| Author | Message |
		| franklinunes Samba Member
				|  Posted: Thu Dec 15, 2011 11:06 am    Post subject: Questions about some extras oval - birth certicate |   |
				| Hello friends,
 today I received the birth certicate from my Oval Jan 1955, the color is not mencionated.
 Now i am able to tell the is a maching car.
 http://www.youtube.com/watch?v=a-p53GTsWEQ
 the reason to post this topic is to have information about the extras, the last one M094 I am ok
 the other 2 i would like to have more information since I dont know what we are speaking about.
 1) M079 the upholstery I know what it is, but which one would be correct? does anyone have pictures? detailed pictures?
 2) the M018 I am confused with this...
 3) about the color from the car I can believe is Ultra Maroon, tomorrow in the light I will try to find it better and take pictures, by the way which place is better to see the real original color?
 Thanks and best regards
		| Back to top |  |
		| cj1971 Samba Member
				|  Posted: Thu Dec 15, 2011 11:35 am    Post subject: Birth Certificate |   |
				| Hola.........ok i can confirm M018 rear lenses are plastic with a large diamond reflector (rather than the snow flake or chevron)usually found on cars in Sweden,possibly in Norway and Denmark.very rare to find!! Try looking in the glovebox to look for original paint.........as regards the interior probably leatherette in a tan colour?????
		| Back to top |  |
				|  Posted: Thu Dec 15, 2011 12:31 pm    Post subject: |   |
				| Update:
 Seems the color was black
 Any pictures from that reflector? the best would see a picture with them in the car.
 And about the leatherette any pictures? how many types was available?
 If has it look a black car, would maybe has u said a tan colour? any pictures from that tan colour?
 Thanks and best regards.
		| Back to top |  |
		| AlteWagen Troll
				|  Posted: Thu Dec 15, 2011 2:20 pm    Post subject: Re: Birth Certificate |   |
	  | cj1971 wrote: |
 How did you confirm this. With the amount of Export cars documented with this option there would be a TON of these lenses out there.
 My opinion since there has been no documented evidence of the swedish lense used anywhere else besides netherlands
 http://www.thesamba.com/vw/forum/viewtopic.php?t=194361&start=18
 The more I think about it, the chevron may be the standard and the snowflake the larger reflector, but still a guess.
		| Back to top |  |
				|  Posted: Thu Dec 15, 2011 4:13 pm    Post subject: Re: Birth Certificate |   |
	  | derluftwagen wrote: |
	  | cj1971 wrote: |
 The first thing come to my mind when I saw the birth certicate was exacly that, since Jan 1955 they had already the option for the snowflakes, so maybe there was that option on that time, heart tailights or snowflake tailights...the true is the reflector from snowflake are larger than heart tailight...
 I got confused...no sures here then...
 Pictures from Upshory leatherett...if the car was black then the interior would be red or Tan colour like cream for example?
 regards.
		| Back to top |  |
		| cj1971 Samba Member
				|  Posted: Fri Dec 16, 2011 1:27 am    Post subject: M018 |   |
				| Are you saying M018 lenses can be a mixture of several different types???egg/chevron and nordic large reflector.........i tried for 18months to buy the correct lenses for my '57! |  |
		| Back to top |  |
				|  Posted: Fri Dec 16, 2011 4:11 am    Post subject: |   |
				| Hello again,
 I was reading very carefully the several posts available about this subject.
 I got this conclusions:
 Hello All, Just received my 54's birth certificate and have a few questions.T.... m018 "larger reflector in brake/indicator light,"
 "Just for your information... "Portugal market too"
 I got a '57 (exported to Portugal - by the birth certificate).. and came with these lenses.. also in the birth certificate says: M 018 - Larger reflector in brake."
 I have my birth certificate in hands, it is for a 113 VW De Luxe Sedan, Destination Country: Portugal .. and the Extras has
 M 018 Larger reflector in brake / indicator light
 M 094 Lockable rear flap handle
 M 104 Upholstery leatherette Red
 igtoth member 1957
 Mine Jan 55 also has written in Birth Certificate M018 Larger reflector in brake / indicator.
 M 079 Upholstery leatherette instead of material
 "M 018 "Large reflector in brake/indicator light" was used on Swedish- market cars only"
 "I still think there was an early (54? thru 55) extra low snowflake tail light fender."
