Color for gas tank - Oval Beetle
Page: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
PEPPE
PEPPE is offline
PostPosted: Sun Oct 31, 2004 6:05 am    Post subject: Color for gas tank - Oval Beetle Reply with quote
i have a 01/55 oval, color L41 black. i have to repaint the gas tank, that is the large filler one. og paint appears to be dark gray as color, but on several restoration appreat to be usually repainted black.
which is the correct color? thanks, Peppe
From later in this thread
Gary Bell wrote:
Ok so I finished sanding out my tank tonight...... Sanding the clear down to get ready for the L29 blue grey.
I have hunted down the mix for Glasurit:
VOLKSWAGEN - L29 BLUE GREY
Glasurit Line 22
Target ltr kg
Base Amount Cumulative UNIT
M26 358.3 358.3 g
M60 290.3 648.6 g
M974 39.4 687.9 g
M77 13.1 701.1 g
522-322 380.5 1081.5 g
I am not sure what we are going to do about matching the gloss but will let you guys know.
EnzoRocks wrote:
I got this off the Glasurit web site...my local glasurit shop didn't know what the code was. This is for the 22 line and then the 68 line.
VW - L29 1955-1955
BLUE GREY AD2220
22 Date: 23.08.05 PG: I
M+A Farben 200 g 0,3 l 0,5 l 1 l 1,5 l
M26 66,2 107,7 179,6 359,1 538,7
M60 53,7 195,0 325,1 650,0 975,1
M974 7,3 206,8 344,8 689,4 1034,3
M77 2,4 210,7 351,4 702,6 1054,1
522-322 70,4 325,2 542,1 1084,1 1626,2
VW - L29 1955-1955
BLUE GREY AD6801
68 Date: 06.09.05 PG: I
M+A Farben 200g 1 l 2,5 l 3 l 5 l
T920 65,1 351,9 879,7 1055,6 1759,4
T002 108,2 584,7 1461,8 1754,1 2923,5
T900 115,3 623,3 1558,4 1870,0 3116,7
T141 117,7 636,2 1590,6 1908,6 3181,0
568-403 200,0 1080,8 2702,0 3242,4 5404,0
Black58EuroBug
Black58EuroBug is offline
PostPosted: Sun Oct 31, 2004 6:12 pm    Post subject: Reply with quote
Hi! A black tank is a replacement tank or a repainted tank, the correct color of an original tank from 10-52 until the early 1960s is L29 gray-blue, I tried tracking this code down and it is impossible to find anywhere. However, there are a couple other pieces in the car also painted the same color, such as the two piece heater connection covers under the rear seat and you can drop off a piece and have the color matched.
Kimberly
9/9/57 European Beetle L41 "Schnitzel"
PEPPE
PEPPE is offline
PostPosted: Mon Nov 01, 2004 2:00 am    Post subject: Reply with quote
thanks, i wil find a match paint. i will provide a code so that all can have a usable color code.
Mr. Bungle
Mr. Bungle is offline
PostPosted: Mon Nov 01, 2004 5:37 pm    Post subject: Reply with quote
good info, black58.
and good job on your site.
Jerry J
Jerry J is offline
PostPosted: Fri Nov 19, 2004 11:23 am    Post subject: Reply with quote
PEPPE, have you had any luck coming up with a paint code or paint ID?
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
PEPPE
PEPPE is offline
PostPosted: Thu Feb 10, 2005 5:34 pm    Post subject: d Reply with quote
Sorry for the delay.
We found the closer match is RAL 7011 from Standox. Paint man however corrected a little bit the phormula by eye
As soon as I paint it i will post photoes.
radrob
radrob is offline
PostPosted: Thu Feb 10, 2005 8:43 pm    Post subject: Reply with quote
I bought this tank already restored and this was the color. Not sure if its the right color though.
John
John is offline
PostPosted: Thu Feb 10, 2005 8:57 pm    Post subject: Reply with quote
As far as I could tell the top picture is my untouched 57 tank painted the original color....the bottom picture is my attempt to match it. It's way too light.
John
Wiggy
Wiggy is offline
PostPosted: Thu Feb 10, 2005 10:49 pm    Post subject: Reply with quote
Unrestored tank on my 55 vert:
After resto:
Definately a bluish gray.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
Sommer86
Sommer86 is offline
PostPosted: Fri Feb 11, 2005 5:30 pm    Post subject: Reply with quote
the same would go for a '57 oval hardtop right??? I just might repaint mine now. Thanks
Mike
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
RareAir
RareAir is offline
PostPosted: Fri Feb 11, 2005 8:12 pm    Post subject: Reply with quote
2splits wrote:
After resto:
What's the consensus on body color-matched fuel tanks? Most of the Convertibles I've seen have body color-matched fuel tanks, especially Iris Blue cars.
Wiggy
Wiggy is offline
PostPosted: Fri Feb 11, 2005 8:14 pm    Post subject: Reply with quote
[email protected] wrote:
2splits wrote:
After resto:
Not on 55's.....guaranteed.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
Wiggy
Wiggy is offline
PostPosted: Fri Feb 11, 2005 8:21 pm    Post subject: Reply with quote
Hard to tell from the pics, since the OG gray looks similar to the bluish gray. But I had both color matched and they are definately different.
Now, split convertibles I believe had body colored tanks.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
Wiggy
Wiggy is offline
PostPosted: Fri Feb 11, 2005 8:25 pm    Post subject: Reply with quote
On this pic, look at the very right of the tank compared to the body...you can see they are different....
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Feb 11, 2005 10:07 pm    Post subject: Reply with quote
I see lots of high dollar restorations that miss this little fact. If you paint your tank gloss black you're gonna lose points when the car is judged. L41 was never a tank color. Wink
vwovalguy
vwovalguy is offline
PostPosted: Fri Feb 11, 2005 10:08 pm    Post subject: Reply with quote
My 57 unrestored vert has a color-matched tank in shetland-grey metallic
Will post a pic later
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Feb 11, 2005 10:09 pm    Post subject: Reply with quote
That is pretty damn close. Very Happy
Wiggy
Wiggy is offline
PostPosted: Fri Feb 11, 2005 10:16 pm    Post subject: Reply with quote
Agree. Most splits should have had a dullish black gas tank.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
coad Premium Member
Samba Scapegoat
coad is offline
PostPosted: Fri Feb 11, 2005 10:24 pm    Post subject: Reply with quote
I'm not arguing with you guys, but if only replacement tanks are black there must be one heck of a lot of replacement tanks out there. My old 54 had a black tank and I'm 99% certain that it had never been hit or had a reason to have the tank replaced.
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Feb 11, 2005 10:30 pm    Post subject: Reply with quote
Was your old '54 a black car? Confused
Page 1 of 10
