Fulcrum and SAW+ Super DIFF problem
Koyote
Koyote is offline
PostPosted: Fri Jan 20, 2012 7:40 am    Post subject: Fulcrum and SAW+ Super DIFF problem Reply with quote
Hello,
First of all, some caracteristics about my car :
1969 beetle (1984pds with me in it)
stock gear box 1974
3.78, 2.06, 1.26 welded, 0.82 welded, 4:12 ring and pinion
Super diff C -clips
poor man posi
Sway a way axles 28- 7/16
Engine is a draw through turbo 2276
Clutch is a Kennedy stage 1 + sintered Jay Cee disk (sort of black magic).
It's a Daily Driver + Drag races in a 12" index class
11.67" best ticket
the race tires are the M&H DOT 215x15 (tire pressure is 17 psi)
NO burnout, only a quick blast in 1st gear, just to remove water.
RPM launch (1st step) is 4200 rpm.
60 fts are 1.80 just to be in the safe side, but I can do 1.65.
During the winter pause, I tore down my gearbox, for a complete revision, because I have no trailer and it’s out of the question to be worried on the road!
Here’s what I have found, only on the left side :
What can cause this ? obviously a lubrification problem ? the poor man posi too tight, for road driving ? What can be done to improve oiling the super diff? bigger holes, another holes? where ?
Thanks for your help !
2276cc daily draw through.
Koyote
Koyote is offline
PostPosted: Fri Jan 20, 2012 8:08 am    Post subject: Reply with quote
Well hum I don't know why I can't insert images here with the [img][/img]
Confused
ozarkbaha
ozarkbaha is offline
PostPosted: Fri Jan 20, 2012 9:41 am    Post subject: Reply with quote
69 with a swing,i like.looks like maybe a lack of lube,but not sure it doesnt look burnt.what kinda carrier do you have?and do you have the other side tore down,if so does it look good?
Koyote
Koyote is offline
PostPosted: Fri Jan 20, 2012 10:09 am    Post subject: Reply with quote
I used synthetic oil 75/90 : it smells burnt and black. the right side is still in good shape, not perfect, but reusable.
I didn't install the super diff, but when you at it it seems very difficult for the oil to reach the left side, So I am thinking about enlarging the existing holes. There is another option I should consider? I cannot buy a quaife, so I am sticked with this super diff for the 2012 drag race season.
Sorry but I don't undestand what you mean by "carrier" ? Embarassed
vdubnut58
vdubnut58 is offline
PostPosted: Fri Jan 20, 2012 10:17 am    Post subject: Reply with quote
I had a similar problem last year. Was using synthetic 90w gear oil and it was just too thin. I am now running redline medium shock proof. I also found that polishing up the ends of the axles and fulcroms help. I tried having extra oiling scoops added to the super diff first. Added 3. That didnt cure the problem 100% as your driving down the road all the oil is getting slung out of the super diff. You need some really good and sticky gear oil to keep them lubed.
This was the end result. Nice 60' by the way!
Koyote
Koyote is offline
PostPosted: Fri Jan 20, 2012 10:28 am    Post subject: Reply with quote
Thanks vdubnut58. So, oil choice is a part of my problem... I will find one more sticky. May be add some "miracle additive" ! Laughing
Koyote
Koyote is offline
PostPosted: Fri Jan 20, 2012 10:31 am    Post subject: Reply with quote
Do you think that adding a poor man posi, as I did, can aggravate things ? on the left size, the spider gear was very tight, starting to be seized in the super diff...and the shims of the PMP are chewed up.
vdubnut58
PostPosted: Fri Jan 20, 2012 10:54 am    Post subject: Reply with quote
I am sure it didn't help. When your setting up a Trans for drag racing you want everything nice and tight to minimize the shock on the parts. But on the street, mainly on the highway. It starts to take its toll on the parts. I would freshen it up and switch gear oils. Try GL 5 as it has a high pressure rating and has the friction modifier for limited slip in it. Or if you like synthetic find a shock proof type oil. Not sure what you have over there.
Koyote
Koyote is offline
PostPosted: Fri Jan 20, 2012 11:01 am    Post subject: Reply with quote
Yes you are right. It's a mistake I made. I didn't think about the shocks on the diff when driving my bug on the road, especially in a tight corner, and we have a lot of corners over here !
I will not reinstall one, just keeping the diff in OEM specs (0.05mm).
yamaducci
yamaducci is offline
PostPosted: Fri Jan 20, 2012 11:15 am    Post subject: Reply with quote
Confused
Works easier if you add pics to "My Photos" under gallery then take the "Forum Code" from that page and paste it in your thread updates. You can then preview to make sure it's visible.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
Dougy Dee
Dougy Dee is offline
PostPosted: Fri Jan 20, 2012 1:10 pm    Post subject: Reply with quote
How large are the oiling holes in the superdiff?