 (Oct '54 - USA bound) would have had Egg style lights
 Egg tailights USA market only
 "Heart Tailight used until May 1955"
 In Europe
 My conclusions:
 Between March 1954 and July 1957 the M018 code indicating Larger reflector in brake / indicator light was present.
 USA
 EUROPE
 Why a reflector called "larger reflector in brake / indicater light" attached to fender?...doesnt make sence...a M code called "Large reflector in fender" would make sense, like this seems not, has is written it should have wires and volts...so to me this was not a simple reflector attached.
 My tip is this reflector has to do with the lense type...reflection light brake and indicater...a bigger light
 M018 code to oval 1954 (USA) using egg tailights until Oct 54 I believe since USA was more advance to upgrate the tailights I really believe the Snowflakes were available for USA market by that time, despite could be that upgrade! I still believe sweden type reflector it  was also used in USA.
 M018 code to oval Jan 1955 (correct heart tailights then) we could think the same before tip (USA 1954)...change hart tailights to a larger reflector...for example snowflake...but this cant be possible since at 1957 there was also M018 code and they had already snowflakes from factory see the birth certificate 1957.
 Soooooo here it goes my final conclusion...the large reflector had to be something different in the reflector I believe could be the sweden reflector (large reflecting) I believe in fact was this reflector sweden option. Look pictures.
 For example to Madeira Island I believe this could be asked as extra....the roads in 50's where small and bad, actually many curves and many montains...here it goes for example the fog! I believe this was asked because the conditions the Island could offer at the time and besides that more safe for the driver.
 To finnish, the housing u see next was in my oval 1955 the 2 red ones...i mean to tell they are not heart talights, of course could be changed in time, but I believe not, I will find it if I match the same colour which is in the car, the original color from factory.
 The car from igtoth member imported to Portugal from June 1957 had that lenses sweden type and in birth certificate was also there, so this make me think it was for sure the sweden type.
 regards and sorry about the long post.
		| Back to top |  |
				|  Posted: Fri Dec 16, 2011 4:48 am    Post subject: |   |
				| Anyone can explain me this:
 M code 079
 Upholstery, Stone Beige/Fur Grey
 From 1960/61 Canadian color brochure
 If u see my birth certicate	it says
 I have seen other M codes for example the M104 it says clearly "Upholstery leatherette red" Why the M079 code doesnt say exacly what it was?
 tips? according with the BC Upholstery leatherette is correct? right?
 Could be the M104 and other codes refering to leatherette colour used >56 and <56 refering only M079 (not mentioning colour of the leatherette)?
 And this "From 1960/61 Canadian color brochure" is at M079 code and my car is 1955 what has this brochure 60/61 to do with an oval 1955?
 Also could be this colour?
  Can anyone help me to find the correct seat colour leatherette?
 Regards. Thanks in advance.
		| Back to top |  |
		| AlteWagen Troll
				|  Posted: Fri Dec 16, 2011 1:26 pm    Post subject: |   |
				| I believe M042 is the correct code for the large diamond tail light lenses.
 M079 just means you got letherette instead of cloth which is correct for domestic deliveries.
 Being that most BC that have no color mentioned were special order the correct color of your letherette is a mystery as well. To me your color does look like ultramaroon which for export usually came with red or beige interior.
 This WW page doesnt list anything in particular
 http://www.wolfsburgwest.com/colors/54l276.htm
 The samba listing only states the cloth in beige with a 50 reference code
		| Back to top |  |
				|  Posted: Sat Dec 17, 2011 12:50 pm    Post subject: |   |
 Then I guess I can paint the car the colour i like most and Upholstery leartherette...I bet in the car black and leatherette beige.
 In concerne to tailights I believe there isn't conclusions...wait for other options in future. If was other kind of reflector attached to the fender it should make also the brake and indicater light.
 derluftwagen why do you think the car be ultramaroon
  ...? just a guess? I can't see nothing there ultramaroon, can be seen maybe the maroon but the ultramaroon is very different.
 I can see under that paint in some places the colour black under, but monday i will make an investigation and take better pictures, use a X-act to see under what it is.
 Regards.
