Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon Jan 03, 2011 12:22 pm Post subject: Wiper Refresh FAQ |
This is actually an important operation, not only for your safety in inclement weather, but for the health of your car. Particularly with the bus, as shown here, your wiper pivot grommets both struggle to keep the blast of 60-70-80 mph rain out of your interior where rust can eat your VW from the inside out AND they are two out of only three responsible for supporting the entire wiper assembly to the car.
Don't like that nasty clonk when you hit the wipers? Fine! Replace the grommets as shown here. Don't like slow wipers? Good! Lubricate the system as shown here!
Step 1) Remove Glove box. There is a strap that holds the cardboard to the dash panel opening. Sometimes you will find that the radio antenna and rear window defroster wiring has been routed between the strap and bottom of the glove box. Let's not do that. Let's find a nicer, tidier route for those wires when we reassemble, OK? Along the lower edge of the strap, you will feel the phillips screw that holds it all together. (clean the glove box out and get rid of the toothpicks and napkins and the seeds from your last stash and whatever other detrius accumulates here. Have a small box for fuses, spare set of points, light bulbs, and stick it on the owner's manual which you have in a waterproof ziplock bag next to the dial tire pressure gauge)
Step 2) Remove heater ducts and wiring.
With the glove box out, it is easy to see the heater ventilation ducts that you need to remove. 1973 and later buses with the registers in the dash panel will require that you remove the registers before you can free the ducts. Start with the right side because it is easiest to get to now. Lightly pinch the barbs in the registers with your small visegrips adjusted to not pinch too much and push up through the dashmetal. Once removed, wash the registers in mild soapy water, dry, and treat with a UV protectant. Push the duct down below the hole in the dash and wiggle sideways and free from the heater branch below. Now you will be able to see the left side a little better and you can remove its register and duct. Heck, remove the branch pipe and clean it in soapy water with the other ducts.
Although the below photograph shows everything already removed, it also shows you how nicely a removed glove box opens up access to the under dash area. Don't forget to wax the intake air plenum to a military shine:
Early buses will need to remove each wire from the wiper motor terminals. Label as necessary. '72-76 buses have a multi-connector which makes it easier, and the '77 and later buses have the only sensible plug that you merely pull out of the terminal block on the wiper motor assembly. While you are here, go chase down the brown wire to its ground spade and clean the terminal and give it a dab of DeOx anti-oxidant gel.
Step 3) Remove Wiper Arms.
Early buses have acorn nuts, later buses have plastic caps and 10mm nuts under them. Remove the nuts and the wavy (they are wavy, right?) washers underneath. Lift the wiper arm until it is in the extended position. Try to rotate and wiggle the arm to free it from the shaft. If it is stuck, reinstall the nut a few turns and tap the nut with a hammer while repeating the wiggle/rotate simultaneously. In seriously stuck cases, a battery terminal puller will work splendidly to get the arm off.
You should very much have the plastic protector (#211955275A WolfsburgWest $3.00) that just fits over the retaining nut and serves as your first line of defense against incoming moisture. Note please, whether or not it actually does engage with the retaining nut below. Remove it by pulling straight off. Now remove the retaining nuts (below is actually a reassembly photograph):
Your wiper assembly is now being held on only by the lower support bolt/grommet inside the car:
Well? Remove it already. Gently remove the whole assembly from the car. You will need to tug a little to get the threaded wiper shaft "bearings" as Bentley refers to them, free of both the outer metal and the inner metal which is actually the windshield channel support. Here is what you need to watch out for:
* any wires dangling that can get hooked, especially live ones,
* scratching the paint on the air plenum,
* blowing up the radio because you refused to remove the battery negative so you could listen to toons.
Step 4) Replace Wiper Shaft Seals/Grommets.
