GrindGarage Samba Member
Joined: October 14, 2008 Posts: 710 Location: Ocean City, NJ
Posted: Sat Apr 16, 2011 9:11 pm Post subject: |
coolant mainfold and fuel line
_________________ -cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7300 Location: Honolulu,Hawaii and France
Posted: Sun Apr 17, 2011 12:09 am Post subject: |
I looked at your pic with the arrow pointing HOT on the return pipe to radiator.I have this one connected to the thermostat housing (which is supply from radiator),but since I replaced the radiator too,I guess I must have connected them to the correct outlet on radiator on the other end of platic pipe,because so far,temperature of working is great
Keep up the good work
Wrap your headers  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sun Apr 17, 2011 12:56 pm Post subject: |
Alika what did you use to wrap your headers? Does it help keep them in one piece? _________________ -cliff
91 Vanagon AUTO
Posted: Wed Jun 29, 2011 6:02 pm Post subject: |
FINALLY..... nope not done yet but may be able to work on her on Sunday. Going to my buddies garage where it has been sitting for nearly 2 months untouched. I have 1 year old daughter and a disabled partner and have to get 2 babysitters. The plan of attack is to pull it in vw powered and out under suby power! 2 of us. 2 post lift. All tools and fluids. Any idea how long without major snags it may take? I don't expect to many headaches. She's pretty clean and tranny has been in and out in last year or so.
Saw a thread started here about a mistake with oil pressure and im one of those guys without a functioning oil Waring system on my WBX.... I know im a rebel. I did check it a year ago with a gauge and was fine and left well enough alone and have a habit of checking oil level before firing up to go. VW couldn't make the dipstick any easier to access so I took advantage.
Anyway I have decided to hook up the diagnostic gauge while cranking to make sure it builds oil pressure. I would like to hook the idiot vw warning system back up to the suby engine and have it function properly. Am I asking to much? How has it been done in the past? Any help would be great. _________________ -cliff
91 Vanagon AUTO
Posted: Tue Jul 05, 2011 6:23 pm Post subject: |
Got the WBX on the floor
91 Vanagon AUTO
Posted: Tue Jul 05, 2011 6:30 pm Post subject: |
Had to order a new Throttle Cable. Got it from ken @ vanagain.com will probably show up tommrow. Love getting van parts next day. Was wondering why the tranny would only go so low. Going to clean up the engine bay and coat it in some black rustoleum.
Do most people keep the heat shields that wrap around the engine bay?
Mine are in Ok shape and could be reused but would rather scrap them. Looks like I need to find some nice trim for the firewall what do most of you use?
Also been thinking about wrapping my SC header. I have the single port EJ22 anyone out there with single ports and cracks? _________________ -cliff
91 Vanagon AUTO
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Wed Jul 06, 2011 4:34 am Post subject: |
I kept the tin in the engine compartment with our 2.5L Subaru install. You probably could run with out it but it will minimize dirt and water being splashed into the engine compartment with them in place. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
FrankenSubySyncro Samba Member
Joined: May 03, 2007 Posts: 638 Location: Vancouver, WA.
Posted: Wed Jul 06, 2011 10:41 am Post subject: |
| Franklinstower wrote: |
| GrindGarage wrote: |
| try to source some torker cams. Anyone know any good sources for after-market suby cams? |
Yes, Delta Camshalf, also in Tacoma, can regring your cams. Call them and ask about their Torque Grind. It gives you more torque at lower rpms, and you will get more HP out of them. I am installing some in the spring.
http://deltacam.com/
it is about $80 per cam i think. Are you using a DOHC 2.5? if so make sure you swap out the head gaskets to the Cometic gasket.
you don't need to port or polish your heads, it will only give you a higher rpm range, which is not necessary in a vanagon!
Paul |
I have the delta camshafts in my syncro with a 2004 impreza 2.5 SOHC. I wanted more low end torque for offroading. They have 3 differen't grinds to choose from. I am using the 1000 grind. I am very happy with them and no troubles. _________________ Syncronize it!
1987 Franken Syncro (converted 2WD auto)
2004 2.5 SOHC Subaru
F & R lockers, decoupler, SS, 6.17 R&P
Trans Cooler
EMPI race prepped 930 CVs and axles
Bilstein coilover front, rear ProComp MX-6066R shocks, 14" hypercoil springs
30x9.5 15" BFG Muds
Custom skid plates
Nose job (custom front bumper) http://www.flickr.com/photos/subyvanagon/sets/72157624970330925/ |
Posted: Sun Sep 18, 2011 6:39 am Post subject: |
Been driving my swap for 2,500 worry free miles. Had 1 snag since it first fired up and that was on my way to Millville to see Ken at Vanagain. About 5 miles from his shop it started to misfire a little. Popped the engine cover and discovered that the #1 injector plug was not fully seated. My smallcar exhaust gaskets have failed (of course) and I am ordering up some factory. Other then that just enjoying the ride.
I do have some body work to do and still need to mount up the ECU. I also want toi switch sides on the factory intake snorkle and modify the subaru airbox to work with it.
Some Pics of the Swap:
Stock subaru intake with early air tube to 97 box:
Super long smallcar harness:
Power steering Bypass: (need correct fitting)
Smallcar Muffler:
3 months of oxidation:
91 Vanagon AUTO
Posted: Sun Sep 18, 2011 6:43 am Post subject: |
Next up mounting ECU. Some Ideas of how / where:
Using factory cover with ecu sticking out of bottom:
Wires hidden with OBD2 connector possible moiuting location:
Any info out there on what others before me have done? _________________ -cliff
91 Vanagon AUTO
Posted: Sun Sep 18, 2011 6:47 am Post subject: |
Next up bodywork. What gauge sheet metal is best for patch panels? I am strongly considering welding the worst of the seams instead of using adhesive.
I pulled all the body molding its gone forever. Allready have the POR15 ready to go just gotta get er done.
91 Vanagon AUTO
Posted: Sun Sep 18, 2011 3:31 pm Post subject: |
It is part of the orginal harness remvoed from the donor _________________ -cliff
91 Vanagon AUTO
