Case Saver movement
whirlpool
whirlpool is offline
PostPosted: Sat Dec 03, 2011 3:09 pm    Post subject: Case Saver movement Reply with quote
I have 10mm case savers inserted for the cylinder studs. I installed the studs into the case savers on Thursday and noticed something that concerns me. I just dont have the experience to know whether the movement I see is normal and the books that I have read do not cover this sort of thing. The case savers are moving within the sockets and a few appear slightly loose, left to right, if moving the studs. I could not notice anything prior inserting the studs. Is this movement acceptable? If not what is the right way to fix this.
thanks
modok
modok is offline
PostPosted: Sat Dec 03, 2011 4:35 pm    Post subject: Reply with quote
Normally they do not move
The first step would be to unscrew the loose inserts, and see if they are stripped or just a little wobbly.
If they are just wobbly then clean/locktite/re-assemble
mark tucker
mark tucker is offline
PostPosted: Sat Dec 03, 2011 6:42 pm    Post subject: Reply with quote
might need to use a defferent tap,and might need to use a biger incert on that case.
whirlpool
PostPosted: Sat Dec 03, 2011 7:11 pm    Post subject: Reply with quote
cheers
need to figure out how to remove and check
I am now hoping that the hole is not too big and in need of some magic!
a few are wobbly - so I hope locktite will be all that is missing.
what are the limitations, by that I mean what is wobbly versus stripped and how do I determine what needs doing?
thanks
volkyoo
volkyoo is offline
PostPosted: Sat Dec 03, 2011 7:14 pm    Post subject: Reply with quote
in an old case, i had some case savers like that. just locktited and voila!!!
modok
modok is offline
PostPosted: Sat Dec 03, 2011 7:18 pm    Post subject: Reply with quote
well, for instance on the average nut/bolt, there is 0.1mm or so of wobble between them. High precision threads will be tighter than that, real easy going low quality ones will be looser. i think they use a percentage to describe it, If I remember right, normal is 80% thread
Point is, a little wobble is ok, but if half the threads are damaged, or busted out, stripped, less than 50% engaged, THEN you have a problem
whirlpool
PostPosted: Sat Dec 03, 2011 7:23 pm    Post subject: Reply with quote
you guys rock!
The case savers are new. What needs to be done is a bit of locktite. You have described exactly what the issue is.
I will have a bit of cleaning up to do and then locktite.
THANKS
SRP1
SRP1 is offline
PostPosted: Sat Dec 03, 2011 7:25 pm    Post subject: Reply with quote
In my book, if a case saver wobbles or is loose in the bore, its bad, period.....
Sorry but its a sure failure point, maybe not today, but it will be tomorrow.
whirlpool
PostPosted: Sat Dec 03, 2011 8:03 pm    Post subject: Reply with quote
ouch; I hear you loudly
any advice?
to over come my loose case savers that is?
SRP1
SRP1 is offline
PostPosted: Sat Dec 03, 2011 9:06 pm    Post subject: Reply with quote
There are oversize case savers out there, I don't know what is available in your area, but they are out there.
Another option is to have a new case saver made by a machinist that fits your needs, This can be easily done on a lathe. If you only need a couple this may be your best option.
Anyone in your area that can weld cases? Weld up the hole and remachine is a permanent fix too.
Other than that; epoxy, loctite, suoer glue, all that stuff is a real gamble.
RockCrusher
RockCrusher is offline
PostPosted: Sun Dec 04, 2011 6:14 am    Post subject: Reply with quote
If by all this you mean that the saver wobbles in the case then the tap you used is junk. That doesn't help you now though. If it's basically a stocker then you MIGHT be ok with loctite. If it's a performance engine then you better make it really right like SRP said.
RC
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
whirlpool
PostPosted: Mon Dec 05, 2011 8:46 pm    Post subject: Reply with quote
Thanks for all the response.
My inexperience shines through here. After a few PM's and this thread I went and investigated further. The case savers thankfully are embedded and do not move. When I read "snug fit" I took it the studs needed to be snug and not tight and after "snugging" them down properly they now are all stationary.
This is a stock build; no way will I be taking on anything other than stock right now as I just do not have the experience. Shocked
g