You could just buy some new Wolfsburg West #311955261A grommets for $2.00 and have some nice new punky grommets that . . . work. You just stick them in where your old ones are torn and bisected through the windshield channel. But what if you were in the middle of nowhere and needed new grommets . . . right now, the rain's a coming? You could walk over to the local parts house and get some GM door stop rubbers for $2.00 and no shipping:
With a little dremel action, you can mow off the cap and open up the hole and most importantly, for those of you who found that your black plastic cap protectors were not reaching the retaining nuts in Step 3, make the outside slightly thicker than stock by offsetting the groove you make with your Dremel cutting disk. That makes the retaining nut sit higher and engage the plastic protector with authority:
Refer back to the already-assembled picture of the wiper shaft, now with an informed eye:
Notice how nicely that seal surface extends past the washer and nut? That's our General Motors doorstop modified to serve as an IAC Hurrikane Sertified Volkswagen wiper assembly support grommet/seal (this method requires some modification effort/time, no warranties implied as to merchantability).
You will find that new support grommets help prevent leaks, yes, but they may also help the wipers track more smoothly. I have noted less chattering or build up of wax stripes at the end of their travel on the glass that like to hang the wipers and beat up the linkage.
Step 5) Lubricate Wiper Shafts.
First you need to carefully pry the links from the ball ends of the wiper shaft levers. Leave the links on the motor crank. You can bend the socket ends of the links easily (and don't want to), so use well-placed prying screwdrivers or chisel or whatever works.
There are cruel little c-clips where the shafts stick out of the threaded bearings. You must wrest these clips off to pull the shafts out. I use two small screwdrivers. Lay this assembly out on a towel and be alert to any flying c clips. Hold the edge of the c clip with one screwdriver. Now, pull the other edge of the c clip with the other small flat bladed screwdriver. As you pull, the c clip comes free of it's groove a bit. You need to rotate the second little screwdriver under the c clip and let it "walk the clip out of the groove around the circumference. Tiny expanding pliers would make this easy. Pull the wiper shaft out of the "bearing" and note the washer down at the other end. Clean out the threaded bearing hole and the wiper shaft. I then use a 45* cross-hatch sanding with 220 grit on the shaft to give lubrication grooves. Clean thoroughly with . . . I dunno, GumOut? Find the little splines on the wiper shafts and pick them clean with the edge of a razor blade. There are many splines, and you are going to do each one. This is to help you, so deal with it, Every one. The shafts have very little leverage to move the ten pounds of snow off the windshield that you were too lazy to clear off, and the splines are the only way the wipers will have a chance.
What sort of lubrication should you use as you reassemble? Cold climate people may find that pure gooey grease gets too resistant. Engine oil is too thin. This grease also serves as an adjunct to keeping water out. My solution was to use thick but well-behaved Valvoline DuraBlend Semi-Synthetic molybdenum disulfide grease. I dipped my finger into the oil base of the grease (it is usually in a little pool at the bottom of the container) with just a dab of the "real grease" smeared in. This lower viscosity should help you in cold weather.
Step 6) Lubricate/Adjust Gearbox.
You have to remove the 13mm nut on the drive lever and let the lever just fall off as it may. The cover has a ground spade under one perimeter screw, and the receptacle for the blessedly sensible later bus wiper terminalplug sort of hiding another screw. Loosen the perimeter screws all about two turns and free the cover a bit. Try to see which surface the gasket wants to stick to. Whichever surface is more favored, the cover or the body, use your razor blade to *make sure the paper is freed from the other surface all the way around*. The limited freedom of the cover is to make sure you don't accidentally fold the paper or tear it. Remove the cover with the little copper tracks,and marvel at the ingenuity before you, which I just could not photograph. There is a copper record album sitting on the big plastic gear. Every time you shut the wipers off, the "off" position of the switch actually sends voltage to this record platter. The motor will remain energized until the copper platter rotates to it's designed-in dead spot. That should correspond with the lever on the outside of the gearbox being horizontal to the linkages' dead spot.
See any grease? Good. 95% of that grease has been blasted away from the operating surfaces and you can borrow as much as you like from the coves. If it is horribly filthy and contaminated with small rocks and metal burrs (haven't seen this ever), I recommend that you get the Sears Garage Door Opener Grease (white, safe for plastic!!) and pack the plastic gear teeth anew after a good cleaning. It is acceptable for the plastic gear shaft and bushing as well. Just pull the gear up, dab the shaft, stick it back down. See that the little cover-to-platter copper fingers are clean at their ends, a buff with the edge of the razor blade is fine.
