littlejay Samba Member
Joined: February 19, 2007 Posts: 91 Location: oneonta,Ny
Posted: Mon Jan 30, 2012 9:49 am Post subject: Leds in vanagon. how to wire?? |
I want to put Leds in all lighting in the Vanagon. I see pics of people adding in dome lights in their front and back of Westy's . How is this wired??. Also the overhead in the Kitchen area,I have seen others add a second light and run them in parallel. I just saw some lights like this in Lowes. Is this what people are doing? |
Timwhy Samba Member
randywebb Samba Member
Posted: Mon Jan 30, 2012 3:13 pm Post subject: |
the light behind the stove on the shelf was 3 bulbs, then changed to a fluorescent bulb by 1986
no easily avail. LED conversion for the latter, only the early 3 bulb type _________________ 1986 2.1L Westy 2wd Auto Trans. |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Mon Jan 30, 2012 7:18 pm Post subject: |
Hi Littlejay,
As mentioned, this thread should get you started:
"Alpena Flex LED lights for interior van lighting"
I have gone to all LEDs for house lighting, and could not be happier. Use small gauge wire, like 16, and a small fuse, like 5 amps. The Alpena Flex lights are great, if you can manage the "cool" LED look. For reading and cooking I prefer the "warm" white LEDs from Oznium.com. Get the Alpena LEDs at Autozone.
I am running this:
- 1 set of the Alpenas (2 strips of 1 foot each) under the dash, ground wire connected to each front door switch, lights are always wired hot. Thus, the lights go on when door is opened. Center one LED strip over the glove box.
- 1 Oznium.com "Surface Mount LED Light Bar - Warm White", over the stove/sink.
- 1 Oznium.com "Surface Mount LED Light Bar - Warm White" over bench seat as a reading light
http://www.oznium.com/smd-bar
(Anyone wanna buy a pair of $50+ Go We$ty fluorescent lights?)
-CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Posted: Tue Jan 31, 2012 8:57 am Post subject: |
thanks man, perfect. I like the idea of the ones wired to the door switch. |
Posted: Tue Jan 31, 2012 9:23 am Post subject: |
how do you get a power source and switch in the sink and bench seat location? |
these Led's are great!!!! |
Posted: Tue Jan 31, 2012 11:09 am Post subject: |
littlejay wrote: |
I am working on a redo of the over sink light in the next day or so, and will post photos in the Alpena light thread.
