Buellistic Samba Member
Joined: February 04, 2011 Posts: 357 Location: Albuquerque, New Mexico
Posted: Sun Feb 05, 2012 12:35 am Post subject: Friction Coatings, quick question |
I was at a car show today and this guy was showing off his friction reducing coatings. Seems legitimate compared to what I've read in the past.
Just curious if anyone thinks it's worth it to coat the mains/rod bearings. This guy charges about 100 for all the crank bearings. I was thinking it might be worth it, assuming he can help correct for the increase in bearing thickness.
What do you serious engine builders think? Snake oil?
I suppose I should type in here exactly the KIND of coating... I forgot where I put down the documentation at the moment though. |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1206 Location: Melbourne Australia
Posted: Sun Feb 05, 2012 2:58 am Post subject: |
Some coatings like Calico have a good rep, I think they are overrated on bearings if you have oil pressure from initial start up ie a prime system, a plain bearing with a well controlled oil film is about as frictionless as you can get in an engine. Temperature shouldn't be an issue for bearings either.
I do use coatings on chambers, piston tops, valve springs etc to either be a thermal barrier, a thermal dispersant or an oil attracting coating as appropriate.
lets see what others have to say. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15600 Location: Deep in the 405
Posted: Sun Feb 05, 2012 7:34 am Post subject: |
The dry film lubricant used on the bearings are usful on higher reving engines that see above 6000 RPM regularly. On street engines that rarly see these high RPM's you're just probably wasting your money. It is very worthwhile to have dual valve springs coated on any engine. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Sun Feb 05, 2012 9:14 am Post subject: |
I have done it for so many years I cant remember.the mains in my 2028(I just put back in 4 months ago still look like when first instaled)well they cam out of my 2332 for about 3 hard years, then 2.5 years or so in my 2028, probably about 70000 miles on them now on 2 different cranks & in 2 different cases.rods look great also.cam bearings looked much better than usual,but still could see a pattern(cant see pattern on rods&mains).I also use it on the lash caps&rocker arms,the entire rockerarm,bushing,flat foot, the whole thing,the dfl attracks oil,and oil cools.I also do the cam gears&crank gears& pistons.springs too sometimes,there a real pain in the ass to do,wish we were getting the polished springs forthese things, but the $$$ would be more than the heads.
so yes do it, thats a good price,dont worry about the thickness, if he is applying it corectly it will be fine.if the crank is small and you have a bit to much clearance the bearings can be blasted with a corser grain at a slightly higher pressure then coated and they will be smaller with less clearance.pistons can also be done this way when there a bit too lose but still good. |
