Brake Booster in 71 bus needs rebuild AGAIN?
Page: 1, 2, 3, 4, 5  Next
Harveybacon
Harveybacon is offline
PostPosted: Thu May 19, 2011 4:55 pm    Post subject: Brake Booster in 71 bus needs rebuild AGAIN? Reply with quote
For now, got my brake booster (servo) back on and painted the ol bus. Brake booster was working great, and now is whining and seems to be busted again. I'll have to mail it back out for another 3 weeks to hope they fix it. Would there be something causing it to break? push rod, or vacuum line? everything seems to be wrong in the booster; I think lines are in good shape...
email: [email protected]
Facebook: http://www.facebook.com/groups/GainesvilleVDubClub
website: http://solemndesigns.com/GainesvilleVDub/?p=1
1971 Campmobile
M-Plate: http://www.vw-mplate.com/mplate-6571.htm
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Facebook Gallery Classifieds Feedback
SGKent Premium Member
SGKent is offline
PostPosted: Thu May 19, 2011 8:21 pm    Post subject: Reply with quote
are you leaking brake fluid into it?
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
Harveybacon
PostPosted: Thu May 19, 2011 8:43 pm    Post subject: Reply with quote
it's possible, the level in reserve went down. do I need to replace the master c.? or is it a seal if this is the case. How do I check? thanks
1971 Campmobile
maximan1
maximan1 is offline
PostPosted: Fri May 20, 2011 8:48 am    Post subject: Reply with quote
You replaced the brake booster without replacing the master cylinder? I was under the impression that those went hand in hand, usually a brake booster goes out when the MC leaks brake fluid into it.
1978 Transporter, 2.0L FI
Harveybacon
PostPosted: Fri May 20, 2011 8:57 am    Post subject: Reply with quote
well, no I didn't replace that. So is this something I should do then? They are only 35 bucks on MidAmericaMotorworks' site. All I did was send in booster for rebuild. They will take it back for free, and hopefully fix it. But really, even if MC was leaking, would it blow the newly rebuilt booster after only 30-40 miles again?! Thanks
1971 Campmobile
ccpalmer
ccpalmer is offline
PostPosted: Fri May 20, 2011 9:40 am    Post subject: Reply with quote
Little advice - stay away from MAMW. German MCs cost more but I'd say that's one place not to scrimp on parts.
'71 Westy
Harveybacon
PostPosted: Fri May 20, 2011 9:47 am    Post subject: Reply with quote
thanks, I just bought the bus for 900 and got 230 in credit to the place MAMW. so it's technically free, and I'm not skimping in theory, lol. Is there a way to check if there is a leak? I didn't notice any fluids when I replaced the part. The guys up at the import shop that sent out booster for me feel that the rebuild people could have just made error and there is no charge to send it back. I just need to know what to do to check the situation out. Thanks for the input guys!
1971 Campmobile
ccpalmer
ccpalmer is offline
PostPosted: Fri May 20, 2011 9:51 am    Post subject: Reply with quote
MAMW did buy OEVeeDub, so they do carry some real German parts but apparently not MCs yet. Maybe save that credit for other parts you'll be needing...
Note - Ouch I just checked German Supply where I got my ATP MC and the prices have skyrocketed... Wolfsburg West has them for $150 though and they say it will fit a '71 with a new reservoir...
'71 Westy
Harveybacon
PostPosted: Fri May 20, 2011 9:52 am    Post subject: Reply with quote
also, I need to know if it is going to harm anything to drive it like this. The brakes feel way better since rebuild. But started whining, and revving up when braking. It's not too hot here in FL right now, but would traveling like this hurt any other components? I mean it only revs up when stopping, so of course I'm not using the gas then anyways... Anything going to get worn out that I'm not thinking of? Thanks
1971 Campmobile
ccpalmer
ccpalmer is offline
PostPosted: Fri May 20, 2011 9:55 am    Post subject: Reply with quote
If it were me I'd just cap off the booster vacuum nipple and run without power brakes rather than risk a lean-running engine.
