Custom Heat Riser Location?
jkyes
jkyes is offline
PostPosted: Sun May 08, 2011 5:32 am    Post subject: Reply with quote
ok what are you guys using for heat riser tubing. It appears you are using extra tubes, but I cannot seem to find them anywhere.
MConstable wrote:
So, Glenn wasn't "trying" to correct you
he "did" correct you.
James
'74 bug
mharney
mharney is offline
PostPosted: Sun May 08, 2011 7:53 am    Post subject: Reply with quote
You can get them at industrial supply stores online. I get them from Mcmaster.com
modok
modok is offline
PostPosted: Sun May 08, 2011 11:11 am    Post subject: Reply with quote
1/2 OD steel tubing
I get it from the hardware store or many of those ugly table lamps have a piece of it through the middle.
jkyes
jkyes is offline
PostPosted: Sun May 08, 2011 12:09 pm    Post subject: Reply with quote
do you just weld it into place? lots of the pictures show special flanges.
this is most similar to my muffler, where should I weld it into place? Am I correct, that I should move the left side(as you look from the back) not the right?
James
'74 bug
KevinAlbrecht
Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota
KevinAlbrecht is offline
PostPosted: Sun May 08, 2011 12:14 pm    Post subject: Reply with quote
I think this mod can only be performed on a header...
Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image
modok
modok is offline
PostPosted: Sun May 08, 2011 1:20 pm    Post subject: Reply with quote
You could have one end centered in the pea shooter, same way the stock muffler is.
But we gotta give you some flack for using that silly muffler
HA HA
mharney
mharney is offline
PostPosted: Sun May 08, 2011 2:02 pm    Post subject: Reply with quote
I use 5/8" OD seamless mild steel formable tubing.
jkyes
jkyes is offline
PostPosted: Sun May 08, 2011 5:54 pm    Post subject: Reply with quote
Yeah I can take getting razed some... I am slowly doing the work to fix up from PO. going to get a new engine eventually, but want this one running well enough I feel like driving around. otherwise it is just going to sit in the garage until i pull together the money.
It does not have to run great, but it needs to be better then now, and I am hoping good heat to the carb will help...
5/8 or 1/2? do they both fit in the stock intake? does the 5/8 fit over the old one?
Flanges? welding?
James
'74 bug
modok
modok is offline
PostPosted: Sun May 08, 2011 6:49 pm    Post subject: Reply with quote
yeah, your right it is 5/8 tubes, musta been an extra big lamp i stole it from.
To make flanges, buy big washers, clamp them together, and drill two or three 1/4 holes through them near the edge. CUSTOM flanges!
mharney
mharney is offline
PostPosted: Sun May 08, 2011 7:30 pm    Post subject: Reply with quote
You can also either reuse flanges from the std heat riser setups, or you can use the blockoff plates and drill them.
THINGONER
THINGONER is offline
PostPosted: Sun May 08, 2011 10:40 pm    Post subject: Reply with quote
Can you weld the pipe to the exhaust just prior to it entering the muffler on the type of system shown above? Will this work? If not does anyone have a suggestion?
mharney
mharney is offline
PostPosted: Mon May 09, 2011 6:16 am    Post subject: Reply with quote
It tends to work as a draft tube.. you need velocity to make it work well. Look at a stock muffler.
jkyes
jkyes is offline
PostPosted: Mon May 09, 2011 6:20 am    Post subject: Reply with quote
you guys buy a bender, or do it another way?
James
'74 bug
mharney
mharney is offline
PostPosted: Mon May 09, 2011 6:23 am    Post subject: Reply with quote
I have a bender made by Yellowjacket. I do all mine by hand with it.
medeno
medeno is offline
PostPosted: Fri Jul 06, 2012 4:54 pm    Post subject: Reply with quote
Found a must read for heat risers, all your questions answered
http://www.carburetorclinic.com/heatriser_tech.html
harleyriders1944
harleyriders1944 is offline
PostPosted: Mon Jul 30, 2012 12:29 pm    Post subject: heat riser pluming for progressive Reply with quote
i understand the theory behind one heat riser located at the #2 header location and the other has to go to the collector my ? is would it be better to just "t" into one of the heat tubes and go down to the collector since its already hooked up the way the headers came originally or do i have to weld up one of the mounts and do it the way is suggested just curious if doing it my way would hinder the heat movement
mharney
mharney is offline
PostPosted: Mon Aug 06, 2012 11:59 am    Post subject: Reply with quote
You need to disconnect it from the primary to get a pressure difference.
jgrexx
jgrexx is offline
PostPosted: Mon Sep 10, 2012 7:36 pm    Post subject: Reply with quote
i plan on doing this but i was gonna use stainless steel braided line like that is used to run oil lines instead of welding pipe. just screw in fittings to the exhaust and into cut off heat risers and then screw on braided line. that way it would be easy to just disconnect the lines in order to remove the exhaust when working on your engine.
1970 Baja Bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=520964&postdays=0&postorder=asc&start=0
tdonaldson
tdonaldson is offline
PostPosted: Mon Nov 12, 2012 2:45 pm    Post subject: Reply with quote
I had a cobbled together system that had flexible lines. Didn't work well. The metal/metal connection with conductive heat probably does as much as exhaust gas passing through.
The system I have now is hi to low welded in pipe on a dual cannon. I'm not sure if I'm getting as much heat even with that because the tube to the low pressure side can't conduct as much heat back into the intake (being welded in three feet further from the head it isn't as hot)
"If you had a beer can in your hand the beer would have stopped it, alcohol is a natural force of good that keeps you from getting hurt, unless you're city people...."
cdollar
cdollar is offline
PostPosted: Mon Jan 21, 2013 8:00 pm    Post subject: Reply with quote
I just did this mod on my bugpack bus header. I don't have a decent torch setup to really bend the steel tubing with tight bends so I ended up using an old 1/2" conduit bender to make some more sweeping bends. Should work nicely!
Page 3 of 4
