Are Bosch W8AC Plugs Extinct?
Dougy Dee
Dougy Dee is offline
PostPosted: Wed May 25, 2011 6:36 am    Post subject: Are Bosch W8AC Plugs Extinct? Reply with quote
Local supply here in Canada seems to be drying up with the WR8AC being substituted. I'm not a fan of 'R' or resistor plugs as I've chased problems with them in the past. The NGK cross keeps coming back as a 'R' plug too.
Are we going to have to change over to higher output ignitions to run these or have I just had a bunch of Bad plugs?
Is the resistor there just to suppress ignition noise so your stereo is cleaner or is there some other function?
tripicana
tripicana is offline
PostPosted: Wed May 25, 2011 6:56 am    Post subject: Reply with quote
i think they have discontinued the bosch plugs for our cars. i just cleaned, checked the gap, and threw mine back in.
don't know what a good replacement plug would be, im interested also.
foam cowboy hats aren't good helmets.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed May 25, 2011 7:04 am    Post subject: Reply with quote
Just get NGK B5HS, they will work just fine.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Wed May 25, 2011 9:44 am    Post subject: Reply with quote
the ones I get are B6HS. i think they're a slightly hotter plug.
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
Dougy Dee
PostPosted: Wed May 25, 2011 9:49 am    Post subject: Reply with quote
I've managed to locate some of the Bosch plugs thru an industry contact.
I'll be trying some of the NGK's when this source dries up.
I was wondering if Bosch W8AC availability is a local issue or a global thing???
Mr. 010
Glenn is offline
PostPosted: Wed May 25, 2011 9:59 am    Post subject: Reply with quote
They're colder.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
pupjoint
pupjoint is offline
PostPosted: Wed May 25, 2011 10:05 am    Post subject: Reply with quote
i wont even bother with bosch plugs, just get NGKs
jbbugs
jbbugs is offline
PostPosted: Wed May 25, 2011 3:39 pm    Post subject: Reply with quote
NGK BP6HS has worked well for me for the last 29 years.
Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket!
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Wed May 25, 2011 8:06 pm    Post subject: Reply with quote
Not sure about the W8AC plugs, but the WR8AC plugs should still be readily available. Bosch has introduced this new metal into the mix called Yttrium (whatever the hell that is), and now labeled the plugs "Super Plus". They also have some new BS numbering system. A WR8AC is now crossed over as a #7902. The shop I work at uses the counterpart to the WR8BC, which is a #7903. The #7903 has a protruded electrode that the shop owner feels burns better. I think the resistor plugs have replaced the non-resistor ones. If you need/want the non-resistor ones go with the NGK B5HS (new #4210) Glenn mentioned, or a BP5HS (#4111) for the protruded electrode.
Nirvana92
Nirvana92 is offline
PostPosted: Wed May 25, 2011 8:09 pm    Post subject: Reply with quote
where can i get the ngk B5HS plugs at?? all i can find at advance auto or autozone is BP6HS
1970 beetle 1600 SP with 019 distributor
Bigmeat
Bigmeat is offline
PostPosted: Wed May 25, 2011 8:11 pm    Post subject: Reply with quote
I by mine at napa.
Nirvana92
PostPosted: Wed May 25, 2011 8:14 pm    Post subject: Reply with quote
i always forget about that place Embarassed
[email protected]
PostPosted: Wed May 25, 2011 8:19 pm    Post subject: Reply with quote
Autozone has them listed on their web site, but they're special order. You should be able to get them within a day, or two. Advance doesn't have a listing on their site, but I would imagine they could get them within a couple of days also. Look for them using NGK's new numbering system as #4210
leaker
leaker is offline
PostPosted: Thu May 26, 2011 1:59 pm    Post subject: Reply with quote
Sparkplugs.com shows the w8ac as being obsolete too,and I agree NGKs from Napa,they stock all the weird shit.
The_Codeman
The_Codeman is offline
PostPosted: Thu May 26, 2011 3:16 pm    Post subject: Reply with quote
Also check motorcycle shops they sell them also thats where i get mine
i use the BP5HS work great
www.codemans-bug.com
www.808vwclub.net
didget69
didget69 is offline
PostPosted: Sat May 28, 2011 8:56 pm    Post subject: Reply with quote
Try Carquest; they bought WorldPac some years ago & usually have decent foreign car parts...
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Howard 111
Howard 111 is offline
PostPosted: Sun May 29, 2011 3:32 am    Post subject: Reply with quote
Berg still has them, and several others, listed in their online catalog.
http://www.geneberg.com/advanced_search_result.php?keywords=Spark+Plugs&x=8&y=8
Vw1600dellortoGR
Vw1600dellortoGR is offline
PostPosted: Fri Jun 07, 2013 6:50 am    Post subject: Reply with quote
Will w3ac spark plugs do the job? German bosch are hard to come by
Bashr52
Bashr52 is offline
PostPosted: Fri Jun 07, 2013 7:54 am    Post subject: Reply with quote
Are these the 14 or 12mm plugs? I need to get some 12mm for my new heads.
Dougy Dee
PostPosted: Sat Aug 03, 2013 6:18 am    Post subject: Reply with quote
http://www.ngksparkplugs.com/docs/tech/design_symbols_plugs.pdf
First digit indicates thread size.
ie: 14mm is B.
12mm could be D, DC or J.
Length is the 'E' or 'H' digit which indicates "3/4" or "1/2".
