Official Upright fan shroud thread
Page: 1, 2, 3, 4  Next
AlteWagen
Troll
AlteWagen is offline
PostPosted: Thu Dec 15, 2011 3:55 pm    Post subject: Official Upright fan shroud thread Reply with quote
WORK IN PROGRESS!!! PICS ADDED AS FOUND. If you have better pics please post.
25hp shroud
seamed at top of shroud
KDF shroud
1946/1947
Manual lever for "summer/winter"
Listed from PR
1947 Cooling air throttle ring
previously slide
March 1949 Now without throttle ring
May 1950 Automatic cooling air regulation
previously throttle ring with swing handle
December 1951 Throttle ring spot welded
previously screw mounted
September 1952 Throttle ring support guide projected for operating shaft
previously recessed
Oct 1953 Fan blade increased to 1.5mm thick
previously 1.25
36 hp shroud
Throttle control ring and thermostat
Aug 1959 Fan bore diameter increased to 28mm
previously 20mm
Nov 1960 Fan now has 28 blades with 20mm bore diameter
previously 16 blades 28mm bore diameter
40hp stale air shroud
Transitional?
Note holes for plug wires and choke
May 1961 Throttle ring rubber stop now increased to 8-9mm
preciously flat
1961-1962
Note cutout for air cleaner no choke hole
July 1962- December 1962
Non fresh air with larger housing
PR lists
Fan housing/fan
Now: Modified shape increased
cooling air throughput
63-70 fresh air shroud
Uses upright oil cooler
April 1964 Cooling flaps replace throttle ring
August 1964 Cooling flaps replace throttle ring (Type II)
71-74 dog house shroud
Type I used a large negative oil cooler slot
Type II used a large positive oil cooler slot similar to a thing shroud (1971 only)
2 piece oil cooler exhaust ducting
All important hoover bit bolted to oil cooler to seal shroud and direct air through cooler
Thermostat flap rod changed due to dog house addition
Doghouse shroud with modified fresh air outlet for use with A/C
Different left side A/C fresh air outlet
73 thing shroud
One year only for export
Non fresh air heat
Uses large positive oil cooler slot
Early FI shroud
Large neagative slot
Velosity ring on back
Late FI shroud
Small peanut oil cooler slot
Puma shroud
Low profile
Non fresh air heat
Large negative oil slot
Both upright and doghouse versions available
Doghouse type has enclosed oil cooler with round exhaust outlet with matching front tin
Brazilia shroud
Low profile
Fresh air heat
torsionbar
torsionbar is offline
PostPosted: Thu Dec 15, 2011 4:18 pm    Post subject: Reply with quote
excellent, nice work!
Max Welton wrote:
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed.
KopfenJager
KopfenJager is offline
PostPosted: Thu Dec 15, 2011 4:50 pm    Post subject: Reply with quote
And I wast just going to take a pic and post, asking what shroud do I have, but I see it is a 1963 Type II 1500
Non fresh air with larger housing . Sweet. Soon off to Don's powder coating.
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Thu Dec 15, 2011 5:09 pm    Post subject: Re: Official Upright fan shroud thread Reply with quote
that is a late model FI fan shroud.
note the venturi ring, coil & throttle cable location Wink
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Thu Dec 15, 2011 5:11 pm    Post subject: Reply with quote
Very cool thread.....
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
danielsan
danielsan is offline
PostPosted: Thu Dec 15, 2011 5:15 pm    Post subject: Reply with quote
Nice thread.
Puma shroud cooling flap linkage and puma shroud return spring. (German spring shown so you can compare)
KopfenJager
PostPosted: Thu Dec 15, 2011 6:03 pm    Post subject: Flaps? Reply with quote
Does anybod know if a 1963 Type II 1500 Non fresh air with larger housing originaly come with flaps and a thermostat? The one I scrounged out of a scrap pile doesn't have them on it.
66brm
66brm is offline
PostPosted: Thu Dec 15, 2011 6:17 pm    Post subject: Reply with quote
Thermostat yes, flaps no, they use the control ring
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
jl_1303
jl_1303 is offline
PostPosted: Thu Dec 15, 2011 6:29 pm    Post subject: Reply with quote
Out of interest, does anyone know if these seals are still available anywhere?
KopfenJager
PostPosted: Thu Dec 15, 2011 7:02 pm    Post subject: Reply with quote
Ok, where do I get the ring and thermo?
danielsan
PostPosted: Thu Dec 15, 2011 7:47 pm    Post subject: Reply with quote
Brasilia shroud:
Tube for charcoal chamber. Uses the German style exhaust. No Kadron linkage slot. Fresh air tubes do not have an indentation that allows the Kadrons the clear the tubes.
Photo of the stock puma with the provisions for the fuel lines and the Kadron linkage attached:
SRP1
SRP1 is offline
PostPosted: Thu Dec 15, 2011 7:58 pm    Post subject: Reply with quote
The two metal pieces CB Performance has, and they come with the rubber
seals. I would bet they have the rubber pieces available seperatly too.
http://www.cbperformance.com/catalog.asp?ProductID=274
The soft seals are nothing more than foam weather stripping availble at
you local hardware store, home depot, etc...
Almost Alive
Almost Alive is offline
PostPosted: Fri Dec 16, 2011 12:23 am    Post subject: Reply with quote
WOW! Long overdue my friend. I LOVE this post.
74 Thing
74 Thing is offline
PostPosted: Fri Dec 16, 2011 12:34 am    Post subject: Reply with quote
Can you clarify with maybe an explanation or close up photo between the difference of a positve vs negative oil cooler slot?
Thanks
nextgen
nextgen is offline
PostPosted: Fri Dec 16, 2011 8:03 am    Post subject: Reply with quote
What fantastic amount of information.
I vote his post be a permanent information listing.
Excellent.
I like the Venturi Ring, ha!!!!
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Dec 16, 2011 8:06 am    Post subject: Reply with quote
Excellent.
Added to the FAQS/Sticky.
Now if only people would look at it before posting Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Almost Alive
PostPosted: Fri Dec 16, 2011 9:37 am    Post subject: Reply with quote
Excellent.
Well deserved.
AlteWagen
Troll
PostPosted: Fri Dec 16, 2011 12:39 pm    Post subject: Re: Official Upright fan shroud thread Reply with quote
Fixed! Very Happy
AlteWagen
Troll
PostPosted: Fri Dec 16, 2011 12:43 pm    Post subject: Reply with quote
Thanks
Negative oil slot (inverted scoop)
Positive oil slot (scoop)
Joost
Joost is offline
PostPosted: Fri Dec 16, 2011 1:47 pm    Post subject: Reply with quote
Wich is better the late or early FI shroud?
The early shroud looks to be better due to the large slot,
But there must be a reason why they changed right?
I have got two late FI shrouds and one normal doghouse shroud with large negative slot, can i remove the venturi and weld it too the normal shroud as too have better cooling?
Page 1 of 4
