Need59 Samba Member
Joined: February 02, 2011 Posts: 2 Location: Carson ca
Posted: Wed Aug 10, 2011 2:13 am Post subject: 1960 Ghia (one year only parts list) |
Hey everyone I have been searching high and low looking for a list of 1960 ghia only parts list. I have found a few but was wondering if anyone has seen one on Samba and can send me a link to it.
1.Gas tank
2.Washer Bottle
3.36hp engine
4.front air grills have 3 mounting screws
5. wiring
6. seats are 58-60 thin backs
7. ?
8. ?
I always tell everyone I am restoring a 1960 ghia and they say how hard it to restore because of all the one year only parts. I ask them what all the parts are and they have no idea..... so any info would help!!! thnks |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14268 Location: Southampton U.K.
wolfgang klinkert Samba Member
Joined: March 04, 2009 Posts: 297 Location: NRW - Germany
Posted: Wed Aug 10, 2011 2:55 am Post subject: |
The following text was copied from this posting:
http://www.thesamba.com/vw/forum/viewtopic.php?t=344617&highlight=model+changes
1960
'60 Model Year (Ch# 2 528 668 thru 3 192 507) August '59 thru July '60
* First Modern Body
* Headlites at tip of fender. (To end)
* Air vent grilles enlarged, bars held by tear-shaped surround. (To end)
* Taillite, pointed oval, at tip of rear fender. (Thru '69)
* Wheel arch openings reshaped. Opening now flows more towards back of car.
* Quarter window hinged and pops-out.
* Ghias still use the famous, venerable 36 hp engine. Split case transmission, with a non-synchro low gear is also standard equipment.
* Last year in which a fuel tap lever as well as fuel gauge was installed.
* Ghia loses its unique steering wheel and horn-blowing ring. Forever after, wheel/ring is an era Bug item.
* An arm rest is first installed on left-hand (driver's door). Previously a cloth strap was used to close left door. Right-hand door always carried an arm rest. (Between 1960 and 1966, a span of only 6 years, 14 different colored vinyl/fabric arm rest covers were used. No wonder finding original, correctly colored interior upholstery material is nearly impossible. Parts departments must have engaged in open mutiny, because from '67-up, all arm rest also fits Beetles. AND were only available in black.)
But I think, the rarest specialities are in a 1966 model.  _________________ With cordial "Karmann Ghia"-greetings from Germany
(O = i = O) ~~~ Wolfgang Klinkert ~~~ (O = i = O)
»»» [Member of "Karmann Ghia IG Lippe in NRW"] ««« |
Need59 Samba Member
Posted: Wed Aug 10, 2011 7:25 am Post subject: |
| Thnks for the body link it had ally of good info. My mistake on the thin back seat. But it is still the same seat from 58-60. Its so strange to me that there isn't a list put together already. Guess I just have to keep doing my research. |
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 378 Location: Calgary, Alberta
pbaptist Samba Member
Joined: January 02, 2005 Posts: 1221 Location: Netherlands
Posted: Wed Aug 10, 2011 11:19 am Post subject: Re: 1960 Ghia (one year only parts list) |
| Need59 wrote: |
1.Gas tank
2.Washer Bottle
3.36hp engine
5. wiring
7. ?
8. ?
What do you call 1960 only?
Some parts were still the "old style" while the body had the "new style"
the 1960 model still had the old gas tank, old seats, old engine compartment sheetmetal, old brake fluid reservoir and the choke cable
1960 specific parts are
Fuse box
The wiring harness is 1960 only
Sscrew terminal rearlight
The front grills that are attached with three screws
Wwindshield washer bottle and washer bottle knob
Outside door window trim moldings _________________ Dutch Karmann-Ghia and coachbuild lover.
1* Karmann Ghia Coupe (1966 Teak)
2* Karmann Ghia Convertible (1958, 1971)
4* Rometsch Lawrence (nr 534, 555, 558 and 561)
Karmann-Ghia Lowlight page and registry
Karmann-Ghia Collectibles database |
retrowagen Samba Member
Posted: Wed Aug 10, 2011 12:51 pm Post subject: |
I agree with Patrick, and would also add that the front seat upholstery pattern (the piping) is slightly different on the August 1959-July 1960 cars versus the earlier 16 September 1957-July 1959 cars. The seat structures beneath are, however, the same. _________________ David Ruby
President, Karmann-Ghia World Club |
lemke Samba Troll
Joined: February 24, 2004 Posts: 1249 Location: Seattle
Posted: Wed Aug 10, 2011 3:46 pm Post subject: |
| 1960 had a one year-only passenger front floor mat - It's pretty much the same as the later models, but it has "slit/oval" shaped mounting holes at the top instead of the round holes. |
