syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12422 Location: Santa Cruz, CA
Posted: Fri Feb 18, 2011 3:28 pm Post subject: |
| Quote: |
| Grille is from indicator to indicator, replacing the original grille under |
Google translator- no biloba needed. |
BenT Syncro Samba Member
Joined: January 07, 2005 Posts: 1088 Location: San Francisco
Posted: Fri Feb 18, 2011 4:31 pm Post subject: |
| syncrodoka wrote: |
| Quote: |
I'm already translating my thoughts into Engarish then you want translate again?! That's too much work to do on my phone especially when you're driving through the snow covered highway without your Syncro.
Since you forced me to risk the lives of everyone onboard, I looked at the site with Babelfish. Nice to know that the €390 price includes a new SA lower grill. Well, they don't actually say 'SA' but I don't think anyone else is making that grill.
BenT |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Fri Feb 18, 2011 6:34 pm Post subject: |
| BenT Syncro wrote: |
Note that on their detail shot, it appears their kit is designed to fit the SA lower grill. I could be mistaken but the original (shorter) lower grill does not extend that far.
If I understand them correct, they sell the entire lower grill, with fog lights included for 390 euro. Still a lot of money, but not so bad considering they charge you 170 euro for an ordinary SA-grille. _________________ 1991 VW Multivan syncro 1,9 TD |
88formula Samba Member
Posted: Mon Feb 21, 2011 2:24 pm Post subject: |
| they look good, but i still want to put something in the holes at the bottom of the bumper. do you know a company that builds a quality set that will fit? |
Posted: Tue Feb 22, 2011 9:22 am Post subject: |
I found this.
http://www.streetglow.com/Xenon-Fog-Lights-SG-797-CH?sc=2&category=5448
They fit in the holes.
Kill 2 birds with one stone, fog and driving in one unit.
My "accent lighting" and new curtains will be blue, so they fit in there.
But apparently the lenses are crap, and crack when they get wet. This must be because of the heat from BOTH lights on at the same time. And I plan on putting 100w bulbs in. That would probably melt that cheep glass right off.
Anybody know of somthing similar? |
Posted: Tue Feb 22, 2011 5:47 pm Post subject: |
bump?  |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10356 Location: N. Idaho
Posted: Tue Feb 22, 2011 6:22 pm Post subject: |
88,
I've got to be straight with you here and perhaps others are feeling the same way. The lights you found and posted indicate you're really just looking for lights for style. If that's what you're looking for then you need to say so. For automotive illumination the lights you posted are junk. Pure junk. And when I think of someone planning to put 100w bulbs in who's looking for this type/quality of light, I dunno - just sounds like I'd be encouraging another annoying vehicle on the road with overpowered cheap crap lights. The roads need another setup like this like we need a hole in the head. I'd urge you to either get quality lights, or buy cheap crap blue lights and leave the stock bulbs in them.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
randywebb Samba Member
Posted: Tue Feb 22, 2011 6:48 pm Post subject: |
I've always wondered how good the flat high beam units in the SA Grill kits are for distance illumination... _________________ 1986 2.1L Westy 2wd Auto Trans. |
1621 Samba Member
Posted: Tue Feb 22, 2011 7:08 pm Post subject: |
I'm in agreement with Doug, those lights are crap. Reading the two user reviews even say as much. Bulb heats up the glass, water splashes on it and the glass is toast. No replacement glass either. Not worth the time and $80.
Like several others have pointed out, mounting the lights low invites all sorts of road debris impacts - even with lift springs and protective coverings. You're also very limited in what you'll find with the 6x2" requirement. Even when you do find something appropriate size wise, the light quality will likely not be worth it. I understand what you're trying to do, just pointing these things out based upon my own previous experience.
