C and D Load Tires
speedtek
speedtek is offline
PostPosted: Mon Jul 04, 2011 10:05 pm    Post subject: Reply with quote
Bercilak wrote:
Speedtek,
You've already been told that VW never used a tire rated below 1580.
If you want to use tires rated at a lower value, go ahead. Just don't walk in here and tell everyone that you're right and they're wrong. You're wrong. Fact.
B.
VW also never used a tire wider than a 205 so your assumption I'm wrong is based on the worst possible evidence.......none at all. Extrapolating a trend to spec lower ratings when using wider tires actually proves that I may be correct. Whether or not my exact rating that I personally use is what "VW woulda done" is pure conjecture on anyone's part because they never did it.
So, at the end of the day I'm not wrong, I'm not right either, but the choice I've made is based on an educated guess knowing my vans weight specifications. When you're pushing the envelope that's the best anyone can do. Now, if you can jump off your high horse for a couple minutes, you will be able to see there is truth in what I am saying.
Either way, I said what I came to say, this is a topic in which there are two camps and unfortunately it's one of those that people feel the need to tear each other apart over. Everybody's an expert when it comes tires Rolling Eyes (no, I'm not excepting myself) and it's kind of like criticizing someone's driving.... Wink
vanjoe
vanjoe is offline
PostPosted: Mon Jul 04, 2011 11:18 pm    Post subject: Reply with quote
I can't believe this tire BS goes on and on and on and on. The facts are already written in all the documents throughout the past tire posts from very trustworthy vendors. I really hope the moderators put a stop to this bullshit tire crap on here.
1990 VW Vanagon tin top weekender Carat
1998 Mercedes S420
"Why is there never time to do it right the first time, but there is always time to do it twice?"
"Back to the basics!"
speedtek
speedtek is offline
PostPosted: Tue Jul 05, 2011 2:27 am    Post subject: Reply with quote
Unfortunately, said trustworthy vendors are also in two opposing camps on the matter (busdepot vs gowesty for example).
Personally, I do feel gowesty's solution is less than I would choose (and many others) however, their basic argument holds water.
The topic keeps coming back because it is one of those issues that really has never been resolved (except in the minds of both opposing viewpoints) There's no reason we can't have a civil discussion about it, however there are always people who take things far too personally and things tend to spiral down from there.
The funniest thing is, of all the auto forums I've belonged too...this is the only one I've ever seen that gets their panties so twisted over tire choices and specs. Weird ......... Confused
Tire choice and proper tire maintenance is a subject that is VERY near and dear to my heart......a few years ago I was in a really bad accident in my Audi S6 when a family lost control in icy road conditions and came across my lane. Their tires on the Neon were half bald and erratically worn (indicating badly worn suspension components as well).....people like that are far more dangerous than those of us doing the research and making informed choices as well as maintaining our vehicles properly.
Have a read, my tires were almost new Dunlop winter sport 3d at the time.
http://forums.audiworld.com/showthread.php?p=23745607
I ALWAYS inspect my tires every couple of days as well as weekly tire pressure checks. Can most here say the same?
Jon_slider
Jon_slider is offline
PostPosted: Tue Jul 05, 2011 8:58 am    Post subject: Reply with quote
the 205R16 104 Q I think means load range C, 1984 lbs @50psi
the 195R16 8PR 107 N I think means load range D, 2149 lbs @ 65 psi
the 6.5R16 10PR 108 N I think means load range E, 2205 lbs @ 80psi
data here
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=35 and
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=55&
> The load index goes up some, but not really any unexpected things are there? Am I missing somehting?
yes, you are missing the difference between C, D and E rated sidewalls (6 ply, 8ply 10ply), versus Passenger tires with unreinforced sidewalls, that are NOT appropriate for a vanagon, IF you want to follow the doorjamb specs.
Honda chooses to use a 65% profile passenger tire with a 35psi max inflation. VW never used a 65% profile passenger tire on a Vanagon. But you can if you want to.
Even if a passenger tire carries the same load as an UNDERINFLATED C, D, or E rated tire, that does not make the passenger tire equally "strong". imho "strong" refers to sidewall strength, not load capacity. Passenger tires are not strong enough to inflate to the pressures used on tires with C D or E rated sidewalls.