Did the side gears/cups gall the bores of the diff?
There are tricks to setting up the PMP. BERG used to have good info on that. I'm not sure whether their website has the info up. For street trim I hang a brake drum off the end and set them up so that it takes serious effort to turn the assembly. Not locked up solid.
On another note I drill two 5/8 or 16mm diameter holes in the diff for lubrication. Drill so that diff rotation will 'scoop' oil in to the internals.
The damage you show and describe sounds like lube problems.
Koyote
Koyote is offline
PostPosted: Sat Jan 21, 2012 4:56 am    Post subject: Reply with quote
yamaducci wrote:
Confused
Thanks for the tips ! I work now ! Wink
Koyote
Koyote is offline
PostPosted: Sat Jan 21, 2012 5:31 am    Post subject: Reply with quote
There are two holes with "scoops" the diameter is 15mm (0.590). there are signs of seizing in the super diff and on the spider gears :
Banzai KG
Banzai KG is offline
PostPosted: Sat Jan 21, 2012 4:57 pm    Post subject: Re: Fulcrum and SAW+ Super DIFF problem Reply with quote
Apparently what I see in your last pic of the axle spade are the sharp corners which would gall up the fulcrum plates.
Best solution to reduce wear on the fulcrum plates is to get your axle spades radius (remove the sharp edges) and polish the ends.
I've done that to my set of SAW axles and I'm also running the GB Poor Mans Posi kit.
Check out these videos about radius and polishing the spade ends:
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
Koyote
Koyote is offline
PostPosted: Sun Jan 22, 2012 2:37 am    Post subject: Reply with quote
Thanks Banzai KG!
That is something I will do on my new axles for sure !
So in the end I'll have to do :
1) enlarging all the holes, the two large ones with those "scoops", and the 4 small holes, redrilling them with a angle, to act as scoops.
2) radius and polish the axles
3) use a thicker oil
There is another thing I noticed : the wear on the fulcrums. It seems the axles were not fully engaged. there is an area on the fulcrums still intact, without any marks. As a side note, I have installed the OEM spacer behind the bearing. Any ideas ?
Banzai KG
PostPosted: Sun Jan 22, 2012 3:49 am    Post subject: Reply with quote
Speaking of fulcrum plates, I'm running grooved fulcrum plates that looks like what's pictured below (not my picture):
I bought my set from Gene Berg a long time ago.
Jim Kikuchi
Koyote
Koyote is offline
PostPosted: Sun Jan 22, 2012 5:02 am    Post subject: Reply with quote
I saw those fulcrum plates in my local shop. That can help oiling in that critical area ! I will add this to my "what to do" list ! Wink
ozarkbaha
PostPosted: Sun Jan 22, 2012 7:08 am    Post subject: Reply with quote
imo from looking over your pics,i think the drive gears an carrier are galled to bad to reuse.but i think my be something up with the carrier not supplying lub,maybe no holes,holes not in the right spot or to small,not sure of cause.i would get someone to check it out that knows transaxles.genos advice an vid are great,and as he stated his plates are gene berg.i wouldnt use anything but berg there, or good looking stock german, german are hard to beat.i also think ur wear pattern is normal for such a fail as this(the wear on the plates).no lub does strange things.the pmp isnt the reason for failure,im sure. alltho i dont think one wil ever hold up well in a street driven car.corners will take there toll.i would reassemble with top grade stuff and drive the SH#T OUT OF IT hope this helps.
Koyote
Koyote is offline
PostPosted: Sun Jan 22, 2012 7:52 am    Post subject: Reply with quote
Here are some pictures of the oiling holes enlarged:
"scoop" effect "improved" and bigger hole :
The same from the inside :
The 4 small near the ring, and from the inside. at left, the stock hole, at right modified, drilled with an angle. so the hole is now in an oval shape (11x9mm) is that enough ? :
Koyote
Koyote is offline
PostPosted: Sun Jan 22, 2012 8:12 am    Post subject: Reply with quote
ozarkbaha wrote:
imo from looking over your pics,i think the drive gears an carrier are galled to bad to reuse.../...the pmp isnt the reason for failure,im sure. alltho i dont think one wil ever hold up well in a street driven car.corners will take there toll.i would reassemble with top grade stuff and drive the SH#T OUT OF IT hope this helps.
ozarkbaha, I will change the spider gears by better ones, but I will re-use the super-diff, who is in a better shape than it seem in the pictures.
It is definatly a lack of lubrification that cause the failure. I still have doubts about the PMP in a street use. Some of the shims were chewed up and then fallen in the bottom of the case. Lubrification, or lack of lubrification didn't help at all.
So, I am thinking to rebuild the super diff without the PMP, but with the tightest VW tolerances (0.05mm).
