Retrofitting an 2.1L Oil Cooler into a 1.9L Digijet
windnsea
windnsea is offline
PostPosted: Thu Aug 11, 2011 1:34 am    Post subject: Retrofitting an 2.1L Oil Cooler into a 1.9L Digijet Reply with quote
Hey group!
I finally got my 2.2L wasserboxer mit digijet fuel injection running properly after putting in a 3-wire O2 sensor!! Mileage is now 19+ in town, ~22 on the open road, and ~26 on backroads @ 50 mph in Central California!
Though I've never had any overheating at all in almost 28+ years as using DAS BOX as my primary driver, and have regularly changed the oil and everything else, I've got a question, which is as follows:
I've got the parts available to retrofit a 2.1L digifant oil cooler to my 2.2L digijet engine. If I was to go ahead I would not do a digifant retrofit to make it a water to oil cooler, but rather I'd route a hose up into the left rear D-pillar to catch it's air flow to be used as the cooling medium rather than doing a rather significant restructuring of the water cooling hoses in the back left side of the engine. I'd make a pressure routing of air with all possible moisture draining without entering the oil cooling duct.
Any comments?? I'd appreciate any feedback that my fellow Sambanistas could throw at this idea!!
Windnsea
BTW, DAS BOX is now approaching 300,000 miles of enjoyed driving, and is starting to whisper as I sleep ( WRX STI, WRX STI,WRX STI,WRX STI)!
Is this like those Canadian Vanagons chanting "Wheetabix, Wheetabix, Wheetabix" ?
I think that those Canuck Vans need more fiber under their wheels!!
Windnsea
Wellington
Wellington is offline
PostPosted: Thu Aug 11, 2011 2:55 am    Post subject: Reply with quote
More details on the 3 wire oxy sensor please.
Not sure of your explanation of retrofit 2.1 system, but I'd rcommend 10cents cooler system or your own of the same variation. Chris has put together a kit to same you all the time and trials,
bquigs
bquigs is offline
PostPosted: Thu Aug 11, 2011 8:41 am    Post subject: Reply with quote
If I understand you right you would use the water/oil cooler but run air though it instead of water? I don think this would be efficient enough to do anything at all even if you were to get an air flow through there which is unlikely. Water absorbs much more heat than air so the water/oil cooler is small and doesn't have much surface area for heat transfer. What you need is a radiator in the D piller that you move the oil through.
87 Syncro Zetec
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Aug 11, 2011 10:24 am    Post subject: Reply with quote
It is NOT an oil cooler. It is a heat exchanger. Or "stabilizer." It will want to make the water and oil the same temperature. Not much gain there when you talk about cooling.
Mount an external air oil cooler. There are posts on this topic. Might start in the FAQ.
FYI: *IF* current engine is running so well, leave it alone. Do as I did and just build up another newer van. I did and love it. The Suby really makes the van fit in with traffic and even more a joy to drive. My $0.02.
Spinal Tap
Spinal Tap is offline
PostPosted: Thu Aug 11, 2011 12:25 pm    Post subject: Reply with quote
If you want to add an oil cooler, talk to Tencentlife. He has a nice kit for adding cooler to both the 1.9l and 2.1l.
'85 Westy
'74 MG-B
RCB wrote:
Its called tact...and tact is the ability to tell someone to go to hell in such a manner that they anticipate the trip.
Cygnus
Cygnus is offline
PostPosted: Thu Aug 11, 2011 2:41 pm    Post subject: Reply with quote
I would also be really interested in the details of adding a 3 line o2 sensor to a digjet with a 2.1 because my single wire sensor is out I believe and I have that same setup.
Thanks,
-Brian E.
Captain Pike
Captain Pike is offline
PostPosted: Thu Aug 11, 2011 8:29 pm    Post subject: Reply with quote
It will not fit with a 1.9 exhaust.Done.
Wildthings
Wildthings is offline
PostPosted: Thu Aug 11, 2011 10:45 pm    Post subject: Reply with quote
300,000 miles without needing it! Why would you want to add anything that isn't necessary, adds complexity, and has a failure mode? If you are worried about the oil being negatively affected by heat, run synthetic instead of dino.
Cygnus
Cygnus is offline
PostPosted: Fri Aug 12, 2011 7:17 am    Post subject: Reply with quote
Hmmm, being that its a 2.1 engine, how can I be sure that I have a 1.9 exhaust? Are they interchangeable?
Thx,
-B
klucz
klucz is offline
PostPosted: Fri Aug 12, 2011 8:18 am    Post subject: Re: Retrofitting an 2.1L Oil Cooler into a 1.9L Digijet Reply with quote
windnsea wrote:
Mileage is now ... ~26 on backroads @ 50 mph in Central California!
Really?
84 Westy 4spd sold
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Aug 12, 2011 10:14 am    Post subject: Reply with quote
I know of another one with over 300K miles on it too. NEVER been split apart or heads off.
You got to figure the math says there must be a few that beat the curve.
It DOES happen.
Ahwahnee
Ahwahnee is offline
PostPosted: Fri Aug 12, 2011 3:45 pm    Post subject: Reply with quote
I think the Cap'n was referring to the 2.1 oil/water heat exchange.
You should have no problem putting a 3-wire O2 sensor on a 1.9 or 2.1 or whatever if that is what you want. Desirability may depend in part on where you live and how you drive.
Cygnus
Cygnus is offline
PostPosted: Sat Aug 13, 2011 6:45 am    Post subject: Reply with quote
Ah Thanks, didn't mean to derail the thread. I will go ahead and get a 3 wire.. My 85 runs pretty hot - I have looked at those oil coolers but it seems a bit too fiddly. I am going to start by going after my radiator - I suspect it is getting clogged.
-B