GWTWTLW
GWTWTLW is offline
PostPosted: Tue Jul 05, 2011 10:10 am    Post subject: Reply with quote
levi wrote:
What happens next is not fun to think about.
Hence, the wheelchair in the pic next to the van........
That was actually a stroller for my (then) 4 year old. Not fun to think about either but fortunately he wasn't with me.
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Jul 05, 2011 10:43 am    Post subject: Reply with quote
Jon, I get that part.
I will never go back to running passenger car tires on my buses as they handle poorly and are more subject to failure when pushed over the limit. My tires are indeed rated as "6 ply" (Vredestein Comtracs 205/65/15) and "8 ply" (Hancook 195R14).
My question is this....
If you are running 16" or 17" wheels with adequately rated bus tires (6, 8, or 10 plys and with an adequate load index ) why would you have to push the inflation pressures way up past what VW said to when these things were new? Example, my inflation sticker says to be at 30 psi front and 44 psi rear. That is where I keep it and it handles quite well. I personally don't think the tire's "contact patch" on the road really matters very much at all when it comes to correct tire pressure.
If I were going to put on 17" wheels (not going to happen BTW) why would I want to go way up in tires pressure as suggested by others here?
Wouldn't the tire pressures be relatively the same even with differnt sized tires as what the sticker says? I can understand it going up a few PSI, but not 20 or 30 psi. I would think that would really throw the handling way off.
Much like a beetle with the front tires inflated to 32 psi as opposed to the VW suggestion of 17 psi? The handling is lousy as you are just using the middle 1" of the tire.
Am I thinking this out correctly?
Typhon2222
Typhon2222 is offline
PostPosted: Tue Jul 05, 2011 11:16 am    Post subject: Reply with quote
Jon_slider wrote:
here is the formula to match VW doorjamb
front 1212/your tire max load x your tire max psi
rear 1492//your tire max load x your tire max psi
Afraid I'm very very ignorant about tires. Embarassed Could some kind soul confirm that I'm doing the math right here?
The doorjamb on my '88 Westy calls for 185R14C tires, at 39 PSI (front) /48 PSI (rear).
Our current tires are Signet/Nexen SV-820 (Signets on front, newer Nexens on the back, but I guess they're the same tire, just different name?) They're rated:
“185R14 — LT — 8 P.R. — Load Range D”
“Max load Single 1875 lbs at 65 P.S.I. cold”
So if I crunch the figures correctly, I should inflate to 42 PSI front, and 52 rear? Question
Basil — '88 Dove Blue Westy.
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Jul 05, 2011 11:39 am    Post subject: Reply with quote
That's about what I get when I do the numbers (by that formula) for my Hankooks. I have always used the door jamb spec for those but may try the slightly higher pressure as see how it feels/rides/handles.
0to60in6min
0to60in6min is offline
PostPosted: Tue Jul 05, 2011 12:12 pm    Post subject: Reply with quote
here's my experience with passenger tires on an 85' Weekender...
in 1990 I bought an 85' Weekender with no knowledge on what tires should I get.. After a year of purchase, it need new tires... so I got a set of 205/70/14 of passenger tires, the guys at the tires shop didn't tell me what kind to get...
300 miles later, fully loaded, me and my wife 2 kids and camping gear we went to Death Valley. On the 395 near Adelanto, one of the rear tire blew up and we got to the road side OK. Guess what..? a fairly big gash on the side wall...I put the spare on, get another tire in town and keep going...
when we got back home I talked to another tire shop and they recommend LT (light truck) tires.. I got them but forgot what brand because it was so long ago...
now my current Carat is running on 195 Hankook RA08. 2 years ago I wanted 205 Vredestein but they are out of stock and waiting list is 6 months or more and I can't wait...
my syncro has BFG 27 X 8.50 R14 LT/C but it's another story
so in short DO NOT get passenger tires for vanagon.. you could hurt yourself your family or hurt someone too...
http://www.vanagon.com/info/tires/index.htm
j_dirge
j_dirge is offline
PostPosted: Tue Jul 05, 2011 12:46 pm    Post subject: Reply with quote
When I bought my van (3rd owner, I think).. It had 4 Bridgestone Dueller ATs. The tires looked nice. Meaty. But they rode like crap... and showed very uneven wear.
