Rephrased Carb Question
marfulle
marfulle is offline
PostPosted: Thu Jan 05, 2012 2:29 pm    Post subject: Rephrased Carb Question Reply with quote
I inherited this bug, and it has a 2L high performance street ( mild cam and head work) motor in it. It has dual 44s and was wondering if I could put a progressive set up on it to simplify things for me. I would consider dual kadrons but want to keep it as simple as possible. Any thoughts?
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Classifieds Feedback
mark tucker
mark tucker is offline
PostPosted: Thu Jan 05, 2012 2:57 pm    Post subject: Reply with quote
duel 44 idf?(2 ,2 bbl) keep them it will run and be a lot easyer to tune than a single or pair of kdogs, and get better mpg.
marfulle
marfulle is offline
PostPosted: Thu Jan 05, 2012 3:36 pm    Post subject: Reply with quote
They are dual Webers 44s. (2, 2bls)
jfats808
jfats808 is offline
PostPosted: Thu Jan 05, 2012 3:41 pm    Post subject: Reply with quote
If you switch to a progressive you will lose hp and lose MPG. Additionally you will have to set up the proper preheat to get them to work right. Like we explained in your other post, once you do some investigation/maintaining, and repairing on your current dual 44 idf set up, you will be a very happy camper. Dont move backwards. Move forwards.
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
baked beetle
baked beetle is offline
PostPosted: Thu Jan 05, 2012 4:02 pm    Post subject: Reply with quote
I think you would be mildly crazy changing them out to 'simplify' things for you. Learn about the carbs, (it's not that hard) and you will be happy you kept them. A progressive carb on that motor would be ridiculous.
These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE)
yamaducci
yamaducci is offline
PostPosted: Thu Jan 05, 2012 4:15 pm    Post subject: Reply with quote
Not to mention the progressive is more of a pain to tune right the first time than duals.
You couldn't ask for a better set of carbs to start with and learn on..
Buy the Weber book and ask questions.
MHarney would be a good person to get in touch with if you need parts or tuning help but you should do some homework yourself first.
If we haven't talked you into them then PM me when you are ready to sell them.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
bsairhead
bsairhead is offline
PostPosted: Thu Jan 05, 2012 4:28 pm    Post subject: Reply with quote
I have a Weber progressive on a 1914 set up dialed in and tuned perfect, I would trade in a heartbeat for your 44's. If that tells you anything.
DarthWeber
DarthWeber is offline
PostPosted: Thu Jan 05, 2012 10:14 pm    Post subject: Re: Rephrased Carb Question Reply with quote
NO Exclamation Shame on you Not talking d'oh!
Dude, seriously, take a deep breath, exhale and please read these tech articles before you do anything else. Once you understand what's in these articles you'll see that keeping your IDF's is a smart thing. Very Happy
http://www.hornbyislandwares.com/acn/671/vw-carburetors-102-basic-jetting-theory-procedure/
http://www.hornbyislandwares.com/acn/672/vw-carburetors-103-synchronize-dual-carburetors/
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Thu Jan 05, 2012 10:17 pm    Post subject: Reply with quote
Why the hell is the progressive carb still being made? Because people like to buy shit! Cheap shit!
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
DarthWeber
PostPosted: Thu Jan 05, 2012 10:19 pm    Post subject: Reply with quote
R - E - L - A - X!!
Breathe deep the gathering gloom.......
77charger
77charger is offline
PostPosted: Thu Jan 05, 2012 11:24 pm    Post subject: Reply with quote
I had dual kads o my 1776 i then built a 1914 and went to 44s.The idfs are easier to deal with alot smoother then the kads.These were my first experiences with duals.IMO it was not bad to get them working
You stat with carbs that need work or bad linkage you will never get it right.
Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine
volkyoo
volkyoo is offline
PostPosted: Thu Jan 05, 2012 11:28 pm    Post subject: Reply with quote
I spent a few years with a Progressive carb. first cause some people advicedme wrong! and i was a litle affraid of two carbs... but a few months ago i installed my set of 44 webers and couldnt be more pleased,more performance better mileage, i dont live in the usa and dont have people near by with duals, i had to install and tune by myself and ask a lot of questions here, read books and like that!
modok
modok is offline
PostPosted: Fri Jan 06, 2012 12:20 am    Post subject: Reply with quote
The kadrons are very simple far as being really crude only a handful of jets, and the airfilters are easier to fit
BUT if you get a good linkage, and an airfilter setup that stops dirt, and make sure the carbs are built right, it will BECOME 100% "reliable" with your 44 webers
Buellistic
Buellistic is offline
PostPosted: Fri Jan 06, 2012 2:22 am    Post subject: Reply with quote
DarthWeber wrote:
R - E - L - A - X!!
Watch lights fade from every room...
And as an aside, I am a bit drunk AND this post helps me with a current project quite a bit... Glad someone posted about it.
mark tucker
PostPosted: Fri Jan 06, 2012 5:36 am    Post subject: Reply with quote
no not because ther cheep, because the owners or guy adding the "HIGH PERFORMANCE" carb is skeered of 2 carbs.I have seen it somany timesI could puke,and the guys that can do it all better than anybody else puts on the duels,dont know how to 1 tune then, 2 sync them,3 install them corectly,4 add fuel filters,5 use air filters,6 runs a oil hose to the airfilters on his 86%blowby motor. and thus the reason for the, "new"lightly used for 2 months carbson the market witch leads them to the progressive&singles, witch they never get working right either.
volkyoo
volkyoo is offline
PostPosted: Fri Jan 06, 2012 10:30 am    Post subject: Reply with quote
x2
i was one of them... mostly cause nobody over here have duals. the guy i bought mine had them from like 8 years ago , this guy bought a lot of things for his beetle, including carbs but due to the poors mechanics over here they couldnt even make it IDLE, this guy sold his beetle and just keep the carbs in a box(nobody wanted to buy it since they had problems according the local mechanics) till i ask him about the carbs, he sold it to me and he still cant believe that my carbs are running like that. he swore to me that the problems with the carbs was the IDLEING system , that this carbs NEVER idles... the mechanic set idle at 1300rpm.... Guess what?? i bought it, took it apart(luckily he took out all the gas before storage) cleaned it and SET the floats that were wayyy off(never done), changed the gaskets, installed it , did the pre tune procedure and woila. know some peolple ask me who did it , who tuned it, and when i say ME they just think that is not as impossible as the mechanics were parroting... know they idles at 900rpms steady... good gas mileage, better than the proggresive , more performance.
sactojesse
sactojesse is offline
PostPosted: Fri Jan 06, 2012 11:02 am    Post subject: Reply with quote
Stick w/ the 44 IDFs. 20 years ago, I had a pair of 44 IDFs on a mild 1967 (92 x 74) engine (Engle W110 cam w/ ported and polished stock heads) in my 1965 ghia coupe. That thing pulled HARD w/ the IDFs and still got around 30-35 mpg on the highway despite the low 4.375 ring and pinion. My record was 36 mpg on one trip! Yeah, it only got around 20 mpg if I was flogging it around town, but the highway mileage was incredible. Plus, it had excellent drivability. Smile
1966 Karmann-Ghia convertible
