Explain the 'Breather Box'
FireBug1966
FireBug1966 is offline
PostPosted: Sun Oct 01, 2006 6:06 am    Post subject: Explain the 'Breather Box' Reply with quote
I'm still learning, I'm at the "suck-squeeze-bang-wheez" level of understanding engines...so bare with me.
What is the deal breather boxes? What do they do? When should you consider getting one?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Oct 01, 2006 6:13 am    Post subject: Reply with quote
Larger engine create more internal pressure. It has to get out somewhere. If you do nothing it will push its way out along with some oil. If you vent the valve covers and case it will have a controled way to exit.
Personally, I like like breathers where the oil drains back to the engine.
I have a Berg Breather/oil fill tower and it gives a nice clean look along with keeping the engine clean.
Worn piston rings will also cause excessive internal pressure, so make sure that's not the cause.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
vwracerdave
vwracerdave is offline
PostPosted: Sun Oct 01, 2006 6:17 am    Post subject: Reply with quote
As the pistons travel back and forth they create a turbulence inside the engine. The larger the engine, or the faster the engine spins, the more air pressure is created inside the engine. A breather system is just a few extra holes in the engine with a simple filter to allow this air pressure to escape and enter. Because of the oil inside the engine, you must have a way to catch the oil so it doesn't blow out of the engine, and filter the dirt out of the air before it enters the engine.
Breather boxes are not necessary until you go above a 1776cc engine or start turning over 5000 RPM.
(Glenn can type faster then I can)
volksfiend
volksfiend is offline
PostPosted: Sun Oct 01, 2006 7:06 am    Post subject: Reply with quote
Unless, of course, you run a sand sealed pulley. In that case you will have restricted one of the engines natural sources of air flow, and must therefore compensate with a breather. I, personally, do this to all my engines as I would rather the air entering the crankcase be filtered.
View user's profile Send private message AIM Address Yahoo Messenger Classifieds Feedback
FireBug1966
PostPosted: Sun Oct 01, 2006 12:06 pm    Post subject: Reply with quote
Thanks for the info.
And...the box helps catch any oil that's purged...and that oil is simply returned by gravity (?). So you need to mount the box above the point where you vent the engine (?).
Mr. 010
Glenn is offline
PostPosted: Sun Oct 01, 2006 1:16 pm    Post subject: Reply with quote
Not all breathers return the oil to the engine. Many are just a puke can and it sits there.
I have a Berg breather and it mounts to the oil fill.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bugman Jeff
Bugman Jeff is offline
PostPosted: Sun Oct 01, 2006 3:45 pm    Post subject: Reply with quote
If you have old worn out rings, and you run 15 PSI of boost, and your breather system is inadiquate, there is enough pressure in the crankcase to blow the valve covers off the heads and dump all your oil all over the ground. Go ahead, ask me how I know... Rolling Eyes
Restorer of Porsche Speedster 80486 Smile
grimace007
grimace007 is offline
PostPosted: Sun Oct 01, 2006 3:47 pm    Post subject: Reply with quote
... sounds like how i know not to test a 500horse 383 stroker that you jus put into your camaro without installing the new solid tranny mounts.. not even for a quick test spin.. Idea
billy1ear
billy1ear is offline
PostPosted: Sat Oct 07, 2006 6:41 pm    Post subject: Reply with quote
Glenn, where do you have the hoses for your breather box going? Valve cover? Carbs?
I just put my foot in mine today and saw smoke coming from the engine, not the exhaust. So I started researching breather boxes.
Mr. 010
Glenn is offline
PostPosted: Sat Oct 07, 2006 6:45 pm    Post subject: Reply with quote
Both valve covers and to a filter.
Not to the carbs.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
beans66
beans66 is offline
PostPosted: Sat Oct 07, 2006 9:45 pm    Post subject: Reply with quote
Do you have to run the breather box or an I just use some small valve cover filter I have off of say a v8 valve cover?
"Could be worse, Could be addicted to dick."
"I just found out my car is a "HE" How many gurls you know like to be stroked and blown?"
View user's profile Send private message Visit poster's website AIM Address Classifieds Feedback
billy1ear
PostPosted: Sun Oct 08, 2006 8:02 am    Post subject: Reply with quote
Looked at bergs oil filler breather box and saw it was $200+, lots of dough.
Saw cb performance had ripped off their idea in cast alum for $30+ . Was wondering if anyone has tried it?
http://www.cbperformance.com/catalog.asp?ProductID=241
Also was thinking about how to route the hoses from the valve covers. Where do you put the hose bibs in the valve covers (towards front, back, middle) and which way to route the hoses?
68Bug-lite
68Bug-lite is offline
PostPosted: Sun Oct 08, 2006 8:37 am    Post subject: Reply with quote
Check out this thread...
http://www.thesamba.com/vw/forum/viewtopic.php?t=137067&highlight=breather+box
fluxcap
fluxcap is offline
PostPosted: Thu Mar 03, 2011 5:02 am    Post subject: Reply with quote
Hi everyone, I've been reading up on breather set-ups for a few weeks now, and have found about a million different opinions. Found this quote above and have a few questions.
I have a very mild 1776 that hardly ever sees above 3200rpm. I'm currently running a single 34pict3 with a 1966 oil bath cleaner. Currently have the breather hose from the oil filler to oil bath. I'm going to be installing a set of Weber 34 ICTs fairly soon and have a few questions about what to do for breathing/venting.
Going by the quote above, if a breather box is not neccessary, what are my other options? I have the CB kit with the oval shaped filters (not the cone filters). Neither of these have any kind of fitting for a breather hose. I'm really trying to keep the engine compartment simple and clean without installing much else. Of course, functionality is more important than looks though so I'm open to all suggestions.
Should I put a fitting on the passenger side air cleaner, and just run one hose from the filler to that cleaner? I've read some people say this is OK, while others say it will gunk up the carb. Or will a breather box be necessary? If a box is necessary, do I have to run additional hoses to each valve cover or would just one valve cover do?
Currently not noticing any blow-by or oil seepage around the pulley.
Thanks for any ideas!
Eric
Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black."
vwracerdave
PostPosted: Thu Mar 03, 2011 5:23 am    Post subject: Reply with quote
All you should need is a cheep $8 mini air filter with a 1/2" connecton and put it on your stock oil filler vent. http://www.cbperformance.com/catalog.asp?ProductID=245
fluxcap
fluxcap is offline
PostPosted: Thu Mar 03, 2011 5:56 am    Post subject: Reply with quote
Great! I'll pick one of these up for it then. Thanks!
RailBoy
RailBoy is offline
PostPosted: Thu Mar 03, 2011 6:07 am    Post subject: Explain the 'Breather Box' Reply with quote
FluxCap, here is a view of a Remote Breather Box mounted on my Rail's Engine. It is not the best photo but you can see it is mounted high on the shroud with a return hose back to the engine breather at the Oil Cap. This allows oil to drain back into the engine via gravity. Also, there are two hoses that go to the top of the valve covers that oil and air can travel up, at the same time, gravity again can allow oil to drain back into the valve covers at lower RPMs......
*Note, the black hose from the breather box on the passenger side going down the side of the engine is going to the valve cover that is not in view....
Also, the breather box acts as a small catch can were as access oil drains back into the case as explained, in most of the style breather boxes are air filters so air can pass through the top of them not allowing impurities into the oil system, nor case.....
RB
jay64
jay64 is offline
PostPosted: Thu Mar 03, 2011 7:58 am    Post subject: Reply with quote
"Breather boxes are not necessary until you go above a 1776cc engine or start turning over 5000 RPM."
I have a 1600 in my 76 and it"s ring are not worn but if I get it going on the highway at 65 plus mph it will blow oil everywhere, around town no problems.
fluxcap
fluxcap is offline
PostPosted: Thu Mar 03, 2011 8:43 am    Post subject: Reply with quote
Thanks for the pics and info RB, and Jay, that is what I'm afraid of. I do a good bit of interstate driving, usually keeping it around 65-68mph. I guess I can try the filter first, but if I get oil spewing out of it, I'll have to go to a box. Just trying to keep it simple in the engine compartment and didn't really want to mess with routing hoses and putting fittings in the valve covers if I didn't have to.
jay64
jay64 is offline
PostPosted: Thu Mar 03, 2011 9:29 am    Post subject: Reply with quote
I'm going to put a breather box on it because I'm going to be building a 2110 for it anyway.
'76 BUG 2054cc
