curtis4085 Samba Member
Posted: Thu Sep 29, 2011 11:48 am Post subject: Undercoating? Yes again. |
Just wanted to get the latest and greatest undercoating ideas. And possible down falls. I had very little rust underneath yet i did do some por-15 work. So the problem being is I have black por-15 spots that need to be covered up and also want to protect what I have. My paint guy has a black rubberized product that they use on the bottom panels of cars to protect from rocks and suggest that this would be a great application for the entire bottom of vehicle. I am curious what is the best method for a tight looking undercarriage. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
airkooledchris Samba Member
Posted: Thu Sep 29, 2011 11:57 am Post subject: Re: Undercoating? Yes again. |
curtis4085 wrote: |
I am curious what is the best method for a tight looking undercarriage. |
a gym membership and good genetics.  |
Posted: Thu Sep 29, 2011 11:59 am Post subject: Re: Undercoating? Yes again. |
airkooledchris wrote: |
curtis4085 wrote: |
Jalabert Samba Member
Joined: December 06, 2005 Posts: 680 Location: On the coast in NZ, somewhere...
Posted: Thu Sep 29, 2011 12:00 pm Post subject: |
I sprayed waxoyl into all the open box sections and around seams (anywhere I could get the stuff), coated the whole thing with an epoxy-based stone chip which sounds like what your guy is suggesting, then a traditional underbody wax on top of that. That was nearly four years ago, the underbody wax has almost dried out enough for me to consider stripping it off and reapplying, the stone chip is in great shape, no rust or visible decay underneath of any sort.
There is a guy near me who does underbody stuff who will do that and the cavities with waxoyl again for about 150 - 200$ (NZ), although I reckon that's so low as to be atypical - I can't see how the guy makes a profit, let alone justifies covering himself in shit every day. I know not everyone likes the look of underseal or rustproof on their bus but I guess it depends on where you live and how much you hate rust. _________________ '73 westy, 1700 type 4 with 34icts |
Posted: Thu Sep 29, 2011 12:11 pm Post subject: |
Jalabert wrote: |
There is a guy near me who does underbody stuff who will do that and the cavities with waxoyl again for about 150 - 200$ (NZ), although I reckon that's so low as to be atypical - I can't see how the guy makes a profit, let alone justifies covering himself in shit every day. I know not everyone likes the look of underseal or rustproof on their bus but I guess it depends on where you live and how much you hate rust. |
yours sounds nice. just curious. Mine appears to have had wax/oil some 32 years ago. the por-15 is sticking should i worry about the undercarriage coating adhearing properly. He is using something that comes in caulking tube and they spray on. very rubbery. You see the stuff on new cars in wheel well joint ( where all the body metal pieces come together) _________________ Special Thanks to:
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42455 Location: at the beach
Posted: Thu Sep 29, 2011 12:24 pm Post subject: |
I have been told by several restorers use waxoyl, cosmoline or home brew waxoyl but not the rubber stuff. It can get just loose enough in sections that water will wick behind it and cause rust. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Sep 29, 2011 12:34 pm Post subject: |
SGKent wrote: |
I have been told by several restorers use waxoyl, cosmoline or home brew waxoyl but not the rubber stuff. It can get just loose enough in sections that water will wick behind it and cause rust. |
ok. I can accept that. Any ideas how to fix the black por-15 spots then underneath? was thinking spray them green then wax/oil? _________________ Special Thanks to:
Brionp Samba Member
Posted: Thu Sep 29, 2011 1:38 pm Post subject: |
I am old school probably to a fault. My bus already has the grey undercoating on it. I am using 3M Body Schultz to spruce up the undercoating. You have to have a special gun and a compressor to apply it. But it dries hard and is paintable. And Rustoleum Semi Gloss Black out of a can everywhere else. Most of the time I apply the Rustoleum with a disposable foam brush. I love those things. Sometimes I will use my touch up gun.
Posted: Thu Sep 29, 2011 1:43 pm Post subject: |
Brionp wrote: |
I am old school probably to a fault. My bus already has the grey undercoating on it. I am using 3M Body Schultz to spruce up the undercoating and Rustoleum Semi Gloss Black everywhere else.
