What broke on my 71 Camper ?
Page: 1, 2, 3, 4  Next
vwbuser71
vwbuser71 is offline
PostPosted: Sun Nov 27, 2011 8:00 am    Post subject: What broke on my 71 Camper ? Reply with quote
When backing my 71 camper out of the garage, it felt like the emergency brake was on , and it wouldn't roll. It finally let loose as the clutch was released, with a clunck. The bus drove Ok for about a mile, but then when starting out in 1st gear from a stop light, it bunny hopped a little and then a loud clunk from the rear, and she was dead. The engine was still running and I could shift, but no drivetrain. What did I brake?
borninabus Premium Member
Samba R&D Dept.
borninabus is offline
PostPosted: Sun Nov 27, 2011 9:31 am    Post subject: Reply with quote
sounds like you you either stripped the splines in one of your drums or a CV fell off.
or your trans is kaput. but lets hope for the best Smile
88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
aeromech
aeromech is offline
PostPosted: Sun Nov 27, 2011 10:17 am    Post subject: Reply with quote
Had the bus been parked for a while with the brake set? I'll bet your parking brake locked up. I suggest removing the rear drums for cleaning and inspection.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Sun Nov 27, 2011 10:26 am    Post subject: Reply with quote
Could be CV's or it could be time for a new clutch. I'd look at these as part of my diagnosis.
"I will gladly pay you Tuesday for a hamburger today."
seventyfo
seventyfo is offline
PostPosted: Sun Nov 27, 2011 10:34 am    Post subject: Reply with quote
I second the strippedsplinesinthedrum theory.
85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey
rustbus
rustbus is offline
PostPosted: Sun Nov 27, 2011 10:49 am    Post subject: Reply with quote
threads like this should be a poll!
I vote CV came loose - have you looked underneath it yet? if it was CV it would be obvious.
drumroll!
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
SGKent Premium Member
SGKent is offline
PostPosted: Sun Nov 27, 2011 12:16 pm    Post subject: Reply with quote
CV
71weekender
71weekender is offline
PostPosted: Sun Nov 27, 2011 12:18 pm    Post subject: Reply with quote
cv
Wildthings
Wildthings is offline
PostPosted: Sun Nov 27, 2011 12:21 pm    Post subject: Reply with quote
Certainly easy to check for a stripped drum or busted CV. If those are all good then next would be something wrong with the pinon in the transaxle.
SGKent is offline
PostPosted: Sun Nov 27, 2011 12:24 pm    Post subject: Reply with quote
71 has a forged flange like a late bay. Pretty hard to strip them.
vwbuser71
PostPosted: Sun Nov 27, 2011 12:49 pm    Post subject: Reply with quote
Thanks all, for the quick responses. Just checked the CV's and the drivers side
CV is broken off from the drum. Can I re-install it, or is replacement the best option. Any other damage I should be looking for to the drum Etc?
SGKent is offline
PostPosted: Sun Nov 27, 2011 1:06 pm    Post subject: Reply with quote
post a photo
Wildthings
PostPosted: Sun Nov 27, 2011 5:50 pm    Post subject: Reply with quote
If it is just the bolts have backed out or sheared, then new bolts may fix your problem. You will need to clean everything well to make sure the mating surfaces and the holes and threads for the bolts are not damaged.
curtis4085
curtis4085 is offline
PostPosted: Sun Nov 27, 2011 6:00 pm    Post subject: Reply with quote
make sure to put a new boot on it when you replace the cv. Rochford has some great ones. Or you could get the CV join and german boot at busdepot and pop it on. I recommend Rockford and German CVS.
heres Rockford boot
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Nov 27, 2011 6:24 pm    Post subject: Reply with quote
And at least repack the joint sine you are in there. If it were me, I would do all 4 of them since you are doing it anyway. I just hate for them to go bad in the middle of deep nowhere though.
Invest in new belleville washers (usually not included in the re-pack kits) and make sure you have all the torque spreaders.
curtis4085
PostPosted: Sun Nov 27, 2011 6:33 pm    Post subject: Reply with quote
now you lost me , newbie here torque spreaders is that the same thing as circlip spreaders and the belleville washer ? is the the dished washer? sorry newbie.
Special Thanks to:
Wildthings
PostPosted: Sun Nov 27, 2011 6:38 pm    Post subject: Reply with quote
Each joint should have three plates under the bolt heads to spread the load onto the boot flange more evenly. The Belleville washers are the slightly curved washers that fit under the bolt heads but on top of the spreader plates.
The most important thing you can do (in my opinion) is to get the bolts tight enough. VW upped the recommended torque on the later Transporters (Vanagons) to 33 ft*lbs, IIRC.
Desertbusman
Desertbusman is offline
PostPosted: Sun Nov 27, 2011 7:46 pm    Post subject: Reply with quote
Time to remove both axles and go thru the 4 CV joints, maybe replace boots and probably get 24 new bolts and the special serrated washers. Then put it back together exactly per the book. If one failed the other 3 might also since it wasn't done right when they were put on before.
71 Superbug
71 Westy
curtis4085
PostPosted: Sun Nov 27, 2011 8:39 pm    Post subject: Reply with quote
awsome..i have those parts on order from VW just was not sure what he was talkiing about. Sorry for the thread high jack...
Definetly do all four CVS If you got one side thats failing the other not far behind.
Special Thanks to:
SGKent is offline
PostPosted: Sun Nov 27, 2011 9:18 pm    Post subject: Reply with quote
and check the tightness on the bolts every time you change the oil. If any feel lose retorque them all.
Page 1 of 4
