Chirping sound
rdk_1973
rdk_1973 is offline
PostPosted: Sat Mar 19, 2011 9:42 am    Post subject: Chirping sound Reply with quote
My split runs fine, but sometimes I hear some kind of chirping sound from the back. It's sounds like a small bird is in the back, but I when I look it's never there. The sound is almost gone when running idle or revving the engine a little bit in neutral, so I only hear while driving. Anyone know what could be wrong?
overrestored
overrestored is offline
PostPosted: Sat Mar 19, 2011 10:58 am    Post subject: Reply with quote
Probably is some loose bit of engine tin... where the engine tin screw has come loose... just rubbing at a given RPM. Check all the engine tin screws for tightness... especially the rear tin... behind the shroud.
it might be the throttle cable... rubbing in the fan shroud... or the fan itself rubbing in the shroud.
UZI
Platinum FUBU
UZI is offline
PostPosted: Sat Mar 19, 2011 11:51 am    Post subject: Reply with quote
put some drops of oil down the distributor shaft if it's dry.
Extravagant Lifestyle
rdk_1973
rdk_1973 is offline
PostPosted: Sat Mar 19, 2011 12:09 pm    Post subject: Reply with quote
Thanks for the reply... I was wondering if too tight/loose valves might make this sound, but I guess not. I will check the screws and distributor shaft.
hazetguy
hazetguy is offline
PostPosted: Sat Mar 19, 2011 3:50 pm    Post subject: Reply with quote
sounds like you need some Bosch grease on the lobes of the distributor where the points ride.
johnshenry
johnshenry is offline
PostPosted: Sat Mar 19, 2011 4:51 pm    Post subject: Reply with quote
Also check your fan. It can rub on the housing at certain RPMs and create this sound....
John Henry
'57 Deluxe
'56 Single Cab
virtanen
virtanen is offline
PostPosted: Sat Mar 19, 2011 11:05 pm    Post subject: Reply with quote
My original generator bearings were dry, sometimes it sound like Morse code Smile
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
David
David is offline
PostPosted: Sat Mar 19, 2011 11:50 pm    Post subject: Re: Chirping sound Reply with quote
Cheers,
Dave
*October '54 Ragtop
ZwitterND
ZwitterND is offline
PostPosted: Sun Mar 20, 2011 11:08 am    Post subject: Reply with quote
x2 Disconnect the fan belt and spind the generator, reach behind and move the fan thermostat ring in & out. it may be hitting the fan once it warms up.
Bill
rdk_1973
rdk_1973 is offline
PostPosted: Sun Mar 20, 2011 2:00 pm    Post subject: Reply with quote
I checked the fan thermostat ring when I heard the noise, but it was only opened a little bit (it's only 10 degrees Celcius around here).
I fastened all tin bolts (they weren't really loose), added a drop of oil to the distributor shaft, checked the fan-belt (was ok) and added some oil to the engine (it was nearly at the bottom mark).
Today I drove around 100km and I didn't hear the sound anymore. Thank for the solutions.
VW Split Beetle (1950)
UZI
Platinum FUBU
UZI is offline
PostPosted: Sun Mar 20, 2011 6:02 pm    Post subject: Reply with quote
i guess we were all correct! Cool
okay!