 Frank
		| Back to top |  |
		| IN2VWS Samba Member
				|  Posted: Sat Dec 17, 2011 1:49 pm    Post subject: |   |
				| I am not convinced that the M018 was for larger reflectors on the earlier cars. VW re-used the 'M' numbers over the years, using them for different things.
 M018 was for larger reflectors on later cars, that is well documented in factory literature. example:
 M18	with larger reflectors in the brake/indicator light, up to Chassis No. 117 507 257 - from a 1967 parts manual.
 It is only my opinion, but I believe that the factory does not know what M018 was in the 1950's, so they are giving the description for the later M018.
 As for M079....This is from a 10/1955 Salesman's catalog:
 M79	Beige leatherette upholstery, for all VW standard colour schemes.
 If you had red leatherette, you would have option M104 listed instead of M079:
 M104	Red leatherette for sedans with Nile Beige and Black finish.
 (ọ\   ¡   /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
 ⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
		| Back to top |  |
				|  Posted: Sat Dec 17, 2011 2:47 pm    Post subject: |   |
	  | IN2VWS wrote: |
 M018 or M18
 Hum I understand, I didnt know that, so they use M code later for the same M code early...then like this we are back to zero...so you dont believe the M18 is the same M018?
 Then everything is turned down
  side down.
 then what do you say about this M code?
 135 	Upholstery, leatherette Beige (thesamba) then if my car would be beige should have the M code 135??
 So what do you sugest? the catalog is from 10/1955 and the car is from 1/1955
 but in my case according tecnical from thesamba the M079 Upholstery, Stone Beige/Fur Grey and which says is leatherette instead of this material, nothing is written about the leartherette colour if beige red or other.
 but for example according to another info i found this:
 Januar 1954 bis Februar 1955, ab Fg.Nr. 1 - 579 683 bis 1 - 823 604
 Karosserie (body) 	                                 L 41 schwarz (black)
 Polsterkombination Kunstleder (leatherette) 	 K 110 beige
 K 155 rotbeige
 then in your opinion what should be the leatherette colour?
 Like this could make sense Back the body then leatherette beige or red no?
 Regards.
		| Back to top |  |
		| IN2VWS Samba Member
				|  Posted: Sat Dec 17, 2011 3:21 pm    Post subject: |   |
				| M135.....as I mentioned earlier, they changed over the years. Here are my listings for M135:
 M135	Dark blue leatherette upholstery for Sedans with Strato Silver finish. -	10/1955 Salesman's Manual
 M135	With soft beige leatherette for beryl green finish only. -	8/1960 M Option Catalog
 ⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
		| Back to top |  |
		| 56Cabrio Samba Member
		| Back to top |  |
		| IN2VWS Samba Member
				|  Posted: Sat Dec 17, 2011 3:39 pm    Post subject: |   |
				| Does anyone have a birth certificate from the mid to late 1950's that does not have M018 on it? _________________
 ⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
		| Back to top |  |
		| Back to top |  |
		| IN2VWS Samba Member
				|  Posted: Sat Dec 17, 2011 3:47 pm    Post subject: |   |
	  | franklinunes wrote: |
 K 155 rotbeige
 Regards.
 In my opinion, If your car had red leatherette upholstery, then the birth certificate would show option M104 and not M079.
 Yes, the cars came with Red (M104) or Beige (M079) leathette, and depending on which colour was used, the associated 'M' option would be listed on the birth certificate.
 The reference you listed above only lists the options available and not the 'M' option number that goes with those options.
 ⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
		| Back to top |  |
		| Back to top |  |
		| AlteWagen Troll
				|  Posted: Sat Dec 17, 2011 4:01 pm    Post subject: |   |
	  | derluftwagen why do you think the car be ultramaroon  ...? just a guess? I can't see nothing there ultramaroon, can be seen maybe the maroon but the ultramaroon is very different.
 the white arrows look like ultramaroon to me then it looks like black, then the two different reds.
		| Back to top |  |
		| IN2VWS Samba Member
				|  Posted: Sat Dec 17, 2011 4:30 pm    Post subject: |   |
	  | 56Cabrio wrote: |
	  | 56Cabrio wrote: |
	  | Here is my BC for my vert, M018 and others can not be identified?
 |  What is M 050 & M 918 anybody?
 M918	With leatherette instead of cloth material	8/1960 M Option Catalog
 ⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
		| Back to top |  |