'71 Westy
Harveybacon
PostPosted: Fri May 20, 2011 10:04 am    Post subject: Reply with quote
great, I can do that? just pull off the hose, and cap it there? there are two hoses going in, should I do that to both? or just cap off at carb? thanks!
edit: if I just pull off hose at carb, I don't think I should have to cap it at the hose, but just on carb? or cap both off and drive? Question
1971 Campmobile
Harveybacon
PostPosted: Fri May 20, 2011 10:27 am    Post subject: Reply with quote
so pulled hose off carb, stuck a perfect stick in hose, and tightened clamp, threw it to the side of compartment. And I found perfect rubber stopper and put it on carb post/hole. Brakes are hard, but work, and there is no Revving! good thinking. just like before I had it rebuilt, but without revving. Hopefully this is OKAY!?
If I left the hose unplugged (no stick) would that be okay? still curious how vacuum works on this, would it being open hurt anything? Thanks!!
1971 Campmobile
aeromech
aeromech is offline
PostPosted: Fri May 20, 2011 10:34 am    Post subject: Reply with quote
You can leave the hose open. When you pulled the booster did you replace all the vacuum hose? There are two pieces, one in front by the booster and one in back that you plugged. Replacement hose is widely available. Use Gates 27231 power brake booter hose. It's 15/32 inside diameter.
What about the check valve? Do you have one? Is it pointed the right way?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Harveybacon
PostPosted: Fri May 20, 2011 11:02 am    Post subject: Reply with quote
Good to know I can have hose open, I'd like to check and see how that works out in a minute. (edit: worked out good, less "hard")
I replaced all hoses that needed it. they are all pretty new except small one, still in good shape. Thanks for heads up on where to get more hose.
I can't seem to find any check valve, unless inside booster. I have read about them, but have no evidence that there is one on my 71 bus.
1971 Campmobile
aeromech
aeromech is offline
PostPosted: Fri May 20, 2011 11:09 am    Post subject: Reply with quote
This is bad. You need a check valve. Also, you spoke about a small hose being in good shape. Which is that? These hoses can fail internally and look good on the outside.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
busdaddy
busdaddy is offline
The check valve is in the line between the firewall and the manifold (should be anyways).
I'm not so sure you can blame the master for the failure unless it's obviously leaking fluid, same with pushrod length and vacuum plumbing. If the end of the master is dry the only reason for a failure this soon is a bad rebuild (it happens to the best of shops sometimes).
Слава Україні!
Harveybacon
PostPosted: Tue May 24, 2011 6:01 am    Post subject: Reply with quote
WELL, i CAN REPLACE THE HOSES THAT HAVEN'T BEEN, JUST FOR PRECAUTION. i SEE NO CHECK VALVE INSIDE ENGINE COMPARTMENT.
Is it okay to drive without power, as I have it now? I don't want to mess anything up doing it this way either. Thanks
1971 Campmobile
aeromech
aeromech is offline
PostPosted: Tue May 24, 2011 6:08 am    Post subject: Reply with quote
Yes, the brake don't work well but you can get by. People do it all the time.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Desertbusman
Desertbusman is offline
PostPosted: Tue May 24, 2011 8:40 pm    Post subject: Reply with quote
Sure. Unless you get into that situation that you need every bit of brake available. Then you might mess up the front end of your bus and the back end of some other vehicle.
71 Superbug
71 Westy
gd420mj
gd420mj is offline
PostPosted: Fri May 27, 2011 3:50 pm    Post subject: Reply with quote
Since this thread is about rebuilt brake boosters... quick question.
I had mine rebuilt a few years ago by that guy in texas...I have not driven the bus much in those few years. Been garaged. However, even since last year, brakes are not quite right....
My question is this: When I depress the brake pedal, even just 1/2", the servo seems to suck air from the front vent on the push rod. I just pulled off the hose and was blowing into it. I pulled the brake pedal down and the servo immediately leaks air. Even if suck, pull vacuum, it still pull air.
IS THIS RIGHT? the engine revs then stalls out, sometimes it doesn't stall..But there is a vac leak.
So is this booster shot again, after only a few years and less then 5k miles?
I am replacing the MC right now so I will check for leaks. Check valve is in place and no gasoline in vacuum lines. (another cause if servo failure.)
SUcks, as I am driving to VA from NJ in morning to finally get in some much needed camping..
74 westy
Page 1 of 5
