Isaacbmxer Samba Member
Joined: July 21, 2011 Posts: 41 Location: Roseville California
Posted: Fri Jul 22, 2011 6:14 pm Post subject: 1974 westfalia first car rebuild |
hi im isaac. Im from roseville california im 15.
This is my first car and it is a 1974 orange westfalia
It is from the california gold country and sat there since 1992. It was brought in as scrap to my dads scrap yard. After 15 min of work and new spark plugs we drove it around. It has no rust except for the battery tray.
The inside was striped of the camping gear but had all the seats. There was a full carpet set for the front and back too. After we cleaning it and puting 17 inch eclipse wheels on (i kept the originals) it looked brand new
I wraped the complete panel set from bus depot and used air duct arm rests from scrap part busses at the yard.I put wood on the floor for vinyl flooring
after i put the floor in
Then we took it to kombi haus in sac they went throough it and fixed a lot of the more complicated electrical stuff
and here is where i am now
ill keep updating to show my progress |
Posted: Fri Jul 22, 2011 6:19 pm Post subject: |
Cool to see another bus saved.  |
MalibuLX3 Samba Member
Joined: October 02, 2005 Posts: 839 Location: Ventura, CA
Posted: Fri Jul 22, 2011 6:38 pm Post subject: |
I'll be the first to say it. Check your tires, if they came on the Eclipse wheels, they are passenger tires and not suitable for your bus. Also, change your fuel lines before anything else. You can buy a complete fuel line kit from German Supply that includes everything you need, from the correct diameter and pressure rated fuel line, to the correct style clamps, to the fuel filter, and everything is pre-cut and the correct length to make it very simply.
Now that I've got that out of the way...how did you get those wheels to fit? Adapters?
Great looking bus, I know it would buff out and shine like new! Check out VDubTech's posts for what he uses to buff out his buses to make them shine! _________________ 1978 Westfalia |
Posted: Fri Jul 22, 2011 6:54 pm Post subject: |
| I have changed all of that out already and the tires have held up fine for the past two or three months I've had them on and the wheels fit on no adapter just had to make room for the skrews on the rear drums |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Fri Jul 22, 2011 8:45 pm Post subject: |
Spectacular! You are one lucky 15 year old. So, am I safe to assume that the bus was free? Very nice indeed. You gotta LOVE that orange. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Fri Jul 22, 2011 9:50 pm Post subject: |
Very nice find! I like that you've kept what you found as original intact. Rare for a 15 year old! _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1558 Location: orlando
Posted: Sat Jul 23, 2011 7:40 am Post subject: |
| Isaacbmxer wrote: |
those tires are not meant for the weight of the bus they are fine now. But the sidewalls cannot take that much abuse and will blow out around a corner or possibly on the highway. _________________ 75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus |
Posted: Sat Jul 23, 2011 11:01 am Post subject: |
| Since he hasn't given spec on the tires, how do you guys know they aren't rated properly? From the survey of Vanagons and Bays I did, it appears that over half of them run on passenger tires just fine. Mostly its only in the netherworld of the internet that passenger tires seem to give problems. |
Posted: Sat Jul 23, 2011 11:11 am Post subject: |
| Wildthings wrote: |
X2. Truer words were never spoken.
Same with AMC heads. They certainly aren't the best, but they don't perform nearly as poorly as all the rumor and innuendo would suggest. Maintenance is everything, and these are a viable option for those who can't afford better. _________________ *****************
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Sun Jul 24, 2011 3:35 am Post subject: |
It sucks that every thread is a broken record here. It's always "you have the wrong tires, change your fuel lines, buy a Bentley". _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
Zelten Samba Member
Joined: September 16, 2008 Posts: 1335 Location: Issaquah
Posted: Sun Jul 24, 2011 4:23 am Post subject: |
| Mr. Unpopular wrote: |
| It sucks that every thread is a broken record here. It's always "you have the wrong tires, change your fuel lines, buy a Bentley". |
Did you search? That has been said before.
Nice bus! _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22677 Location: Escondido CA
Posted: Sun Jul 24, 2011 6:00 am Post subject: |
| Westfabulous wrote: |
| Wildthings wrote: |
Same with AMC heads. They certainly aren't the best, but they don't perform nearly as poorly as all the rumor and innuendo would suggest. Maintenance is everything, and these are a viable option for those who can't afford better. |
I just put a repop new Chinese oil cooler on my 1800. I cant wait for it to fail
Come on the raggin aint that bad. For the ammount of repetitive traffic this forum sees, just be thankful people do repeat some of the basics over and over. Otherwise no one would know better  _________________
| t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun Jul 24, 2011 10:03 am Post subject: |
Would you rather it not be said and instead read about a beautiful bus burning to the ground because someone didn't think fuel lines needed to be changed every 5 years... _________________ 1978 Westfalia |
Posted: Sun Jul 24, 2011 1:31 pm Post subject: |
| The tires are rated up to 1 ton |
Posted: Sun Jul 24, 2011 1:32 pm Post subject: |
Desertbusman Samba Member
Posted: Sun Jul 24, 2011 5:11 pm Post subject: |
| Isaacbmxer wrote: |
Wow, that's wonderful.
So just for fun, give us the details in case we want to get some for ourselves. Tell us, brand, model, size, load range, max. pressure, max. load, ply ratings, and anything else of interest. _________________ 71 Superbug
71 Westy |
Posted: Sun Jul 24, 2011 9:12 pm Post subject: |
You are doing a great job, and should be very proud of your bus, and your work. Keep it up young fellar. _________________ *****************
guanella74 Samba Member
Joined: March 13, 2009 Posts: 520 Location: Boulder, CO
Posted: Sun Jul 24, 2011 9:32 pm Post subject: |
Gotta say, I'm a bit jealous! I've got an identical bus, but yours is looking wayyyyy better than mine! What a score.
ROLL that thang!!!
Can't beat the orange plaid - it's a source of secret power, which I'm sure you'll discover soon. _________________ - Travis
1974 Westy CampMobile - the OG!
1979 Transporter
1979 Transporter
1977 Transporter
1974 Transporter
1973 Transporter
1971 Westy |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3109 Location: Tulsa, OK
Posted: Mon Jul 25, 2011 7:07 am Post subject: |
| Zelten wrote: |
Nice bus! |
Quite an impressive thread here, dude. Great job! _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