In fairness, the front end was worn and the alignment was left out of whack for WAY too long.
I eventually flatted a rear tire, then shredded it (destroyed) getting to the side of the road.. At least I *think* that is how it went down.
To replace those tires, I was in a pinch and installed two P-rated Michelins.
They were improperly sized (225/70r14), and they were under-rated sidewall. They handled better than the BstDATs, but I could not rotate since they would not fit on the front without a spacer. I eventually found 2 OE sized tires new and left them on the front. We drove 20k on that setup.. Mixed driving, heavy loads, no loads. Snow, rain, dry.
That entire mess has since been reworked.. 16s all around.
Moral of my story. I think I could destroy ANY tire if I tried.
But I'd not go back to P-rated tires if I had ANY choice in the matter. And for me, a cost difference of $150 for 4 properly rated, properly sized, tires is chump change.
There's other places to skimp.. tires are not the place to skimp.
Nor is the "look" of the tire at all important when stacked against rating and handling.
Your experiences, mileage, and opinions may vary. Wink
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
jadatis
jadatis is offline
PostPosted: Wed Jul 06, 2011 3:18 am    Post subject: Reply with quote
I kept myself busy with calculating tire-pressure since 2007, with use of the formula the European tyre-makes use since decades, and the American since 2005. Learned myself Excell to make spreadsheets for it and translated a few to English to go worldwide with it.
Reacting on several fora in America , I discovered the diferences between the systems in America and Europe.
I will not post links in my first post , because sometimes they are seen as spamm.
In Europe C on the sidewall stands for Cargo or Comercial tire, and is mostly what in America is called a D-load tire with 65 psi.
But all this is not important, yust look what is written on the sidewall in the form of "maximum load xxxx lbs at yyy psi" ( Europe mostly KG and kPa, 100kPa =1 bar) . Then the XXXX is the maximum load and the YYY is the reference-pressure as it is called in the formula I got hold of of the ETRTO ( European Tire&Rimm Technical Organisation) .
For Normal car( P-tires or SL standard load) and Extra Load tires only the maximum pressure is written down and the reference pressure, so the pressure that is calculated with, is in Europe 36 psi and in America 35 psi.
For EXTRA Load/XL/reinforced ( all the same) Europe 2,9 bar, America 2,8 bar ( converse it yourself to psi). In europe many exeptions , in America not.
America calculates the maximum load for the referencepressure up to maximum speed of tire or if lower 99 miles/h( 160km/h) and puts it on the tire. Europe calculates the same way but rounds it down to the nearest load-index. Because Europe calculates for SL and EX load with a higher reference pressure, it mostly gives 1 load index higher load. But technically both tires are the same , so You can calculate the pressure for lower then maximum load for american tires with the better European formula. Though America now calculats since 2005 with the same power in the universal formula, there are many old lists in America whit to my opinion wrong calculation, wich gives to low pressures for the load , or to high load for the pressure, wich can give tire-damage at a higher speed.
Because a D load tire is stiffer then SL, it may deflect less then the SL.
This gives less surface on the ground, so at the same load the pressure must be higher to compensate that.
In my next post I will give a link to my public map of skydrive of hotmail, in wich maps with spreadsheets to calculate. Fist I want to read if I can that soon.
Greatings from Holland
Peter
And because I only signed in, to give this information, I will not introduce me in an opening topic.
jadatis
jadatis is offline
PostPosted: Wed Jul 06, 2011 3:37 am    Post subject: Reply with quote
So now I will try to place a link.
https://skydrive.live.com/?cid=a526e0eee092e6dc#cid=A526E0EEE092E6DC&id=A526E0EEE092E6DC%21128
this leads to my public map with the pressurecalculation with temperature playing clicked on the I at the end. Then on the right you can click download.
After viruscheck you can open it in Excell or compatible programm to work with it. In the browser wont work because it cant handle some things in it.
If questions pup up , ask me here. And from this link you can navigate my complete public map by clicking the other "I " at maps and spreadsheets and articles the same way.
