Dale M. Samba Member
Joined: April 12, 2006 Posts: 20871 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Mar 24, 2012 8:57 am Post subject: 2 Cylinder AC VW Motor? |
2 cylinder AC VW motor???
http://www.oocities.org/scottjjohnson2000/enginelog/logindex.html
Think a few may get a giggle out of this....
Dale _________________ “Fear The Government That Wants To Take Your Guns"
orangesuper Samba Member
Joined: January 06, 2007 Posts: 384 Location: Moretown, VT
Posted: Sat Mar 24, 2012 9:02 am Post subject: |
These turn up on eBay every once in a while there is (or was) a crowd of ultralight airplane guys that would do variations this mod for a (relatively) cheap alternative to airplane specific motors. I always thought this would be a cool engine for a vw powered motorcycle although you would likely have to do a ton of preformance mods to make enough hp for it to be much fun on a bike. |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2924 Location: San Antonio, Nuevo Mexico
slalombuggy Samba Member
Posted: Sat Mar 24, 2012 9:45 am Post subject: |
We had a few at the ACVW shop I worked at. One guy built half an 1835 a couple others were half 1914s. Also hada few 4cyl airplne motors with twin plug conversions. Cool stuff.
brad |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4130 Location: NW Washington
I have a set of plans for the half VW engine that i bought in the mid eighties when I was heavy into the ultralight and experimental airplane scene.
My plan actually cuts the case in half too so you don't have to plug the holes.
It's pretty cool but you need to do a bit of machining in order for it to work out nicely. _________________
richardcraineum wrote: |
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah .. |
cbeck wrote: |
His user name in a previous life was dick head. |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
skabonner Samba Member
Joined: May 12, 2009 Posts: 854 Location: La Habra, Ca
Posted: Sat Mar 24, 2012 10:47 am Post subject: |
Even cooler, a while back I saw a video of some guys in brazil who were welding cases together to make 6 and 8 cylinder engines. But I couldn't find any other info, other than a grainy video of one of the engines idling.  _________________
Douglas Adams wrote: |
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. |
'68 Beetle "Sadie" (R.I.P.)
'67 Beetle "Ilsa"
'06 Gti "Heidi" |
Joel Mohr Samba Member
Joined: March 07, 2002 Posts: 269 Location: High Desert SoCal
Posted: Sat Mar 24, 2012 2:07 pm Post subject: |
COOL STUFF! _________________ SEE YOU AT THE RACES!!!! |
JustBuggy Samba Member
Joined: August 01, 2010 Posts: 851 Location: SF Bay Area, Ca.
Posted: Sun Mar 25, 2012 12:07 am Post subject: |
skabonner wrote: |
Even cooler, a while back I saw a video of some guys in brazil who were welding cases together to make 6 and 8 cylinder engines. But I couldn't find any other info, other than a grainy video of one of the engines idling.  |
Now THAT is one I'd like to see!!!! |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5562 Location: Lefty, CA
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Sun Mar 25, 2012 4:27 am Post subject: |
I think they extend the crank and put a special prop bearing where the pulley was before. Thrust loads are taken there.
*edit* Can't see it clearly in the photo though... I know this is done on the full VW conversions. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2815 Location: The World's Motor Capital
Posted: Sun Mar 25, 2012 1:00 pm Post subject: |
Lots of interesting stuff out there....
markhuebbe Samba Member
Joined: March 08, 2006 Posts: 379 Location: St. Louis, USA
Posted: Tue Mar 27, 2012 6:43 am Post subject: |
Boolean wrote: |
That's how my full VW engine is in my airplane. The 1/2 VWs normally don't need the bigger bearing and just use a stock bearing. The thrust loads aren't that high to require it.
Also, you can cut the case in half to save even more weight. My father had over 1000 hours on his 1/2 VW and it ran great. _________________ 1970 Beetle - Rally car
http://www.Rally-America.com
http://www.HuebbeRally.com |
torsionbar Samba Member
Posted: Tue Mar 27, 2012 8:08 am Post subject: |
looks like suicide to me. you won't get me into any airplane powered by one of those things! a lycoming, sure, but not a hacked up beetle motor. _________________
Max Welton wrote: |
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed. |
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Tue Mar 27, 2012 8:41 am Post subject: Re: 2 Cylinder AC VW Motor? |
Giggle?
I have been wanting to try this for a long time. People I have talked to claim 70 plus miles to the gallon. |
Posted: Tue Mar 27, 2012 8:45 am Post subject: |
torsionbar wrote: |
looks like suicide to me. you won't get me into any airplane powered by one of those things! a lycoming, sure, but not a hacked up beetle motor. |
The Beetle motor has been successfully used for millions of hours in experimental aircraft since the 60s. _________________ 1970 Beetle - Rally car
wompninja Samba Member
Joined: July 06, 2008 Posts: 2163 Location: Salt Lake City
Posted: Tue Mar 27, 2012 8:47 am Post subject: |
wompninja wrote: |
I don't get the point, wouldn't this just make the engine run a lot rougher than it already is? |
You get the point now?  |
Posted: Tue Mar 27, 2012 8:49 am Post subject: |
Yeah, I don't buy it. If you are so worried about mileage and you want a two cylinder engine why not use a v-twin out of a Honda motorcycle? _________________ Pics of my 1970 Satin Black Type 1 build |
Posted: Tue Mar 27, 2012 8:50 am Post subject: |
Not to mention cutting the already too small 40hp in half... good luck driving that on the road. _________________ Pics of my 1970 Satin Black Type 1 build |
Posted: Tue Mar 27, 2012 8:58 am Post subject: |
So you have tried it?
Or you are just rich and don't care?  |
