue Feb 15, 2011 2:54 pm    Post subject: Reply with quote
Ninamashr
Have you thought just adapting a cap from a Nissan Nap-Z motor from the 80's they were twin plug? I think ford had a twin plug 2.3 in the ranger pickup that might have a cap to adapt as well.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
Ninamashr
PostPosted: Tue Feb 15, 2011 3:02 pm    Post subject: Reply with quote
Casey, I thought about that option, but, I preferred the vintage speed look of twin 019's on a 36er.
Ninamashr
PostPosted: Tue Feb 15, 2011 3:09 pm    Post subject: Reply with quote
Very Happy
Paul
That's an awesome setup for dual carbs, but, but I have one major problem. I am running 3 carbs and that setup would place one dizzy right underneath the throttle arm on the center carb causing interference, so I couldn't accelerate.
anmilsurp
anmilsurp is offline
PostPosted: Tue Feb 15, 2011 5:43 pm    Post subject: Reply with quote
What's the number and parts supplier of the gears? Are they keyed or just set screw attached?
Low Bräu
Low Bräu is offline
PostPosted: Tue Feb 15, 2011 6:06 pm    Post subject: Reply with quote
Looks great but how much is this baby going to weigh? I don't know what your goal is with this engine but I can only assume you're trying to squeeze the most HP out of an engine that doesn't produce much power to begin with. Now you're turning three large gears in an oil bath to only to rotate a rotor that should spin with little to no resistance. I know the power loss is minimal but then so is the output of a 36hp motor. Free up hp by making things move with less resistance and less weight. Consider what porsche did with the 964 twin plug. They had a sealed bearing and a rubber drive belt. Just my thoughts. Keep the pics coming, your craftsmanship looks great!
Ninamashr
PostPosted: Tue Feb 15, 2011 7:49 pm    Post subject: Reply with quote
I'm not sure how much it will weigh? I'll check once I am done, My guess is about 3 lbs? My goal is to have all my other components ready and tested before I start rebuilding an true oldspeed engine. I have other plans for better cooling, and a better intake system, etc;. I'll post those up in a month or so. What Porsche did with the 964 looks pretty reasonable but with any rubber timing belt you have the issue of the belt stretching so the timing will eventually be off. With properly lubricated gears I don't think that will be a problem plus with this setup I can adjust exactly when I want the spark to come on for the second plug in the cylinder. I'll be able to overlap the timing so the spark burns longer and more fuel gets used instead of being wasted. It's gonna involve some engineering, but, I knew that coming in.
Ninamashr
PostPosted: Tue Feb 15, 2011 7:51 pm    Post subject: Reply with quote
Anmil, The outside gears are going to be pinned, like the gear drive coupler on a normal dist, to their respective shafts, the center gear will spin on a pressed pin shaft and be held in place with an "E" clip and bronze bushings. I got the gears from SDPI (Stock Drive Products Inc) I'll post up the p/n's when I get in tomorrow.
Mr. 010
Glenn is offline
PostPosted: Tue Feb 15, 2011 7:57 pm    Post subject: Reply with quote
If you want i have a few bodies that are broken at the o-ring if you want.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Ninamashr
PostPosted: Tue Feb 15, 2011 8:05 pm    Post subject: Reply with quote
Thanks Glenn, that's not a bad idea, but, I'll still need the rest of the dizzy. Wink It felt kind of wierd cutting up 2 perfectly running 019's right above the O-ring groove. Shocked Here's a blank I made. It's the part that will pop into the case and will be welded to the bottom of the Dual Dist housing...
Glenn You can probrably identify this part, it's whats left when you press out the advance plate off an old 009 dist. I will be using it to extend the drive shaft of the main drive dist.
Ninamashr
PostPosted: Wed Feb 16, 2011 10:33 am    Post subject: Reply with quote
The lid is complete, time to move on to the base and extending the shaft
Blauhaus
Blauhaus is offline
PostPosted: Wed Feb 16, 2011 10:50 am    Post subject: Reply with quote
Beautiful machine work and thinking. Tuned in to see your progress!
www.blau-haus.com
QUALITY CLOTHING. PRODUKTS. FÜR THE PEOPLE.
** WANTED **
Haines VW dealership (Sacramento) license frame
Page 1 of 12