One thing I use in it is the Load- or Gripp-Percentage( further L%) and that is introduced by myself to get an idea of comfort and gripp. L% is the part what the real weight is of the weight you calculate the pressure for.
So 85% L% of 850 lbs can be calculated like this. 850/0,85 ( 85%) = 1000
, Then calculate the pressure for 1000 to get a loadpercentage of 85%.
This 85% is the border I concluded by reactions about bouncing. Under this discomfort begins by bouncing. Over 100% L% tire-damage begins.
So trick is to keep the pressure between L% of 85% and 100% , then you have a save pressure with comfort and good gripp .
The higher the L% the more gripp.
Jon_slider
PostPosted: Wed Jul 06, 2011 7:41 am    Post subject: Reply with quote
I think you mean 30 front 40 rear, not 44?
If so, that means your van came with a 205x70x14 rated 1580 lbs @ 40 psi
1. now the math for what each tire carries at 30psi front and 40 psi rear
30/40*1580 = 1185 pound carrying capacity front
40/40*1580 = 1580 pound carrying capacity rear
NO! each tire has its own load rating and max inflation. That producs vastly different doorjamb specs. For example, my doorjamb says 39 front, 48 rear, but it came with a 185R14 tire rated 1710 @ 55 psi.
to inflate the 185 tire to carry the same load as the 205 tire here is the math, starting with the results on item !.
1185/1710*55= 38 psi, very different from 30psi front
1580/1710*55= 51 psi, very different from 40 psi rear
not yet, but you are asking the right questions..
do you follow the explanation?
next math request:
YES YES YES! I have been heard, thank you!
lets review the math for those interested, first your stock tire was rated 1710@55 and was set to 39 front, 48 rear, lets calculate the load carrying inflations
39/55*1710= 1213 lbs front
48/55*1710= 1492
now to calculate the inflation of your tire rated 1875@65
1213/1875*65= 42 psi front
1492/1875*65= 52
jadatis
jadatis is offline
PostPosted: Wed Jul 06, 2011 8:06 am    Post subject: Reply with quote
reaction to last post
What you are doing , with calculating part of the load = part of the pressure, can be translated in the universal formula the tire-makers use , as using power =1 in the formula, Europe uses 0.8 and America for LT tires still 0.7
Beter is to use for LT tires and higher 0.9 to 0.95 power.
So what you are doing is not so wrong, only the calculating back of the used loads for the old tires gives to low loads, because tire-maker in America calculated with power 0.7 at highest but mayby even 0,5. wich lead to lower pressures . Calculating this lower pressure back with power =1 you get lower loads then they realy calculated with .
Beter is to go from the Gross Axle Weight Ratings wich are mostly somewhere on the vehicle, and calculate with you power 1 the needed pressure.
Made a spreadsheet for that to, where you can fill in your own power and the data of the tire. Then you get the same list as the tire-manufacturer gives.
https://skydrive.live.com/?cid=a526e0eee092e6dc#cid=A526E0EEE092E6DC&id=A526E0EEE092E6DC%21601
You can give 3 powers and the formula is stated in the spreadsheet.
Jon_slider
PostPosted: Wed Jul 06, 2011 10:17 am    Post subject: Reply with quote
thanks for adding to the detail jadatis
my formula is linear, what your spreadsheet calls a power of 1 I think.. thanks for sharing your spreadsheet. I would like to know how to post mine..
if your formula produces higher inflation recommendation, I would like to understand how to use it.. I respect the fact that the equation may not be linear, and wonder what percent variance your pressure results are to the 42/52 the following example produces
here is my spreadsheet template.. dont know how to post it as a file yet, but someone could build similar
Original doorjamb
OE front psi 39
OE rear psi 48
Original tire specs
OE max load 1710
OE max psi 55
calculate load on front 1213 =oe front psi/oe max psi*OE max load
calculate load on rear 1492 =oe rear psi/oe max psi*oe max load
proposed new tire
new max load 1875
new max psi 65
proposed front psi 42 =calculated load on front/new max load*new max psi
proposed rear psi 52 =calculated load on rear/new max load*new max psi
I think thats enough hot air from me about tires for now, time to go driving..
enjoy the ride
jadatis
jadatis is offline
PostPosted: Wed Jul 06, 2011 2:13 pm    Post subject: Reply with quote
You cant add a file to a post in this forum, I see now I am writing this.
