AlteWagen Troll
Posted: Tue Dec 27, 2011 12:28 pm Post subject: Engine blueprinting worksheets |
Since i always just scribble notes on small sheets of paper just to loose them and remeasure, I decided to make some worksheets that I can keep for future reference and to give to customers when I complete a build.
There are a few things that I remembered I left out and have added in to the original document but I would like feedback for more stuff I forgot or things I should remove (retainer weight??). Think if you were to have someone build you an engine, what info would you like to see?
Thanks
Update - This is now on the site in PDF Format.
Link:
http://www.thesamba.com/vw/archives/info/blueprinting_worksheet.php |
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Tue Dec 27, 2011 12:58 pm Post subject: |
That is a wonderful list, thanks for spending the time on it  _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
craigman Samba Member
Posted: Tue Dec 27, 2011 1:23 pm Post subject: |
Very nice!
Anyone who assembles an engine should have one of these.
Definately beats the binder paper i've been using!
Thanks! |
slalombuggy Samba Member
Posted: Tue Dec 27, 2011 1:31 pm Post subject: |
craigman wrote: |
Very nice!
Thanks! |
Actually, anyone who BUILDS an engine should use these. Engine assemblers don't really care to get this detailed
Thanks for working at making this list , I'll be printing them off
brad |
Posted: Tue Dec 27, 2011 1:40 pm Post subject: |
Well i consider myself a "assembler". I've assembled many engines with great sucess, but I definately don't have the smarts of Raby, Chico, ect. I consider those guys builders!
But i still take the time to measure everything (as should anyone assembling a engine) and write it down.
But derluftwagen did an excellent job with his spreadsheet! I know it will make it easier for me now!  |
AlteWagen Troll
Posted: Tue Dec 27, 2011 2:13 pm Post subject: |
I am waiting for more feedback to finalize the sheets. Once completed I will send them to EB to post as a PDF or what ever format he recommends.
There are a few things not on these JPEGs like:
Quick summary
Installed deck height/head cc/shim stack/copper gasket table
Final end play shim stack measurement
Quick reference torque table
Solid rocker shaft shim measurements
Rocker stand shim measurments
Actual valve lift measurement (installed specs for rocker arms (true ratio))
Sand seal type check boxes
Flywheel dowell pin size/lenth
Gland nut type/size and final torque
Pushrod tube type/size/seals
etc...
Im sure there are other things Ive forgotten so I need some "builders" to chime in.
Thanks again!!! |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Tue Dec 27, 2011 2:31 pm Post subject: |
I have some almost exactly like these for TIV based engines.. Looks really good. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
too much writen fer me.but nice work, as some realy need that kind of stuff and some want that kind of stuff, then there is the ones who,have to have that kind of stuff(ocd, witch I have but not that bad).I do how ever have stack sheets that take the big part of guess work out of figuring the stack& what will be needed in theroy for each combo,just add it up.(I havent checked the AA cylinders&pistons for the sizes I only have 1 set of 92b's from them) |
AlteWagen Troll
Posted: Tue Dec 27, 2011 2:40 pm Post subject: |
I guess I am ocd when it comes to putting together an engine for a customer that will drive their car daily to work!!! Even stock builds need some added attention as the cores are 40 years old and have been through hell not to mention china parts.
That and the fact that most machine shops are using 50+ year old machines that MAY get calibrated every 20 years or so. By taking measurements before any assembly you can tell if the line bore is crooked or the crank is warped.
Another reason I put these together is for the novice builder. Even if they do not know everything (who does) it will help them learn what to look for. How many posts do you read about seized rebuilds or junkyard builds that are all mis matched? If you want to use used parts just measure the parts, and 90% of the worry is gone! |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5303 Location: Southern AB
Posted: Tue Dec 27, 2011 3:20 pm Post subject: |
It would be nice if it was a word file or something you can add the numbers to.
I find when I do a paper print out of something like this it either ends up with assembly oil, or sealant,or lunch on it so it would be nice to print out a copy with the info entered and readable.
Like this one I have been using:
http://www.aircooledtech.com/parts_list/
only trouble is if you scroll down to the total when the wife is looking over your shoulder........  _________________ 1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2163 Location: Salt Lake City
Altema Samba Member
Joined: June 20, 2010 Posts: 2906 Location: Lower Michigan
Posted: Tue Dec 27, 2011 4:31 pm Post subject: |
Looks good, nice job. I have a spreadsheet I put together for mine, but yours looks more professional. Only thing that might be nice is a before/after weight on pistons and rods. Mine were all over the map (401 to 406 grams!), and some people might want to know how close or far off they were.
Paul |
Posted: Tue Dec 27, 2011 7:18 pm Post subject: |
[quote="W1K1"]It would be nice if it was a word file or something you can add the numbers to.
Like this one I have been using: hey hes talknig about me !! great for some just not me.did it years ago or tried any way, but great for some.
http://www.aircooledtech.com/parts_list/ |
Rome Samba Member
Joined: June 02, 2004 Posts: 10572 Location: Pearl River, NY
Posted: Tue Dec 27, 2011 10:26 pm Post subject: |
Excellent list; significantly more detailed than the log sheets I devised 10-15 years ago. How about a space for each major component, as to its origin/where you bought it? This was significant for me, being a home hobby builder and finding parts at swapmeets or buying them new.
After posting my response and viewing the lists again, I realized you do have several lines' space at end of each section for such "notes'.
Also, how about
- in which car was the engine installed (customer name, or type of VW and when)?
- The case sealant (to monitor if the engine leaks soon or not),
- initial carburetion,
- exhaust system? |
ViLL Samba Member
Joined: September 07, 2009 Posts: 263 Location: La casa de tu pinche madre guey!
Posted: Wed Dec 28, 2011 12:00 am Post subject: |
I remember these sheets when I raced 1/8th scale R/C buggies...tedious work getting shit dialed then simply refering to your tweak sheet for various settings/adjustments. There was even an empty block for our nitro engines...shims, glowplug heat range, pipe, exhaust manifold, clutch springs, clutch shoes.....it was insane!!!!  _________________ '10 Audi A4 Avant Premium Plus S-Line w/ 19"sport pkg |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20817 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Dec 28, 2011 10:28 am Post subject: |
Word or EXCEL document would be awesome then people can print them out as need be.... OR modify for special circumstance...
IF you make a Word or Excel file I can host them for download on my site, on "Technical Links" page
http://www.mydune-buggy.com/
Would also host PDF version if it were available....
Dale _________________ “Fear The Government That Wants To Take Your Guns"
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2373 Location: Mount Airy, Maryland
Posted: Wed Dec 28, 2011 11:24 am Post subject: |
It's too bad I can't see photobucket images from work but I have my own sheet in Excel. Derluftwagen, any Chance you want to host your on thesamba instead of photobucket? _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Almost Alive Samba Member
Posted: Wed Dec 28, 2011 12:23 pm Post subject: |
Wow, this is terrific. Do you happen to have it in an excel sheet? |
AlteWagen Troll
Posted: Wed Dec 28, 2011 3:08 pm Post subject: |
like I posted earlier, still working on the final version and when complete I will make it a PDF and post it here for all to use.
Currently it is in a word doc and is in a fillable form and will offer it in both versions if possible. |
Posted: Wed Dec 28, 2011 3:09 pm Post subject: |
derluftwagen wrote: |
Oh cool, sorry. I obviously missed that part. Anxiously awaiting it! |
