svenakela Samba Member
Posted: Fri Jan 20, 2012 5:35 pm Post subject: |
| MR GAS wrote: |
we should be measuring from the van Floor to the bottom of the trans and to the bottom of the oil pan. Not from the ground! every van is at a diffrent ride height and tire combo . the only consistant is from a fixed surface not the soft suspension.
I will do some measuring and picture taking over the weekend.
Greg |
That was a very good point! |
jabba Samba Member
Joined: April 30, 2008 Posts: 92 Location: La Rochelle (FRANCE)
Posted: Sat Jan 21, 2012 12:59 am Post subject: |
| MR GAS wrote: |
....and Front Brakes from the 99 Passat.
So its a Vanassat or is it Passangon. Passatagon
I could make these mounts if there is enough interest in them.
Ahahaaaa, i'm interested by the front brake conversion.
What kind of calipers do you have from your passat and what's the year of production of your vanagon? Mine is 1982.
I've got girling 54 from my Seat ibiza tdi engine donor. (The last eurovan 150hp tdi used 54 or 57 calipers). _________________ vanagon 1,9 tdi pd 130 hp |
MR GAS Samba Member
Joined: October 29, 2008 Posts: 129 Location: Canon City
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10122 Location: Where?
Posted: Sat Jan 21, 2012 7:24 am Post subject: |
| Nice job. I've considered the same swap in the same manner. I'd want better flow through the intercooler. A Saab 900 intercooler in the driver's side D-pillar or a liquid2air system would fit the bill. Another option would be to add the diesel belly pan and louvers on either side of the license door, but I wouldn't want the intercooler there at all and would keep the ability to check/add coolant and oil. |
MR GAS Samba Member
Posted: Sun Jan 22, 2012 5:44 pm Post subject: |
Here are some pics. of the rear tin mods. and the intercooler.
Does any one have pics of a VD Belly pan? i ve never seen one and prefer reverse engineering over inventing stuff.
MR GAS Samba Member
Posted: Sun Jan 22, 2012 6:22 pm Post subject: |
| purplepeopleeater wrote: |
| Looks great, 50* is the way to go, how's the ground clearance? I was looking at this on the vortex too. |
Here are pics of the clearance in my lower 84 2wd westy. Transaxle in factory stock location!
Oil pan is higher than the diff area of the trans. (my lowest point) and goes up slightly towards the rear. almost as high as the mustache bar.
Beetsport  Samba Member
Joined: January 08, 2005 Posts: 478 Location: Sacramento, CA
MR GAS Samba Member
Posted: Tue Jan 24, 2012 10:33 am Post subject: |
| Beetsport wrote: |
I see your I-Cooler is located where your license plate was. How are you keeping it cooled down & what are your intake temps?
Nice job keeping it all tucked away  |
I have plans for testing the efficiency of the intercooler.
But right now the high temps out side are in the 60's F.
I havent been able to find my Vagcom cable to see IAT's
Beetsport or anyone maybe you would know if the comp will send a OBD code if it gets too hot??
This cooler is 3.5 x larger than the Passat one. The opening under the lic. plate is the same size as a passat IC. the new IC is sealed front to back w/ foam rubber. i added lower tin under the engine to promote a +positive air press in the engine comp.from the scoops.( and to keep turbo temps out) and am hoping the -vacuum at the rear of my breadbox will do the rest.
I have a GOPRO and some yarn that im going to attach to the rear of the Vanagon to see if i really get any air flow. im hoping so ! but wont know till i do it . the motor runs really cool and the IC is only warm to the touch.
#1 is that this is a project still under construction.
Thx Greg |
Posted: Tue Jan 24, 2012 10:48 am Post subject: |
| MR GAS wrote: |
| Beetsport wrote: |
Thx Greg |
Your ECU will not set a trouble code for overheated Intake temps. On the AWP engine ECU the computer system will just limit boost pressures and ignition timing to save the engine.
The rear of the Vanagon has a void of air flow. I would recommend an Water over Air cooler system instead if you determine your intake temps are getting up there. You can see where we install our coolers. We are limited to CA smog laws and have to run the original cooler...
