BOSCH 0 231 178 009
Page: Previous  1, 2
zundapp
zundapp is offline
PostPosted: Wed Nov 16, 2011 6:36 pm    Post subject: Reply with quote
Keep the bracket on it when you pull it out. Stick it under the back seat for a spare. If you ever need to replace your distributor on the road, you can just drop it in and it will already be timed and gapped.
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Wed Nov 16, 2011 6:44 pm    Post subject: Reply with quote
bill may wrote:
uhooh want a picture of one with brazil there?
Yes please. I'm with Andy, I never saw one stamped Brazil
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
DHMaher
DHMaher is offline
PostPosted: Wed Nov 16, 2011 8:40 pm    Post subject: Reply with quote
Are we still talking about the 205K 009s?
Daniel
"POs, you gotta love them, because killing them is illegal." -Unknown Samba Member
1967 Beetle - Java Green Green Bug VW Logo
See my ads
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Wed Nov 16, 2011 9:12 pm    Post subject: Reply with quote
Not the last few posts - he asked at the beginning what his current centrifugal 009 might be worth... and the discussion about German vs Brazil, etc sprang from that.
DHMaher
DHMaher is offline
PostPosted: Wed Nov 16, 2011 9:32 pm    Post subject: Reply with quote
Haha... ok thanks! With all those possible number combinations I wonder why did they named more than one 009...
Daniel
See my ads
The Android
PostPosted: Wed Nov 16, 2011 9:45 pm    Post subject: Reply with quote
I've often wondered that myself - I'm sure that was Bosch's decision, and probably just total luck of the draw. There were actually like 5 VW and Porsche/914 distributors that ended in 009.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Nov 17, 2011 5:47 am    Post subject: Reply with quote
Because the entire part number is 10 digits... like a phone number.
If you have any questions, just call me at 649. (get my point?)
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
The Distributor Distributor
tasb is offline
PostPosted: Mon Nov 12, 2012 4:31 pm    Post subject: Reply with quote
Somewhere hiding in the forums is some information on early 009's that had a different part number than the more common German 009's= 0 231 178 009. I have done 8 differnet search ques and can't find any info. Can anyone with a better memory help out? I am interested from a historical perspective. Somewhere there is even a cast iron X XXX XXX 009. Thanks.
Roads Scholar
Member# 2059
Mr. 010
Glenn is offline
PostPosted: Mon Nov 12, 2012 4:33 pm    Post subject: Reply with quote
Every BOSCH 009 i've seen had the same number 0231 178 009.
If it had a different number it had a different curve.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
tasb is offline
PostPosted: Mon Nov 12, 2012 4:35 pm    Post subject: Reply with quote
understood, nonetheless its been posted in here somewher.
Roads Scholar
Member# 2059
Mr. 010
Glenn is offline
PostPosted: Mon Nov 12, 2012 4:37 pm    Post subject: Reply with quote
I've have to see it in persona and test them to know they have different numbers and the same curve.
But then A Bosch German and Bosch Brazilian 009 will have different curves.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
tasb is offline
PostPosted: Mon Nov 12, 2012 7:37 pm    Post subject: Reply with quote
ok Glenn, not quite sure how to take the above but sometimes even the Master can learn a thing or two...
Roads Scholar
Member# 2059
Mr. 010
Glenn is offline
PostPosted: Mon Nov 12, 2012 7:40 pm    Post subject: Reply with quote
My point was you can't trust things on the internet.
I don't see how Bosch would produce 2 exact same distributors with different numbers.
Unless you mean the 009 and 094 where the 094 was a 009 with a chrome body.
Nothing personal, just some Samba humor.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
tasb is offline
PostPosted: Mon Nov 12, 2012 8:32 pm    Post subject: Reply with quote
Still searching but this I can tell you, if you go to the oddball distributor thread you will find an VI 4 BR 8 instead a a VJ 4 BR 8. I've had both on my Sun Machine and their curves are pretty close if not meant to be the same. You won't find any reference to the VI 4 BR 8 anywhere but it does exist. Perhaps it was a 1 231 178 008 I'm looking for I can't recall.
Roads Scholar
Member# 2059
Mr. 010
Glenn is offline
PostPosted: Mon Nov 12, 2012 8:36 pm    Post subject: Reply with quote
tasb wrote:
perhaps it was a 1 231 178 008 I'm looking for I can't recall.
That could work.
What you saw could be for a Alfa 0231 178 006.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
tasb is offline
PostPosted: Sun Nov 18, 2012 3:13 pm    Post subject: Reply with quote
I found one reference to early 009"s. It's the oldvokshome website. It is one of the better distributor interchange references but it is not perfect. It lists the following:
0 231 178 001
0 231 178 003
0 231 178 009
all three cross referencing back to a 0 231 178 009.
Roads Scholar
Member# 2059
tasb
tasb is offline
PostPosted: Fri Jan 11, 2013 11:46 pm    Post subject: Reply with quote
...and here we have the critter to which I was referring too:
Note that it has a VW logo and a VW part #. I've seen more than my share of 009's but this one is a first.
According to several sources and Bosch microfiche, this distributor is the predecessor to the 009. I have run it on my Sun Distributor Tester and it has a curve very close to that of the 009. It is designated as an industrial engine distributor specifically for VW engines. That is not something that the 009 can claim. There is also a 0 231 178 001 out there somewhere that had VW applications.
Roads Scholar
Member# 2059
tasb
tasb is offline
PostPosted: Sun Jan 13, 2013 9:57 am    Post subject: Reply with quote
After several discussions it has been pointed out that these distributors are fairly rare as most industrial engines were supplied with magnetos rather than distributors.
Roads Scholar
Member# 2059
user0815
user0815 is offline
PostPosted: Mon Jan 21, 2013 7:20 pm    Post subject: Reply with quote
I was going to order a tune up kit today and found my distributor is a Bosch 0 231 178 008 , now I'm clueless as to what to order...... I found a cross reference chart online that says I should order:
points 01030
cond 02086
cap 03010
rotor 04033
now I'm even more confused, can't find these numbers on the vendor's websites.....
Is this distributor "correct" for a '68 Ghia with a 1500cc engine? When I say "correct" I mean, will it work correctly.... what car/engine is this distributor "correct" for ???
I know the engine ran fine with this dizzy, last time it ran was 2007 though..... getting close to getting it back to life and just wondering if it will run better with a different dizzy......
Page: Previous  1, 2
Page 2 of 2
