Zentaka Samba Member
Joined: August 22, 2010 Posts: 264 Location: Hawaii Island, Hawaii
Posted: Fri Aug 12, 2011 5:46 pm Post subject: Van won't start with Digital Idle Stabilizer disconnected. |
When I disconnect the plugs to the digital idle stabilizer and plug them into each other, the van won't start. When I plug them back into the digital idle stabilizer, it starts.
What does this tell you? As far as I understand it's supposed to be able to run without the stabilizer connected.
Thanks,
-Zen |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10304 Location: Mt Lemmon, AZ
Posted: Sat Aug 13, 2011 2:00 pm Post subject: Re: Van won't start with Digital Idle Stabilizer disconnecte |
| Zentaka wrote: |
| ...As far as I understand it's supposed to be able to run without the stabilizer connected. |
Yes, but I think the two leads must be connected if the stabilzer is bypassed. Yes, you said you did that but I would check and be double darn sure they are truly connected. If they are not really connected then indeed you will have a 'no start'. |
Posted: Sat Aug 13, 2011 2:22 pm Post subject: |
They did click into place and were pushed in as far as I could get them. Also I tried several times. I will go out and make sure I have them snugly fit together though, thanks for the suggestion.
After a little thinking, I wondered if this could be due to my timing being off, and the digital stabilizer correcting the issue so that the van runs. I have no idea if that's likely/possible/etc. What do you think?
UPDATE: I tried again and I had the connections on as far as I could get them to go, and it wouldn't start. Plug into idle stabilizer and it started right up. I also noticed the tach doesn't seem to move with the idle stabilizer disconnected. What does it all mean? |
stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Sat Aug 13, 2011 3:03 pm Post subject: |
Digijet or Digifant ? _________________ Steve |
Posted: Sat Aug 13, 2011 3:12 pm Post subject: |
| Digifant, I'm pretty sure. Any easy way to tell? |
Posted: Sat Aug 13, 2011 3:28 pm Post subject: |
2.1 has digifant.
Don't know where the information came from that when you unplug the connector to the stabilizer you have to connect the two wire together. I just went out to my van and unplug the ISV and left the plug dangling. The van started with a little push on the gas pedal. Of cause now it idle too slow.
If you look at the schematic, the idle stabilizer control unit takes inputs from temp 2, hall sensor, starter, throttle switch, A/C and power steering. It has only two output wires which is connected to the stabilizer valve. The rest of the engine do not know if the ISV is connected or not. _________________ Steve |
Posted: Sat Aug 13, 2011 3:44 pm Post subject: |
Sorry I have a 1.9, so I guess it's digijet.
The Bentley test for the Digital Idle Stabilizer said to unplug the plugs and plug them into each other to test the idle stabilizer. It said if the engine is running rough or misfires, and unplugging the idle stabilizer fixes it, then I have a bad idle stabilizer. Unfortunately they didn't have any mention of what the problem is if the engine won't turn with the idle stabilizer disconnected.
Thanks for everything,
-Zen
UPDATE: I replaced my ICU and now the van starts whether the stabilizer is connected or not. Go figure. Any explanations?
Main thing is it's starting again (for now).
Thanks for everything!
-Zen |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Sat Dec 03, 2011 7:22 pm Post subject: |
Zentaka,
the ICU meaning the Ignition Control Unit? the ingnition module on the DS firewall by the coil?
anyone else have any insight to the function (and disfunction) of the Idle Stabilizer unit in the 80-85 vanagons?
| Zentaka wrote: |
-Zen
-Zen |
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2734 Location: East Nassau, NY
Posted: Sun Dec 04, 2011 6:32 am Post subject: |
| It changes the timing to put the idle speed into specs. |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3452 Location: Talos IV, Piedmont Arizona
Posted: Sun Dec 04, 2011 6:57 am Post subject: |
Bypass the stab and check the timing. _________________ LEARN TO SELF RESCUE
....Bad Sneakers.... |
Gauche1968 Samba Member
Posted: Fri Oct 18, 2013 4:05 pm Post subject: |
| Captain Pike wrote: |
| Bypass the stab and check the timing. |
What if it won't start with stabilizer bypassed? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
