grove082 Samba Member
Posted: Fri Mar 30, 2012 7:58 pm Post subject: 67 beetle 1600cc dual kadrons after 15mins car loses power |
after driving for 15 mins or so the car backfires and loses power. runs great for the first 15 mins. had the carbs synced and adjusted left shop and same thing happened. the next day ran fine and once again after 15mins runs like crap. anyone know a cure to my problem? i just bought car a few weeks ago |
craigman Samba Member
Posted: Fri Mar 30, 2012 8:23 pm Post subject: |
Sounds like it could be electrical. I'd check either the coil or condensor. |
Posted: Fri Mar 30, 2012 8:46 pm Post subject: |
ill check it out i was thinking it was running to rich and soaking the plugs i didnt think about the electric |
Posted: Fri Mar 30, 2012 11:18 pm Post subject: |
Na if it was soaking the plugs with gas it would foul them and wouldn't run good at all. You said it runs for about 15 minutes then craps out, let cool then runs again for another 15 minutes.
Electrical parts like coils, relays, condensors, ect., can act funny when they get heated. They can shut off, stick, or go out, then cool down and be fine.
It's just a suggestion, but i'd start there. |
ejonn Samba Member
Joined: September 04, 2011 Posts: 348 Location: Middle of California
Posted: Sat Mar 31, 2012 4:15 am Post subject: |
Electric fuel pump? |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16800 Location: State College, PA
Posted: Sat Mar 31, 2012 4:19 am Post subject: |
Fuel pressure is what? If you have a gauge, I'put it on and run the car a bit - pressure could be to high or too low - or your volume is too low and you are running out of gas. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Posted: Mon Apr 02, 2012 8:56 am Post subject: |
I think it may be getting to much fuel. Thinking I might get rude of the dual carbs and go with a single. |
Posted: Mon Apr 02, 2012 10:09 am Post subject: |
It's not a "too rich" problem. If it was, it would foul the plugs and would run like crap all the time.
They just don't dry out and then run fine later. If they foul, their done. |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
Cusser Samba Member
Joined: October 02, 2006 Posts: 33049 Location: Hot Arizona
magnus0328 Samba Member
Posted: Mon Apr 02, 2012 7:51 pm Post subject: |
Choke element not adjusted properly and closing the throat of the carb?? _________________ Matthew 6:19-21 |
Posted: Tue Apr 10, 2012 1:06 pm Post subject: |
There's no chokes in these carbs, when I bought the car and drove it home the muffler filled with fuel and was glowing. Flame shot out of the exhaust. I got the carbs adjusted and that hasn't happened since but still have the loss of power and backfire. I did have a cracked distributer cap and got a new one. Going for a ride maybe that's my problem |
Rome Samba Member
Joined: June 02, 2004 Posts: 10524 Location: Pearl River, NY
Posted: Tue Apr 10, 2012 7:20 pm Post subject: |
Intake manifold leak at the joint where either manifold is bolted to the head? Engine runs fine when cold (rich mixture), then as engine warms up, the excess air leaking in at the manifold joint leans out that side of the engine, allowing the engine to still run on the 2 cylinders fed by the other Kadron carb.
When your engine is running a few minutes, check the manifold joints on each side by aiming a shot of brake cleaner spray at the base of the manifold. If the joint is not solid due to a slightly tilted manifold connection, the engine speed will increase noticeably almost immediately. Shut the engine off, disconnect your carb linkage at that side, loosen the manifold nuts to the head, rock the assembly slightly while pushing down; then tighten. You might even want to pull the entire manifold+carb off on that side to make certain there is not a small obstruction between the bottom of the manifold and the head joint which could prevent the manifold from sitting fully down.
Then you may have to adjust your carb linkage slightly again (ball socket end at the carb throttle arm on the carb/manifold you just retightened). |
outruncat Samba Member
Joined: November 05, 2007 Posts: 67 Location: Kansas City, Missouri
Posted: Wed Apr 11, 2012 2:42 pm Post subject: |
if you let it cool 10-15 minutes, does it start up and run again?
Runs for a few more minutes and dies? Repeating cycle?
If so... I would focus on the condensor. This is a common problem when they go bad as they get hot require to cool before working again. Pop a new one in and see if it improves before getting too involved in troubleshooting. |
Posted: Wed Apr 25, 2012 4:43 pm Post subject: |
thanks for the help everyone, the car is burning way to much fuel to the tune of 10mpg i took it to a shop hopefully the can figure it out |