Check the endplay of the motor before it's disassembly. Endplay . . . an inescapable part of VW life. What is .008" endplay, anyway? Men who adjust their own valve clearances know all about this. It is the same feel as slightly loose valves, a nice click click, but not a minor tick tick and certainly not a tonk tonk. HTH.
By moving the plastic gear back and forth a smidge, you should see the motor shaft rock up and down a smidge. .008" is called for. You can loosen the locknut, screw in the nub screw a tad to snugger up a little, then tack with the locknut.
Reassemble the gearbox. Snug on the screws, but not stupid-tight.
You can now check and adjust the endplay of the plastic gear shaft.
Step 7) Make Wiper Motor Happy.
There are two bolts holding the motor to the gearbox. Make a note of the position of the housing to the gearbox. Please also note how the little tab/nuts were slipped into the motor housing, as you loosen the bolts. Temporarily slap the drive lever with the dangling links on the plastic gear shaft and snug it up so you can hold the plastic gear from turning. Pull the motor housing off the armature which will stay put, since the plastic gear will hold the worm gear. You will be battling the mysterious force of magnetism as the pole shoes relinquish their field against the armature. Inspect the bearing surface of the motor shaft for cleanliness and smoothness. If yours is dried and scored, just sand it down smooth with 220 grit in bad cases followed by 320 and even 600 to polish. Achtung! Protect the armature from sanding contamination. Wipe clean with GumOut impregnated paper towel.
Removing the motor shaft from the brush housing is occasion for anxiety if you do not like stuff sproinking. Rotate the armature to see which way unravels it from the plastic gear. See if you can pull the brush plate with the motor housing from the mounting plate. There are three(?)rubber mounting divots for the brush plate that will have to release from the mounting plate as you pull the motor away. If it screws up, the brushes will all pop out like jack in the box and the springs often intricately knot themselves amongst each other instantly. Oh well. Clean the armature with 600 grit sandpaper. Stripe the stripes with a razor blade to undercut from the working surface just a tad. Wipe with a GumOut impregnated paper towel. Wipe down the brush plate and see if all of your brushes are similarly sized.
Step 8 ) Reassemble This Mess
You can put each wild spring and brush in its cage and pull the wires *gently* to keep the brushes retracted as you sort of stick it on the commutator/stick the commutator through the brush plate. Expect six or six thousand tries.
Slap a dab of grease-with-base oil Valvoline DuraBlend Semi-Synthetic molybdenum disufide carefully upon the motor shaft bearing points.
Move the motor shaft and brush plate like you are docking the space shuttle . . . slow . . . deliberate . . . accurate . . . and with awe, towards the mounting area. Rotate the assembly to line up brush plate with the rubber divots and the through bolt holes for subsequent motor housing. Screw the motor shaft to allow it to go past the plastic gear. Hold the plastic gear again via the dangling linked lever, because now you get to battle magnetism again as you get the motor housing onto the armature and pray that the shaft goes into the bushing at the bottom of the motor housing shell. Find your indexing and get the through bolts in while you slip those stupid tab/nuts aligned through the slots in the motor housing. Tighten the bolts as you shimmy the housing to its favored assembly spot.
Step 9) Set Park Position.
Review underdash for any wires that should not be touching bare metal. Replace ground strap on negative post of battery if you removed it. Remove the lever (with the dangling links) from the gearbox/motor. Bring the gearbox/motor to the car and get the wires all hooked up to the wiper assembly. Us '78-later buses just have to plug in the plug. Ha ha, a small benefit in the midst of cheaped-out plastic. Turn on the ignition and then turn on the wipers. The motor will jerk to life in your hand. Smooth, peppy, nice, huh? Shut it off at the switch. The motor will stop momentarily. This is your park position. Install motor to the wiper assembly. See how your wiper shaft arms with the ball joints can pivot to the left side as installed in the car? That means you want the lever to now be installed to the left as far as it can, i.e. horizontal-to-the-left on the gearbox output shaft.
Step 10) Back Together
Dab a little grease in your wiper support grommet/seals. When you install the refreshed wiper assembly, you may need to bend the shafts a little to get them through their holes. There is a radius to the front of the car that the shafts must find.
