My attempt at a transaxle cooler (manual trans)
Page: 1, 2, 3, 4, 5, 6  Next
Alaric.H
Alaric.H is offline
PostPosted: Wed Aug 10, 2011 6:36 pm    Post subject: My attempt at a transaxle cooler (manual trans) Reply with quote
I my experimenting with a transaxle cooler/filter for my syncro to see if the oil temps drop on the highway right now it runs at 170-185 on hot day and steep hills.The temp sensor in the trans starts the cooling pump at 150deg and shuts it off at 135deg it can not hurt to filter the oil as well.
Outback Kampers
Outback Kampers is offline
PostPosted: Wed Aug 10, 2011 7:30 pm    Post subject: Reply with quote
Looks good, colorful. Wink Where did you locate the pump? I would recommend a guard of some sort for the lower hose, it would be bad to snag it going over some trail debris and lose all the oil.
Karl Mullendore
1990 Syncro 16" sunroof Reimo highroof conversion
1990 Westy Multivan 112i automatic
1992 LT31 Karmann Distance Wide 'La Tortuga'
2014 Touareg X TDI
Alaric.H
Alaric.H is offline
PostPosted: Wed Aug 10, 2011 7:43 pm    Post subject: Reply with quote
Not to worry the skid plate covers all of the hoses.I got the pump from here.
http://www.rbracing-rsr.com/oilsystems.htm
Outback Kampers
PostPosted: Wed Aug 10, 2011 7:52 pm    Post subject: Reply with quote
Oh, yeah, skid plate... forgot that! Laughing
I meant where is the pump located, photo please? <edit - I see it now, the white thing?>
Karl Mullendore
2014 Touareg X TDI
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Aug 10, 2011 8:30 pm    Post subject: Reply with quote
Looks like a pretty simple worry free set up Cool
insyncro
Banned
insyncro is offline
PostPosted: Thu Aug 11, 2011 5:58 am    Post subject: Reply with quote
Interesting.
I see Weddle did similarly for EricA.
Curious to know if a drop in temp will help the longevity with a more powerful engine.
RicoS
RicoS is offline
PostPosted: Thu Aug 11, 2011 7:50 pm    Post subject: Re: My attempt at a transaxle cooler Reply with quote
Alaric.H wrote:
I my experimenting with a transaxle cooler/filter for my syncro . . .
You're reinventing a wheel -
http://vanagonsyncroproject-herman.blogspot.com/2007/02/transmission.html
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02#5041246109161147426
Richie
RicoS
RicoS is offline
PostPosted: Thu Aug 11, 2011 8:06 pm    Post subject: Reply with quote
I like Herman's idea of using a power steering pump much better. Modern power steering pumps are a proven quantity, last damn near forever, are directly driven and cheap to boot.
Richie
Outback Kampers
PostPosted: Thu Aug 11, 2011 8:16 pm    Post subject: Re: My attempt at a transaxle cooler Reply with quote
Richie
No, not at all the same setup. Alaric's is plug in and go, no internal oil channels, drilling etc. That's hardly what I'd call 'reinventing' anything. Rolling Eyes
Karl Mullendore
2014 Touareg X TDI
HeftySmurf
HeftySmurf is offline
PostPosted: Fri Aug 12, 2011 8:45 am    Post subject: Reply with quote
Looks good Alaric
-Lorenzo
90 GL w/ Bostig
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Aug 12, 2011 8:48 am    Post subject: Reply with quote
Is the silver cylinder in between the drain plug and the pump a check valve?
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
snowsyncro
snowsyncro is offline
PostPosted: Fri Aug 12, 2011 9:17 am    Post subject: Reply with quote
That might be the filter that he mentioned.
Looks good.
Alaric.H
Alaric.H is offline
PostPosted: Fri Aug 12, 2011 10:37 am    Post subject: Reply with quote
That is the reusable filter.
Zeitgeist 13
PostPosted: Fri Aug 12, 2011 10:53 am    Post subject: Reply with quote
Ah hah! When you mentioned a filter, my mind automagically went to a spin-on design and wouldn't move off that thought.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
squeegee_boy
squeegee_boy is offline
PostPosted: Fri Aug 12, 2011 12:04 pm    Post subject: Reply with quote
What size AN adapters did you use for the fill/drain port connections? I've been mulling over the same thing, but wasn't sure where to attach the inlet/outlet.
Very cool, BTW.
Robyn
1984 FrankenSyncro Westy. EJ25 RMW kit
Alaric.H
Alaric.H is offline
PostPosted: Fri Aug 12, 2011 8:20 pm    Post subject: Reply with quote
Very cool, BTW.
Robyn
Lets see the fill is1/2 npt the drain is 24x1.5
and the hole you drill in the bottom of the trans for the temp switch is 3/4x16.
Alaric.H
Alaric.H is offline
PostPosted: Fri Aug 12, 2011 8:29 pm    Post subject: Reply with quote
I fired it up to prime it and the hose started weeping gear oil just about the whole length pretty good size mess bad hose I guess.
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Aug 13, 2011 5:27 am    Post subject: Reply with quote
And why do you think you need a transaxle cooler? Does it really run that hot?
Alaric.H
Alaric.H is offline
PostPosted: Wed Aug 24, 2011 5:26 am    Post subject: Reply with quote
I have driving with the trans cooler for a few thousand miles now and looking at the temp gauge there is a 40 deg drop in temp. In FL I unplugged it and the oil temp went to 183deg so I pulled over and plugged the pump in and the oil went to 145 deg in less than 2 minutes.I am in MI now and the out side temps are much lower so it is running at 115-125 deg the biggest difference is the shifting where it was very hard or notched to go in to gear it is looser now so shifting is easier.
chojinchef
chojinchef is offline
PostPosted: Wed Aug 24, 2011 6:01 am    Post subject: Reply with quote
Thats a sexy setup.
Cant imagine here in New England that the internal temps are as high as in other parts of the country, but that looks like a great solution.
Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory.
Page 1 of 6