I spent 20 minutes looking around the Internet at reputable manufacturer sites and found only one Hella light that might work (FF75, though still a little tall for that spot). If you're open to above the bumper it will open up so many more options. I like Cibie lighting, but some of the others recommended by Doug early in this thread are worth a try. Not trying to be a dick, just would hate to see you waste money on crap that will get destroyed on a tall curb. _________________ '85 Westy |
Posted: Tue Feb 22, 2011 7:13 pm Post subject: |
I guess I should also chime in to say that I'm also not trying to be a dick (heh). There is quality automotive lighting, and there's "other stuff". I'm trying to keep you away from the other stuff. It's worth noting that most people have never driven behind a set of quality lamps. Once you have experienced this, I'd think it hard to move back down to the other stuff. Ironically, the other stuff is often priced at or above the price for quality lamps.
Posted: Tue Feb 22, 2011 7:19 pm Post subject: |
These are what I am running.
Not what you are asking about but very durable and good light output. |
rfoubi Samba Member
Joined: March 21, 2004 Posts: 224 Location: Rossland BC
Posted: Tue Feb 22, 2011 7:21 pm Post subject: |
So I'm not even going to get into the debate of "real lights" vs crap. Whatever, it's your van do what you want, someones always gonna have something bad to say about it. Anyway as far as factory ish look, this is what I did on my rig.
I just cut out the lower grill and built a little mini light bar out of angle stock aluminum to bolt the lights to. I like the look, they are out of the way, look like they could be stock but yet look unique. And I went with shitty lights. Well they may or may not be but I just bought 60 dollar lights at Canadian tire and they throw lots of light, are aimed properly and light up the logging roads nicely at night. Less than 80 bucks for everything and they've been on there 5 + years. |
kamzcab86 Samba Moderator
Posted: Tue Feb 22, 2011 7:38 pm Post subject: |
O...M...G...
MUST... HAVE!! Darn you for posting that link, and darn my van for already having bumper-mounted lights, and darn that thing being so expensive and an ocean away!
I can only speak from experience with my Cabriolet. My Cabriolet came with below-the-bumper-mounted fog lights (back when fog lights were amber!), which were at about the same height as the Vanagon's spoiler, maybe a bit lower. They had very thick glass in them and were destroyed by rocks and de-icing cinders; one blasted a hole right through one of them (didn't really care because I was going to remove them anyway). I'd be wary of mounting lights below the bumper on a vehicle that's used for outdoor adventures like a Vanagon. The spoiler on mine has seen its share of abuse over the years; I honestly can't imagine putting lights in/on/below/in front of it unless it's purely for aesthetics. My 2 pennies' worth. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Tue Feb 22, 2011 9:56 pm Post subject: |
| 88formula wrote: |
oh and as for "being a cock", i live in red deer Alberta. there is more of a white bread, red neck % of our population than any other place in most of north America, and all of these rig pigs have nothing they love to spend there money on more that there 12"+ lift kit, 26" mud slinging tires, with no less than 8, 10" hid "blistering blue" lamps anywhere and everywhere on these trucks with there "low beams" pointed right in your eye. there is some kind of subconscious competition going on here. and i am not a part of it. i just want adequate light as i drive off highway quite often to get to my family. and there is NO sunlight left at 5 o clock in the winter.
just in case anybody forgot.
i never said i was buying them, i was only showing them. both piaa and hella are reputable lamp manufacturers, and they both make dual beam lamps. BUT so far ive yet to find some that will work.
im not afraid of them being damaged under the bumper. im sure they will last quite some time, the way i think about it is like this. how many times has a passenger freaked out thinking you were going to run into someone or something because they don't understand how close the front bumper actual is to there feet! my girlfriend hasn't been able to park closer than 2 feet to a wall/barrier ext. curbs are the least of my worrys. and rock damage is a far shot for me. the speed limit on highway 2 is 110, and the average speed is actually closer to 130. i wont be tailgating anyone with my 2.1 vw. besides, i take the less traveled 2a were the speed limit is lower, so its not nearly as much traffic. when i go to the mountains, i like the scenic rout of highway 1a same thing. used to be Trans Canada, now its barely traveled on except for locals.
and i WILL be putting 100w bulbs in them, but don't worry Doug, i wont be in Idaho anytime....ever. besides, if your ever in alberta, youll know my frustration. |
Posted: Tue Feb 22, 2011 11:33 pm Post subject: |
88,
I give man, I give. You rant about folks with excessively bright blue lights in your area and how you're "not part of that" then bring up and link blue lights and insist you're putting 100w bulbs in whatever you get. Huh?
