3Bugs Samba Member
Joined: December 27, 2003 Posts: 503 Location: Palmdale California
Posted: Tue Oct 19, 2004 10:46 am Post subject: Some of the smallest things can cause the biggest problems |
About a week ago I got ripped off of my Weber and 009 and had to put in the old stock stuff to get her going again. After the re-install I couldn’t get it started most of the time and when it did it ran rough. I remember the plug on the original Solex fell out of the carb and I JB welded it back on but thought it was still giving me a problem so I;
Purchased a new carb, that will fix it ….. Not! Still had problems
Then I checked to see if my spark was strong, it was kind of on the yellow side so I;
Put in new points….. Still had the problem
Put on new cap, rotor, and plug wires….. Still had the problem
Purchased a new coil….. still had the problem.
Purchased new plugs….. Still had the problem
Swapped distributors….. Still had the problem, kind of, it started but stalled right away.
I tried advance timing it while someone held down the pedal and my timing kept changing then my dwell kept changing then the engine just would not start. So I;
Removed and reinstalled the manifold, thinking there was a leak I could not find….. still had the problem
Did a leak test…. 95% +/- 1 for all four, that’s a good sign!
Adjusted the valves twice….. Still had the problem.
The one item I did not think to change was the freaking CONDENSER.
That fixed the problem.
Moral of the story….. Start with the least expensive and least time consuming item first regardless of how simple it may be. _________________ 3Bugs
Well, actually a 67 Bug, 72 Super, 61 Ghia and a 2004 Beetle Vert (sorry) |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Tue Oct 19, 2004 10:50 am Post subject: |
Glad you found the problem. Just think now how much ahead of the game you are having changed all that other stuff!! |
TeamSpatula Samba In The Rain
Posted: Tue Oct 19, 2004 2:12 pm Post subject: |
Yep - technically you're supposed to change the condenser when you change the points, but a lot of folks don't...No matter where you start, it'll always be the last place you look.
Glad you got it fixed... _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77652 Location: Sneaking up behind you
Posted: Tue Oct 19, 2004 2:17 pm Post subject: |
I had a valve spring break 2 months ago that could of done alot of damage to my engine.
It's a $3 part.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
3Bugs Samba Member
Posted: Tue Oct 19, 2004 3:08 pm Post subject: |
The reason I did not think to change the condenser was because it was only about three months old when I took the old dizzy out to put in my 009. I know your suppose to change them every tune up but three months is a short time for a condenser to go bad. Fooled Me!
Glenn,
How did you discover that one? _________________ 3Bugs
Glenn Mr. 010
Posted: Tue Oct 19, 2004 3:36 pm Post subject: |
3Bugs wrote: |
Glenn,
How did you discover that one? |
A loud banging noise coming from the rear of the car and a sudden drop in power.
I quickly realized I was running on 3 cylinders and that I had a upper valvetrain problem. _________________ Glenn
Member #1009
#BlueSquare
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22955 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Oct 19, 2004 6:54 pm Post subject: |
Small things can also cause the biggest problems in a divorce.
Glad you got it straightened out. |
Posted: Wed Oct 20, 2004 5:55 am Post subject: |
Looks like the 50 cent clip that holds the throwout bearing in place has gone out on my vanagon...that'll be a 4 or 5 hour PITA fix...
it's not the part itself, it's how much work you have to go through to get to it... _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
OnlyVW Samba Redneck
Posted: Wed Oct 20, 2004 11:02 am Post subject: |
Small parts. big probles, be glad it wasn't a lug nut that came off... Been there done that,it sucked. _________________ I may drive a GMC, but I long for a DUB! |
CoBusDriver Samba Member
Joined: December 30, 2003 Posts: 359 Location: Home is where you park it
Posted: Tue Oct 26, 2004 6:53 pm Post subject: |
$9.95 w/new washer... _________________ Big Mike
'58 standard
'71 westy |
Posted: Tue Oct 26, 2004 7:00 pm Post subject: |
New cam $50
Cam lube $5
properly breaking in your new engine... priceless! _________________ Big Mike
'58 standard
'71 westy |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Tue Oct 26, 2004 7:06 pm Post subject: |
Saving three dollars on fuel line has cost more people their VW's to fires. |
Glenn Mr. 010
Posted: Tue Oct 26, 2004 7:22 pm Post subject: |
A few monts ago someone brought me a siezed engine. After tearing it down i found one of the wrist pin retainers was missing and the wrist pin wore a groove in the cylinder wall taking the cylinder, head, rod and crank.
All for a $0.10 part. _________________ Glenn
Member #1009
#BlueSquare
lemke Samba Troll
Joined: February 24, 2004 Posts: 1249 Location: Seattle
Posted: Tue Oct 26, 2004 7:34 pm Post subject: |
How about a 99 cent part that will prevent a major accident?
A rubber brake pedal pad. If it wears out and you’re stepping on a metal pedal, your foot could slip and…. LOOKOUT!
Spend 39 cents for a hose clamp on your fuel line, and check those inexpensive hoses, and you could prevent a fire. |