Some fora have that possibility.
But there are sites like Imageshacj where you can post a file and paste the link to it in the reply. But if you have a Hotmail-adress or make one, you can use the skydrive like I did.
Then you can link to it the same way as I do.
But using power 1 is not that bad for calculating the pressure for a given load. Only the calculating back of the load the car-maker used for the original tires is unsertain in America, Because diferent powers where used for diferent kinds of tires.
P-tires or Standard load ,or I think A-load tires power 0,5 for calculating a load for a sertain pressure.
P-tires with aspect ratio of less then 50% ( 185/50R 14 ) power 0,65
From C load tires power 0.7 XL the same as Standard load.
After 2005 0.8 for A and B load tires ( P and XL), and still 0,7 for C and higher-load tires.
J.C Daws , from wich I have an article in the public map with link in my own reaction, states that if you keep using the power formula, youu better use for large tires with high refence-pressure power 0.9 to 0.95, so even higher then the 0.8 Europe uses for decades and I ask myself why they keep to 0.7.
If you want to turn the formula around to calculating a pressure for a sertain load you have to take a power of 1/ P . So the lower pressures from the original tires give lower loads when you calculate back with power 1 as you do. So the new tires are calculated for a to low load so still to soft . Power 1/ 0.5 = power 2 and that is the same as square.
Power 0.5 is the same as root, maybe this will make you understand what this powerthing is all about. But on a sciencetific calculator, as you can swich the calculator of windows too , there is a X^y button to use for it.
I will stop now because it is 23.00 H here and I am going to bed.
But this all to be continued.[/b]
hippiepilot
hippiepilot is offline
PostPosted: Wed Oct 26, 2011 11:02 am    Post subject: Reply with quote
I'm so confused after reading this thread that I hope someone can tell me the "safe" tire to purchase. I currently have unsafe tires they are 205/70/14 95s and only have lasted about a year, with maybe 12K miles on them. The back left tire is starting to get a budge that was shown to me when I was having my rack installed. My door sticker on my 91 carat states http://www.vwvid.com/m/photos/view/tire-specs and I would like to stay with the 205's so my van doesn't look like it is running on bicycle tires. If I'm reading the sticker correctly as long as I purchase 205/70/14 97r I should be ok. I have found something close but it has a rating of 98t which is above the recommended rating. http://www.tirerack.com/tires/tires.jsp?tireMake=G...mpare1=yes I know these are cheap tires but I'm just using them as an example. Would it matter if the load range exceeds the recommended range? Or am I still lost in tire-land?
Thanks for any advice.
83 air-cooled Westy
91 Carat (daily driver)
http://www.changeisland.com
r39o
Samba Polizei
r39o is offline
PostPosted: Wed Oct 26, 2011 11:11 am    Post subject: Reply with quote
Your weather is a lot like San Diego. Many of use use Hankook RA008 in a 185R/14 or 195R/14
PLEASE, PLEASE, PLEASE, search on TheSamba about those Altimax tires. Not on most people's list of acceptable....
hippiepilot
PostPosted: Wed Oct 26, 2011 11:14 am    Post subject: Reply with quote
I know they are not good tires I just wanted to use the rating specs. Thanks
83 air-cooled Westy
elsyr
elsyr is offline
PostPosted: Wed Oct 26, 2011 11:45 am    Post subject: Reply with quote
hippiepilot wrote:
My door sticker on my 91 carat states http://www.vwvid.com/m/photos/view/tire-specs and I would like to stay with the 205's so my van doesn't look like it is running on bicycle tires ...
I'm just up the road in Jacksonville, so have essentially the same weather you do, and I've been very happy so far with the Hankook RAO8 195s on my Carat - they definitely don't look like bicycle tires to me, and the improvement in ride and handling over the POS passenger tires that were on there is amazing. I keep them at around 55psi. It may be that I will never pack enough crap into Brunhilde to get even close to pushing the load limit, but I'd rather know that I don't have to worry about it than guess.
Doug
'89 Carat "Brunhilde"
Page 4 of 5