I think you chose the location for the lights and simply cannot let go of that decision. And don't get me started that those holes were intended to ensure proper air flow gets to the front disc brakes due to the air flow change of the spoiler. I'm sure you've got a good reason for that as well and I can't wait to hear it.
Anyhow, it's all good. Room on the roads for another set of too-bright blue lights, I guess - even here in Idaho.
rfoubi Samba Member
Posted: Wed Feb 23, 2011 5:38 am Post subject: |
| As far as under the bumper goes, personally I drive off road too much to consider it, but if you are just using it for normal use what you have to worry about with the lower mounting point is not hitting them on stuff, but rather rocks/gravel smashing them. Get too close to one by rig or snow plow and smash there goes your investment. I've had great success with th rockblocker style vinyl like clear plastic Light overlays. My first set of fogs got smashed within months due to the boulders they like to sand the road with here in Bc. After that I bought a sheet of the film, cut it put it on and no problems. Just a thouht |
OddN Samba Member
Posted: Wed Feb 23, 2011 7:18 am Post subject: |
| 88formula wrote: |
I found this.
Just ask any BMW owner what they think about the low position foglights. It just takes one small puddle on the road and one splash of water to crack the lights if you drive with them on. If you insist on having lights under your bumper, and use them as driving lights, at least go for some hi quality LED's like Hella. _________________ 1991 VW Multivan syncro 1,9 TD |
kjurkic Samba Member
Joined: January 20, 2011 Posts: 14 Location: Vancouver Island
Posted: Wed Feb 23, 2011 12:00 pm Post subject: Aux Lights - Location is important |
Howdy all
It has been my experience, with many vehicles in often extreme conditions, that a good rule-of-thumb is "the higher the better".
Low-mounted lights have the drawback of not reaching very far when the road is anything other than dead-flat. It is also annoying to drop $$ for the good quality lamps, just to lose a lens to a stray rock or curb.
I also have a rally/daily car that I drive regularly at night, in craptacular weather. I moved the 4x100W driving lights off the front rack that came with the car, and bolted them to the roof. This improved the lighting so much that I have been using my 6" round driving lights even in heavy fog/rain/snow, as I don't get the blinding "light blob" just in front of the car.
On a westy, I would consider recessing them in the front fascia of the roof; for my Vanagon, I have been looking for some cargo basket or even an emergency light rig & replace the flashers with driving & fogs. It will not do wonders for the appearance, but if seeing where you are going is the primary concern, then mount them high is what I say.
[img]
fender-proto-02 by kjurkic, on Flickr[/img]
regards
Ken
PS I cannot speak for your jurisdiction, but in my area the police have never pulled my over or otherwise bothered me about these. This car is a daily driver. |
IrideWheelies Samba Member
Joined: July 09, 2009 Posts: 386 Location: Olympia, WA
Posted: Wed Feb 23, 2011 6:32 pm Post subject: |
kjurkic,
When you use the roof mounted lights in fog don't they illuminate all the fog in front of your windshield?
I always thought roof mount lights would be bad in fog or dust because the helmet mounted lights I use for night mountain biking are. I can hardly see through the beam if I use a bright helmet light in fog or dust while the same light on my handlebar works great in those conditions. _________________ 89' Dove Blue Syncro Hightop |
Posted: Wed Feb 23, 2011 6:48 pm Post subject: |
Roof lights are generally subject to causing a lot of light blowback because they light a cone of dust up close to your eyes and directly in line with your line of sight (vs a light several feet below your line of sight like a bumper mounted light). They also are apt to light up the hood - again a source of light in the driver's view. The rally vehicle shown has them wisely mounted back on the roof to avoid lighting the hood.
Funny you mtn bike at night - teaches some fast lessons about vehicle illumination, eh? I also ride and race mtn bikes at night.
Anyhow, vehicle roof lights would generally be a bad idea for poor visibility conditions unless you're in a place where you can fire merciless amounts of light forward so being dazzled is less of an issue - such as racing. A vehicle on a public roadway with roof lights would be less effective.