Bolt the lower support grommet to the intake plenum and do not overtighten. Screw down the washers and nuts on the threaded wiper shaft "bearings" and again, not too tight.
Reassemble duct work and glove box. Lubricate the inside holes of the black plastic caps so they don't try to work the retaining nuts loose over time.
Adjust your wipers to horizontal for the left wiper and to stay clear of the lower right edge of the windshield seal even under a downward pull for the right wiper:
Outside View:
Inside View. See? Sort of follows the dash curve:
Try out your wipers only with a wet windshield.
Colin _________________ www.itinerant-air-cooled.com |
rumplestilskin Samba Member
Joined: January 13, 2007 Posts: 963 Location: los banos,CA
Posted: Wed Mar 02, 2011 7:52 am Post subject: |
sticky!
or at least linked in a sticky
thank you for the guide. i refreshed my wipers a few weeks ago and used this write up as a guide . i also replaced my motor with a newer(cheeper) vanagon motor. and used wire grommets as wiper grommets . i just lubed em up with silicone grease. _________________ currently 71 super auto-stick, 73 ghia, 71 yellow ghia , a 68 square w71 fi, a 77 bus station wagon deluxe. and finaly finaly a 74 riveria with volvo pawer .ITS AN ADDICTION!!! |
jure-slo Samba Member
Joined: November 06, 2009 Posts: 245 Location: Slovenia (Europe)
Posted: Wed Mar 02, 2011 9:11 am Post subject: |
What about a sticky containing all interesting how to's? _________________ '79 Bay-window, 2.0, duals solexes, automatic
'76 Triumph spitfire 1500
'86 Polski Fiat
'72 Mercedes W115, 200D |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Mar 02, 2011 9:21 am Post subject: |
Amskeptic wrote: |
Clean the armature with 600 grit sandpaper. |
you should not use sandpaper on an armature. you should use crocus cloth or emery cloth. |
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Wed Mar 02, 2011 9:35 am Post subject: |
INTENSE! _________________ once you realize im not impressed we will get along just fine |
chrisradioman Samba Member
Joined: September 20, 2007 Posts: 4873 Location: Swansea (Sunny Penllergaer) Wales UK
samwise Samba Member
Joined: May 04, 2010 Posts: 611 Location: North Salt Lake, Utah
Posted: Sun Feb 12, 2012 1:12 pm Post subject: |
Am following this guide at the moment, pretty easy to follow so far (I'm still at the removal stage, though )
I've taken the opportunity to remove the eyeball vents at either end of the dash to try and clean up more of the air ways - the driver's side one had a big round chunk of dense foam (about an inch thick) stuck in the outlet pipe, and both vents have what looks like the remains of foam on the shutter (Or whatever you call the bit that cuts off air flow when you move the lever in the vent.
Should that foam be there?
Naturally, I've taken it apart and then read a bit further to see that I should've ordered the grommets for outside first
All this because I can hear the motor whine at both speeds when I move the switch, but no movement from the wipers - I'm hoping that means that it's just the arm that has frozen, and greasing it up etc will free the wipers up. _________________ Ben
1979 7-passenger bus
Harvee the Wonder Bus' pics |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sun Feb 12, 2012 2:20 pm Post subject: |
samwise wrote: |
All this because I can hear the motor whine at both speeds when I move the switch, but no movement from the wipers - I'm hoping that means that it's just the arm that has frozen, and greasing it up etc will free the wipers up. |
on mine the weld on the shaft of the motor snapped, so the motor ran, but it didnt turn the mechanism because it was spinning freely....check into that first, and if thats the case...just get a new motor (used is cheapest) _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Micropassatman Samba Member
Joined: January 27, 2006 Posts: 472 Location: Chico, CA
Posted: Sun Feb 12, 2012 3:03 pm Post subject: |
Great writeup! |
The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 705 Location: Arizona
Posted: Sun Feb 12, 2012 4:00 pm Post subject: wiper refresh.. |
Thanks MUCH for this post.will be doing in a couple of weeks...what is the GM part number for the grommet? Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Sun Feb 12, 2012 4:01 pm Post subject: Re: wiper refresh.. |
ashley1 wrote: |
Thanks MUCH for this post.will be doing in a couple of weeks...what is the GM part number for the grommet? Bob |
the original grommets are only 5 bucks for the pair....(bow wow in lynnwood) _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Feb 12, 2012 5:07 pm Post subject: |
Well, that's wonderful! Taken the lever arms off from the motor, taken the wiper spindles out, cleaned them up including the washers and c-clip, and re-greased.