Also recommend a Scan Gauge II to connect to your data port for temps while driving. Handy device to check sensors while driving that you can leave in your Vanagon with an OBDII system. _________________ '90 Syncro Westy 1.8T with 180hp 174 torque, CA safe!
http://H2oVanagon.com
http://www.thesamba.com/vw/forum/viewtopic.php?t=217285 |
MR GAS Samba Member
Posted: Tue Jan 24, 2012 11:17 am Post subject: |
Beetsport said:Your ECU will not set a trouble code for overheated Intake temps. On the AWP engine ECU the computer system will just limit boost pressures and ignition timing to save the engine.
Also recommend a Scan Gauge II to connect to your data port for temps while driving. Handy device to check sensors while driving that you can leave in your Vanagon with an OBDII system.[/quote]
MR GAS said: Ill look into the Scan Gauge II if i cant find my Vagcom cable. i never have to use it and it goes a long time between . I forget where i put it.
I hope this IC works out.
Void I am hoping means Vacuum over the positive scooped air in the engine comp. Ill keep samba informed.
How much $$ does a water to air set up cost?
Thx Greg |
fairweather Samba Member
Joined: August 26, 2007 Posts: 663 Location: Aspen, CO
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed Jan 25, 2012 5:51 am Post subject: |
| fairweather wrote: |
planning on going with the awic with the radiator set up in front like alaric.h has his, integrated into a brush guard.
Tom, how would that work, you route air intake to the front of the van and back? Or you have 2 tanks? I must be missing something. Dave |
MR GAS Samba Member
Posted: Wed Jan 25, 2012 6:38 am Post subject: |
| davevickery wrote: |
The IC is in the same engine comp location and Water lines run to a radiator in the front of the van. i like the idea and if the currrent set up doesnt work ill do an AWIC. Thanks for the pricing! not as bad as i thought price wise! |
outwesty Samba Member
Joined: June 06, 2006 Posts: 1078 Location: Northern Sierras
Posted: Wed Jan 25, 2012 4:37 pm Post subject: |
Here is what I did with my TDI air-water set up. The grill will form very easily when heated with a heat gun. I am now running a Gowesty bumper and it looks even better. I purposely left the top open so I can spray bugs off. Hope this helps
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19045 Location: Retired South Florida
Posted: Thu Jan 26, 2012 8:04 am Post subject: |
| outwesty wrote: |
Out of curiosity, what sort of IAT do you see compared to ambient say running down the highway on an 85 degree day? Clean install. Thank you. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15407 Location: Syracuse, NY
Posted: Thu Jan 26, 2012 10:04 am Post subject: |
I really like the 50* install and I have alot of 50* conversion parts, the things that make this upgrade difficult is the modified intake from 2~3 intake sources
is there an aftermarket flange that one could build a SRI (short Ram intake) available out there? I'm not as familiar in the newer H2o tuning parts market.
beautiful install. and a nice engine balance for the weight of the vanagon without overpowering the transmission. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Posted: Thu Jan 26, 2012 6:49 pm Post subject: |
| rsxsr wrote: |
| outwesty wrote: |
I am not sure yet. I am adding sensors and gauges for the inlet/outlet temps in the near future. I can tell you that if I flip the pump off I can actually feel a difference. |
MR GAS Samba Member
Posted: Sat Jan 21, 2017 7:31 am Post subject: Re: 1.8T @ 50 deg. under the decklid. Now Running!! |
Update! 5 years still going strong! over 45k on this now. only maintenance items and tune up once. Starts right up every time. Lots of reliable Power. good mileage averaging 21mpg loaded.
_________________ Transaxles Rebuilt, Repaired and Re Geared 25 years. www.MRGASRebuilds.com |
Posted: Sat Jan 21, 2017 8:15 am Post subject: Re: 1.8T @ 50 deg. under the decklid. Now Running!! |
Nice! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sat Jan 21, 2017 6:22 pm Post subject: Re: 1.8T @ 50 deg. under the decklid. Now Running!! |
Nice job.
Is there still a thread on vwvortex on this? I couldn't find it.
Curious what you ended up doing with the IC.
Did you go water? Still have the IC in the same place I see. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
