T-handle not locking?
audidood
audidood is offline
PostPosted: Mon Apr 23, 2012 7:50 pm    Post subject: T-handle not locking? Reply with quote
having a weird locking issue with my t-handle. When i unlatch the handle and pull the decklid up, i can turn it the handle back to latched position and lock it with the key. but when i put the decklid back down, turn the latch 180 to latch it in place, i can't lock it. the key just won't turn in the keyhole when the lid is latched down.
any thoughts? i hope it's not a bad core, because the handle and my door are still a matching set that use the same key. Thanks!
'56 Oval
'71 Westfalia
'17 Taco
a (not so) wise man once said, "chrome don't get you home."
srm1956
srm1956 is offline
PostPosted: Mon Apr 23, 2012 11:42 pm    Post subject: Reply with quote
I had the same issues with a locking T handle I had on a 56 I use to own. When the deck lid is down turn the handle to the lock position then turn the handle a little bit further while keeping pressure on the key until it locks. Give that a try it worked for mine.
I'll explain why your handle is doing this if my method works.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Tue Apr 24, 2012 5:03 pm    Post subject: Reply with quote
Same issue with my 56 and I tried your technique to no avail.
Roads Scholar
Member# 2059
audidood
audidood is offline
PostPosted: Thu Apr 26, 2012 10:33 pm    Post subject: Reply with quote
hmm, actually it's the other way around. when i turn the handle to unlatch it, i can lock it. but when i latch it down, i can only turn the key almost 90 degrees. even if i try jiggling the T back and forth and trying to lock it, it doesn't lock. Crying or Very sad
'56 Oval
'71 Westfalia
'17 Taco
audidood
audidood is offline
PostPosted: Thu Apr 26, 2012 10:42 pm    Post subject: Reply with quote
ok, common sense saves the day. i unbolted the T and flipped it over. voila. problem solved Embarassed Razz
'56 Oval
'71 Westfalia
'17 Taco
Russ
Russ is offline
PostPosted: Fri Apr 27, 2012 7:26 am    Post subject: Reply with quote
we have all been there trust me Very Happy
Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:)