Connected it up to the power without connecting the lever to the spindles and it works on both speeds.
Attach the levers to the spindles and nothing, no movement whatsoever.
Boesen Samba Member
Boesen Samba Member
Posted: Thu Apr 26, 2012 5:14 pm Post subject: |
This is the second time I've used this post for wiper system removal and PM. Once was last month just to re-lubricate the shafts on my 79. and the other was today for wiper shaft replacement on my wife's 71. Thanks again AMSKEPTIC for another great "How to".... Thats three times in the last two months I've used one fo your "How To's" for PM's on both Bus's. Thank you for your time and effort put into them, they are a wealth of help when needed, and to keep "Bookmarked". _________________ 1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa |
slowmo1968 Samba Member
Joined: May 19, 2010 Posts: 10 Location: Kittery Maine
Posted: Tue Jun 12, 2012 11:49 am Post subject: |
What about new brushes for the motor? I dont want to have to buy a new wiper motor. Pretty sure a new set of brushes and clean the armature will do the trick. PLEASE does anyone know if there is somewhere to purchase the brushes still????????? |
Chris_914 Samba Member
Joined: September 16, 2011 Posts: 344 Location: Las Vegas
Posted: Tue Jun 12, 2012 12:05 pm Post subject: |
Just did mine a few months back....
The drive arm on the motor shown in the Bentley manual is indexed for an earlier model than '75 and 180° off for me. My wipers went down instead of up using that wonderful piece of info.
My hardware store had springs that were similiar to the original brush springs. One of mine lauched to infinity and beyond trying to install it. There are four brush on mine, they were still good but the hardware store had some that could be shaped to work. _________________ '75 Westfalia Camper FI 1.8L
'75 914 2.0L |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2946 Location: East Northport, NY
Posted: Thu Jan 24, 2013 5:29 pm Post subject: |
Do you recommend the GM style grommet over the stock style VW one from Bus Depot?
I just bought my bushings, caps, wiper arms and whatnot. Just not sure if your GM solution is because of a flaw with the VW part. _________________ Mike
1964 Beetle
2001 Eurovan Camper |
Posted: Thu Jan 24, 2013 6:29 pm Post subject: wipershaft grommets |
Colin is the "authority" on this one in my opinion....I am in the middle of restoring my wiper assembly, and did get the GM pieces...however, am going to try another idea...the WW wipershaft seals pn 311 955 261A are too small (in my opnion)...I need to replace the wiper assembly grommet pn 111 955 641...which I just ordered...am going to see if this ( measures about 11/16 across) is close enough to be the right size for the shaft seals....my thinking is that I may only need to enlarge the hole, and might work...and be an easier solution...we will see. Will post when I get them and try them out... Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Thu Jan 24, 2013 6:58 pm Post subject: |
I had also noticed that the factory seal seems smaller in diameter than the GM "fit" that's above. I don't know if there is a reason or if its just the way the GM seal fits in. _________________ Mike
1964 Beetle
Posted: Thu Jan 24, 2013 9:31 pm Post subject: |
obnoxiousblue wrote: |
I had also noticed that the factory seal seems smaller in diameter than the GM "fit" that's above. I don't know if there is a reason or if its just the way the GM seal fits in. |
My little article was in the middle of California agricultural country where I had no access to the correct grommets, but I did have a "help" aisle at the local auto parts store with those GM door stops. I would NEVER recommend the long road I took! BUT . . . there actually was a benefit that I only understood mid operation, namely that I could cut the body opening groove in an offset manner to allow the retaining washer and nut to stick up high enough to be engaged by the plastic shaft seal/cap.
Do you think Hazetguy will come around after all this time to read that the bodyshop 600 grit wet-or-dry sandpaper worked really well, no friability?
Colin
(wipers still working well and doorstop rubber still intact, thankfully) _________________ www.itinerant-air-cooled.com |
