shroud not fitting properly
VW-Gasser
VW-Gasser is offline
PostPosted: Sun Dec 25, 2011 7:19 pm    Post subject: shroud not fitting properly Reply with quote
Hi,
I want to put a 36 HP fan shroud on my 2110cc engine. I tried to fit it as tight as possible, but I ran into the following problem: The shroud is fitting at the ends of the cylinder tins nicely but the area where the cylinders meets the case is barely covered.
Any suggestions how to fit it perfectly?
Thanks
Karsten
-- www.vw-gasser.de --
ArnoudH
ArnoudH is offline
PostPosted: Mon Dec 26, 2011 4:43 am    Post subject: Reply with quote
Is it an Aluminum case?-they are thicker on top so they might require some clearancing.
Karsten:nichts wie 'ran mit dem Flex! Laughing
VW-Gasser
PostPosted: Mon Dec 26, 2011 8:54 am    Post subject: Reply with quote
no, it is a AS41 Brazilian case and I already cleared the case area.
I looks like the angle of the shroud does not match the angle of the cylinder tins although they are all original, not aftermarket!
Arnolds64
Arnolds64 is offline
PostPosted: Mon Dec 26, 2011 9:02 am    Post subject: Shroud. Reply with quote
Tin Snips.
64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels.
ALB
ALB is offline
PostPosted: Mon Dec 26, 2011 9:18 am    Post subject: Reply with quote
Using sheet metal from different eras can be a problem when trying to get everything sealed up properly; assemble it with the alternator/generator and stand and then see how it fits.
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Matthew
Matthew is offline
PostPosted: Mon Dec 26, 2011 9:23 am    Post subject: Reply with quote
That's a "stale-air" 40hp shroud btw. You may need to grind on it some where it sits on the case to get it down a little lower. Your cylinder tins may need some tweaking to get the angles right.
ALB is right, bolt it all together before you modify anything else.
1965 Beetle sedan
Click to view image
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Dec 26, 2011 9:36 am    Post subject: Reply with quote
You'd be better off with a late model shroud and a offset oil cooler.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
fredy a
fredy a is offline
PostPosted: Mon Dec 26, 2011 11:28 am    Post subject: Reply with quote
x2 30 hp shroud is nice but you be better of having a later on
sorry for the spelling
thefladge
thefladge is offline
PostPosted: Tue Jan 03, 2012 11:46 am    Post subject: Reply with quote
I use that same fan shroud on my 2110cc engine. The cylinder tins I use are from a fuel injected engine and everything fits together very well.
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
mark tucker
mark tucker is offline
PostPosted: Tue Jan 03, 2012 1:09 pm    Post subject: Reply with quote
most I have seen are like that.I use lifeline cover on mine,(the small stuff,sail boat)and it also keeps the tin from chafing&eating at the case&seals a bit better.along with some sealer(silocone or pollyurathane at the big aeras on the case/shroud so It cant be seen but seals, you can fit the shroud to the caseusing the alt/gen to hold it where it go's,trim if needed for clearance,wax the case real good and polyurathane sealent the inside of the shroud so when you lower it and tighten the alt to keep it in place it will make a mold of the case and a perfect seal,the wax should let the seal addhere to the shroud&not the case, so you only do it once.and do it for both side's,well inside the shroud on front&back so it dosent loose air,and you can also make it seal around the oil kooler better while your there.&tins too.there are lots of way to skin a cat,some will get you bit,some just a scratch& a fever.