super nice.. love it _________________ Special Thanks to:
Busdriver79 Samba Member
Joined: July 22, 2011 Posts: 1655 Location: The Peoples' Republic of "No" Jersey
Posted: Thu Sep 29, 2011 4:45 pm Post subject: rust prevention |
for all those hard to reach areas such as inside the doors and the drain holes in the rocker panels i used a spray product called LPS#3......it sprays easily through a straw tube provided and dries to a waxy finish.....it can be wiped off if necessary and it does a great job of repelling moisture and waterproofing everything it comes in contact with....i have used LPS#3 over the years successfully on many cars with excellent results......it is available in most hardware stores and home depot for about $5 a can.....LPS#2 is a fine lubricating oil,.... and LPS#1 is a good penetrating oil...... |
Heliconman Samba Member
Joined: August 08, 2008 Posts: 283 Location: Minnetonka, MN
Posted: Thu Sep 29, 2011 6:06 pm Post subject: Re: rust prevention |
mschiffel wrote: |
We use it on aircraft at work. I did not know it was available at local stores. I never seen it outside of work. |
Brionp Samba Member
Posted: Thu Sep 29, 2011 7:06 pm Post subject: Re: rust prevention |
mschiffel wrote: |
X3
I discovered LPS#3 about 6 months ago. Heavy Duty Rust Inhibitor. The can says it lasts two years |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5492 Location: North Texas
Posted: Thu Sep 29, 2011 7:53 pm Post subject: |
Home Depot has it? I think thats the thing Colin recommends. I'll have to check my notes. What color is it? _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
Posted: Thu Sep 29, 2011 8:11 pm Post subject: |
Brionp wrote: |
what product did you use for painting your axle. nice black clean look _________________ Special Thanks to:
Desertbusman Samba Member
Posted: Thu Sep 29, 2011 9:08 pm Post subject: |
Don't just slop undercoating on it. Totally clean every portion of the undercarriage. Scrape off everything loose and get down to good clean metal or the original undisturbed primer. Oven cleaner works fantastic but mainly tons of elbow grease. Take off any original undercoating. Dig out all the seam sealer. That's where the worst rust problems will start at seams and joints. Sandblast any questionable areas. POR 15 on any rust areas. Prime it all with a good rust preventative primer. Then apply new good body seam sealer to all the seams averywhere. Otherwise moisture will get in the seams and joints. Then prime paint all the seam sealer. Then finish with a good heavy application of a good oil based rust preventative enamel.
Then, and only then, put on whatever undercoating you deem best suited. And you can coat inside the hidden area access holes as some have mentioned. _________________ 71 Superbug
71 Westy |
Brionp Samba Member
Posted: Thu Sep 29, 2011 9:43 pm Post subject: |
The beam and trailing arms were done with Rustoleum Oil Based Enamel. Semi Gloss Black. I sprayed it on with a Binks 115 Touch up gun. They were sanded and primed first. DBM is correct in his prep but after all of that work you might as well paint everything with the same paint as the top of the bus. Like he did. And park it on mirrors. I would. I used scrapers, putty knives, big stiff wire brushes like you clean a BBQ Grill with and a Makita Grinder with a Braided Wire Cup Brush. The one that goes 10,000 RPM and will shred you in a heartbeat if you daydream. It takes alot of time and at the end of the day you look like a Coal Miner at the end of the shift. But if anything is still sticking on after that. It stays. I plan on driving the shit out of this bus when I retire. And it is the underside of the bus. I'm pretty Anal and have OCD but I'm trying to lighten up. I'm on the downside of things and I don't need it to last forever. Just 10 or 15 more years is all I hope for. I'm leaving some work for the next owner. You know, they will have to put some effort into this also. Just so they don't take it for granted.
Posted: Thu Sep 29, 2011 9:46 pm Post subject: |
Desertbusman wrote: |
Then, and only then, put on whatever undercoating you deem best suited. And you can coat inside the hidden area access holes as some have mentioned. |
the goods you dish..thank you Desertbusman. I have currently the 32 year old oil wax on it. I have wire wheeled and scrapped just the areas with rust (not really much rust at all) and treat and por-15 those areas. I guess next step is to strip old oil/wax undercoating. was hoping to use a product I found that is a black wax undercoating to go over the old yet very good no rust under coating without having to remove it. I guess that would be cutting corners? Just wondering if whats there is good no rust just dirt ugly look and i coat with same type product but with black pigment in it to help give a nice solid black undercarraige. I do not want to cut corners at all. _________________ Special Thanks to:
Posted: Thu Sep 29, 2011 11:06 pm Post subject: |
It also seemed like Rustoleum primer and paint was about the best practical choice for the type of protection that it needs. Mine was color matched the same as the original body and interior paint. But the top is primer and it will remain primer. Underneath where the original undercoating was intact and still good is where the best condition of the steel was. But where the undercoating had come off or was dried and flakey is where the worst spots were.
The choice of what you do probably depends a lot on where you are located. In my case the concern was just being able to keep it clean. Where dirt and junk builds up is where moisture collects and causes the rust. And after these years there arn't any rock chips so no new undercoating probably was the good choice.
What makes it all interesting is that VW kept changing the methods of dipping the body, the type of chemical protection and prime painting and also the type of final protection or undercoating. Earlies had none of the waxy stuff. The heavy tar/rubberized undercoating was either done at the factory after it was all assembled or it was a dealer option. For yours I'd think the main thing is getting it real clean before you paint or coat it with anything.
https://www.thesamba.com/vw/gallery/pix/338626.jpg
https://www.thesamba.com/vw/gallery/pix/338625.jpg
https://www.thesamba.com/vw/gallery/pix/338624.jpg
https://www.thesamba.com/vw/gallery/pix/440600.jpg
https://www.thesamba.com/vw/gallery/pix/718267.jpg
Try some oven cleaner and see if it helps removing your wax, grease, and dirt. The old generic bad smelling stuff works much better. I used many cans of it. Be super cautious of safety breathing issues. That stuff gets real bad. _________________ 71 Superbug
71 Westy |
Posted: Thu Sep 29, 2011 11:47 pm Post subject: |
Try some oven cleaner and see if it helps removing your wax, grease, and dirt. The old generic bad smelling stuff works much better. I used many cans of it. Be super cautious of safety breathing issues. That stuff gets real bad. |
great pictures _________________ Special Thanks to:
