My H6 Install (EZ30)
Page: 1, 2, 3, 4  Next
purplepeopleeater
purplepeopleeater is offline
PostPosted: Mon Nov 28, 2011 7:25 pm    Post subject: My H6 Install (EZ30) Reply with quote
Well, I made the leap to change out my EJ25 to something with a little more torque, my primary reasoning was mainly the updated engine and the added power and smoothness of the H6 was a huge benifit to me.
I purchased a "kit" from h6t3.com and took the plunge.
first step was preping the motor,
Lookie, no timing belt...
Prepin the covers with epoxy paint,
I needed to take the intake off in order to pull the engine wiring harness off, you'll find out that with most of the wiring harnesses you find that those big grey plugs that connect the engine to the firewall off factory cars are pretty hard to find, so I opted to use a one piece harness from each sensor all the way to the ECU
Keep track of all the hoses!
Clean intake system eh?
Good grief, look at this wiring harness mess....have I mentioned yet that I am a wiring retard? Wink
This is the tee you need to put in for the heater core return line for the old hose on the drivers side
These puppies come out, the crossover pipe that goes across the the front (below the pulley) gets moved to the rear and nests along the engine mount, don't worry I didn't use this hammer...
Two supplied plugs come in the kit, I used some JB weld and it worked pretty well.
Using the supplied thermostat adapter you get some threaded barbs and this allows you a little more room to move the coolant hoses to the rear, I made hard lines rather than using the suggested rubber heater hose.
[img]https://lh4.googleusercontent.com/-gQRciI9kF5U/TtQx5qJhI2I/AAAAAAAAAG8/ajguagKkimY/s640/IMG_0228.JPG][/img]
Intake is now bolted back on, this is the bolt hole where you'll bolt on the wire-to-cable throttle setup that is ran off the link ecu,
This port you'll need to figure out how to vent, I used a universal breather filter and it works great, it all depends on what air filter you use...I used a K&N filter so my options where limited.
Okay, the kit also comes with a vanagon temp sending unit so breakout the 10x1.0 tap
These are the nifty exhaust mounts, you'll need to remove 4 of the bolts from the t-chain cover
I used a KEP adapter plate, here you can also see the engine mount
I skipped a few steps, you'll need to drill your own holes to mount the new engine mount, but thats easy stuff...I wanted to document what I thought would be the hard stuff...
Here is the fuel pressure regulator,
You will also need to buy a wideband o2 sensor and gauge (LC1) the link ecu is designed to work with the LC1 so no getting around this...
I bought mine off amazon for about $180 bucks
Here is the wiring setup I used for the LC1 to the link,
Here is a wiring diagram for the throttle body to the link,
Here's the alt wiring,
Here is where I mounted the link, looooooots of wires eh?
I decided I'd put the ecu in this location due to it being the spot where I plan on putting the rest of my electronics.
I have more pictures once I find my memory card, Its all finished now and I’ve put about 190 miles on it....I must say going from the 2.5 to the 3.0 was quite a surprise to me, the 2.5 was smooth compared to my wbx but this is miles above either and I have a nice power band in 3rd and 4th gear.
purplepeopleeater
PostPosted: Mon Nov 28, 2011 7:40 pm    Post subject: Reply with quote
Oh I should add that I did this in 9 days, would have been a little quicker, but with watching a 3 year old at the same time I couldn't focus as much.
connorsvw2
connorsvw2 is offline
PostPosted: Mon Nov 28, 2011 7:48 pm    Post subject: Reply with quote
Nice post-I'd love to have one of those 3.0s in my van!
Can the coolant plugs be replaced with threaded NPT plugs and the alloy body tapped? I'm sure the JB Weld will work fine (love the stuff!) but I'd personally like the assurance of a tapped fitting "just in case".
'85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car)
purplepeopleeater
PostPosted: Mon Nov 28, 2011 7:51 pm    Post subject: Reply with quote
Not enough room there to turn the threads. , I was paranoid about this too. If it ever leaks i'll TIG it in place
nelinor
nelinor is offline
PostPosted: Mon Nov 28, 2011 8:00 pm    Post subject: Reply with quote
I'm jealous.
1983.5 VW Vanagon Westfalia - manual - EJ22
2002 Subaru Impreza Wrx
1990 Nissan 300zx tt
View user's profile Send private message Facebook Twitter Gallery Classifieds Feedback
Alaric.H
Alaric.H is offline
PostPosted: Mon Nov 28, 2011 8:12 pm    Post subject: Reply with quote
I guess the older 3.0 go a little deeper.
purplepeopleeater
PostPosted: Mon Nov 28, 2011 8:16 pm    Post subject: Reply with quote
wow, there is a a slight change.
did you use stright barbs?
Alaric.H
Alaric.H is offline
PostPosted: Mon Nov 28, 2011 8:20 pm    Post subject: Reply with quote
Tapered NPT threads and a little teflon tape.
danfromsyr
danfromsyr is offline
PostPosted: Tue Nov 29, 2011 7:48 am    Post subject: Reply with quote
*Fixed link so I could see pic
Abscate wrote:
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Nov 29, 2011 10:08 am    Post subject: Reply with quote
Very nice pictures and write up Cool
I didn't know this H6TL link,thank you Wink
Farfrumwork
Farfrumwork is offline
PostPosted: Tue Nov 29, 2011 10:51 am    Post subject: Reply with quote
WOW
Nice work peopleeater.
Great photos and detail.
I've driven a EG33 powered syncro, which was very smooth and torquey, but I bet the more modern 3.0l is even more so.
-Chad
sold Sad -> '85 Wolfsburg Syncro / 'Built' DOHC EJ25 (a great machine!)
'07 Legacy spec.B, road tuned stgII
'17 4x4 Sprinter, stone grey, SMB pop-top, on 33"s
"Blood stains, speed kills - Fast cars, cheap thrills - Rich girls, fine wine - I've lost my sense, I've lost control, I've lost my mind"
scobax
scobax is offline
PostPosted: Tue Nov 29, 2011 11:20 am    Post subject: Reply with quote
Thanks for your extremely thorough write-up, Purplepeopleeater! This is exactly the sort of thing that makes this public forum such a valuable asset to the greater Vanagon enthusiast community. It's all about an exchange of ideas, open source Vanagon hacking, if you will.
I have had a line on a half a dozen of these engines/harnesses, etc. for more than a year, but I was hesitant to move on one due to the lack of a comprehensive build thread. You deserve a big THANK YOU for taking the time to put together such a clear and comprehensive thread.
Can't wait to see the rest of your pics!
87 Syncro Westy w/ Suby 2.5
RIP: 2.1 WBX. You were a good dog 'ol feller
“The word adventure has gotten overused. For me, when everything goes wrong, that's when adventure starts” -Yvon Chouinard
"It's not expensive, its priceless" -Unknown
syncrogreg
syncrogreg is offline
PostPosted: Tue Nov 29, 2011 12:31 pm    Post subject: Reply with quote
Hi,
Good job! it's not easy to deal with all the mess the factory engine has.
Why do you relocate the water fittings? they are located before the thermostat to give you hot air in cold morning within a minute. The spacer that has the new fitting is located in the cold water side or the warm water erea? I don't get the point yet.
Thanks
GSB
conversions: www.boxeer.com Common rail TDI and NOW PDK transmissions!!
travel pictures:
http://instagram.com/crepeattack/
- the Pastis build: http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel
Turk.380 Premium Member
Turk.380 is offline
PostPosted: Tue Nov 29, 2011 1:01 pm    Post subject: Reply with quote
Awesome! Thanks for the write-up. I just purchased the same kit but for the earlier EZ30D (non drive-by-wire) engine and will be doing this conversion over the winter.
Very nice to see what I'll be in for in a few months. Currently I'm still in the tear-down phase. So far only posting to our local forum:
http://www.aircooledmissouri.com/Forums/viewtopic.php?f=21&t=5145
Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '74 RHD DoubleCab | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista
'70 Karmann Ghia AutoStick coupe.
wontfalia
wontfalia is offline
PostPosted: Tue Nov 29, 2011 1:21 pm    Post subject: Reply with quote
SHOTGUN!!
Seriously. This is impressive. You make the install look and sound easy. And that engine looks brand spanking new. Is the adapter plate the same from your 2.5? I think I'll buy a lottery ticket this week.
Wontfalia
Don't break the law when you're breaking the law
purplepeopleeater
PostPosted: Tue Nov 29, 2011 1:25 pm    Post subject: Reply with quote
wontfalia wrote:
SHOTGUN!!
Wontfalia
Yep, same adapter off the 2.5...it was kinda easy. mainly all the wiring was the biggest hassle.
I lost my memory card, so I'll take some new pics later today and post of finished product, I am setting up my idle table and tach signal right now.
levi
levi is offline
PostPosted: Tue Nov 29, 2011 6:52 pm    Post subject: Reply with quote
So KEP adapter plate, and what clutch, and does it feel like it's enough for the torque?
I hope you'll give us your impression of the difference in gas consumption from ej25 to the 3.0 once you've run a couple tank fulls too. Wink
Awesome!
I thought you said you were a wiring dummy? Looking wizardly enough to me.
Laughing
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
shadetreetim
shadetreetim is offline
PostPosted: Tue Nov 29, 2011 7:21 pm    Post subject: Reply with quote
Nice job with the conversion and the thread. Gonna be interesting following your progress. That motor looks good.
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5
Vanagon Nut
Vanagon Nut is offline
PostPosted: Tue Nov 29, 2011 7:46 pm    Post subject: Reply with quote
Dude.
Great pics, text and pen pointing. Not to mention nice looking QC.
All the best on your swap and thanks from the "Royal We" for taking time to post details.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
purplepeopleeater
PostPosted: Sun Dec 04, 2011 8:08 am    Post subject: Reply with quote
Here are a few more pictures,
Here's a shot of the beast, I used some epoxy primer then shot it with blitz black (this stuff is tougher then poweder coating when done right)
My helper
Wiring almost complete
All tucked in the engine bay,
Under shot, the engine mount needs some adjustment I think...The engine could sit a little further up and I could gain a little clearance, I also am going to find a way to modify the coolant line leading from the oil cooler, it needs to be on the back side.
Here's the other side, I put some header tape around the coolant hoses...doesn't look realt pretty but after running it hard I can touch it still
After the first test drive I had a fuel line pop off, it was after I shut it down went inside with the family to eat dinner and when we went to start it stumbled then I smelled gas, I guess this was the issue Shocked
Gates hose is really crappy, it was brand new and meant to FI systems. I used a correct band OE style clamp too, I plan on further researching some new source for fuel line, I've been using the BMW stuff and never had issues yet, I gotta change fuel lines on 3 of my vans in a month or so.
Page 1 of 4
