Speedometer lightbulbs
williambrea
williambrea is offline
PostPosted: Thu Jul 21, 2011 3:07 pm    Post subject: Speedometer lightbulbs Reply with quote
I have a speedometer that matched this one:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113957021
I was wondering if anybody knew where i could buy bulbs to put in it? Maybe advance or somebody would carry a dash bulb I could pop in.
Thanks!
zozo
zozo is offline
PostPosted: Thu Jul 21, 2011 3:38 pm    Post subject: Reply with quote
You can get them from lots of on line sources, including WW, but I doubt your FLAPS would have them.
Bugga
Samba's lil one
Bugga is offline
PostPosted: Thu Jul 21, 2011 4:40 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1145695
Dry Heat Panzers
williambrea
PostPosted: Thu Jul 21, 2011 5:45 pm    Post subject: Reply with quote
Those are nice but where can I buy the non-led lights? I dont need to spend that much money on bulbs right now haha
fluxcap
fluxcap is offline
PostPosted: Thu Jul 21, 2011 6:04 pm    Post subject: Reply with quote
Oreilly's is the only local auto parts store I have ever found them at.
Of course they'll probably only have the 12volt ones. You didn't say if you needed 6 or 12v. If you need 6v, you'll probably have no choice but to get them online.
Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black."
williambrea
PostPosted: Thu Jul 21, 2011 6:11 pm    Post subject: Reply with quote
awesome thanks for the info! If that number doesnt work they should be able to pull it up for a 61 beetle right?
I have 12v his speedo is going in a manx. I just figured this would be a better forum to ask it in.
pOrk
pOrk is offline
50 bucks for those 6 led light bulbs is fukin CRAZY
OReillys has the 12v ones in stock, they can order the 6v ones. Check superbrightleds.com for cheaper bulbs, that guy selling them in the classifieds is on crack.
HAH! I think I found the bulbs that guy is selling, 89 cents each. Not sure if they work with reverse polarity though
http://www.superbrightleds.com/cgi-bin/store/index...htm#ba7-pt
thomas.
thomas. is offline
PostPosted: Thu Jul 21, 2011 6:16 pm    Post subject: Reply with quote
But he does offer free shipping . Wink
BDubVdub
BDubVdub is offline
PostPosted: Thu Jul 21, 2011 6:58 pm    Post subject: Reply with quote
But they are also the only reverse polarity bulbs available for the 3 you need reverse polarity for with no additional wiring required except for an exciter that's needed for an alternator light.
pOrk
pOrk is offline
PostPosted: Fri Jul 22, 2011 1:20 pm    Post subject: Reply with quote
So you have them made and then mark them up crazy sky hiigh and take advantage of fellow VW people? COOL!
BDubVdub
BDubVdub is offline
PostPosted: Fri Jul 22, 2011 4:03 pm    Post subject: Reply with quote
Eh...not really. The mark up is very minimal. Unlike some of the VW stuff I'm sure you've purchased before Confused
I honestly don't make a whole lot off these.
williambrea
PostPosted: Sat Jul 23, 2011 1:08 pm    Post subject: Reply with quote
I went to O'rilleys with those numbers and they couldn't find anything.
Can anybody give me a more specific number?
Thanks!
pOrk
pOrk is offline
PostPosted: Sat Jul 23, 2011 1:26 pm    Post subject: Reply with quote
You want me to pick a pack up and ship it to you? I know for a fact they have them at the Oreilly up the road. They are labeled 14.4 volts but they work just the same, couldn't find the package in the garage or I would get you the exact bulb number.
fluxcap
fluxcap is offline
PostPosted: Sun Jul 24, 2011 4:15 am    Post subject: Reply with quote
Thanks!
The numbers in the picture above (se1274) come up just fine when searching on their website.
You just got a worker that obviously doesn't know how to work a computer. I'll give the worker the benefit of the doubt that they didn't have any in stock and that's why he couldn't find them in the store, but he should have been able to find them in the computer. Go back and ask for somebody different.
http://www.oreillyauto.com/site/c/search.oap?keyword=se1274
pOrk
pOrk is offline
PostPosted: Wed Jul 27, 2011 1:21 pm    Post subject: Reply with quote
You could also make your own Smile
http://www.gerrelt.nl/LED/
tb03830
tb03830 is offline
PostPosted: Wed Jul 27, 2011 1:33 pm    Post subject: Reply with quote
LED is nice but I just bought these, they work fine.
12v: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=N177222
6 V: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=N177221
"Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower.
DesignBuild
DesignBuild is offline
PostPosted: Wed Sep 25, 2024 2:37 pm    Post subject: Re: Speedometer lightbulbs Reply with quote
I know this is an older forum but just in case someone is reading this for bulb information, the speedometer illumination uses a BA7S bulb base and you want a 2Watt or greater. Most of them are 1.2Watt and that is why they are dim. Most LEDs with this base are not worth purchasing because they have a directed light. You want light that spreads. If you want to try an LED look on Amazon for the ones that have a square chip that is exposed; non-focusing. DO NOT GET BA9S as these will not fit; too large.
Another bulb number is 3898 and this has the same dimensions as the original BA7S (VW N177222). See attachment. Shop around because you can find these bulbs for $0.30 each or $5.63 each.
