delbertinie Samba Member
Joined: February 13, 2012 Posts: 4 Location: KANSAS CITY
Posted: Mon Feb 13, 2012 8:32 pm Post subject: Treuhaft 32-1000 cam |
Does anybody have full specs for this cam trying to find out if stock valve springs will be acceptable
on my rebuild I found 3 cracked valve springs which explains my popping
here are the specs I have but I need valve spring specs if anybody can help
Its a Treuhaft
32-1000 lift .400 duration 280 rockers 1.1 lobe center 106 open 34 close 66 intake / exhaust is 66 open 34 close
the valves springs i have that are still in tack, measure 2.2 tall od. 1.25 id. 0.93 wire diam. .158
i can not find any valves that match these measurements. I'm sure that the height has shrunk
stock valve springs are about a 1/4 shorter.
I'm not the greatest at performance building, besides some possible valve float can I use stock valve springs
.009 dist. headers twin solex 40/44 eis carbs 87 mm pistons everything else is stock.
__________________ |
Posted: Tue Feb 14, 2012 4:16 pm Post subject: |
Last night I got the bright idea to measure the length of the stroke between the the highest / lowest
point of the cam lobe on the intake and exhaust lifters. I found that the max. stroke for both is 3/8 of an inch == 0.375
So the rockers are 1 to 1 the push rod stroke would equal the valve stroke right...... 0.375
the stock valve springs are a little over 2 inchs so total travel would be only 0.375 correct
So the the longer valve springs are not necessary
what do you all think
_____ |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7854 Location: Videbaek Denmark
Posted: Wed Feb 15, 2012 5:40 pm Post subject: |
Stock springs can handle 0,385" lift. But they are most likely too weak to handle that cam duration and lift.
T |
Posted: Wed Feb 15, 2012 5:42 pm Post subject: |
You need to check coil bind on these other springs.
T |
Posted: Wed Feb 15, 2012 10:11 pm Post subject: |
did not think that was a very radical cam. In fact is it not pretty mild
the stock springs I bought measure 128 lb of force at 31mm of compression
do you still think they are too weak |
Posted: Wed Feb 15, 2012 10:14 pm Post subject: |
are you worried about valve float. |
