losride66 Samba Member
Posted: Wed Apr 25, 2012 12:20 pm Post subject: Adjusting front brakes on a 66 bug. |
Just redid all the front bearings on my daughters 66. adjust the brakes so the wheels spin freely. drove it for a while and it started to smell and get hot only on the left side (driver side). The wheel got tight,adjust again and did it again. I'm new to this and can this be fixed by newbie or should I take it to a vw guy. I'm in Orange,CA. Thanks Folks. |
decobugma07 Samba Member
Joined: May 03, 2005 Posts: 1049 Location: Newtonville, MA
Posted: Wed Apr 25, 2012 12:31 pm Post subject: |
If you open the system you have to bleed the whole thing (all four wheels). If you didn't open the system, then is just adjustments.
You have to move the star (you know by now where it is) to the point that the drum wont spin, then, loose it about one or two teeth until you feel the drum spin but still rubbing just a little. Do that with all four and test it again. _________________ Custom labels available here
http://www.thesamba.com/vw/classifieds/detail.php?id=1217449
66 Bug "Trixie"
68 Bug "Deco" (parting out)
73 Bug "Blue Angel" (RIP)
Last edited by decobugma07 on Wed Apr 25, 2012 12:42 pm; edited 2 times in total |
Renowood Samba Member
Posted: Wed Apr 25, 2012 12:39 pm Post subject: |
Also make sure you adjust both shoes on each wheel. In other words tighten till it won't spin then loosen then do the same for the other shoe on that wheel. I learned this the hard way. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Wed Apr 25, 2012 12:58 pm Post subject: |
Sounds like an internally-failed rubber brake line on that side. If so, I'd replace all four. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Wed Apr 25, 2012 1:58 pm Post subject: |
KTPhil wrote: |
Ding ding ding ding. We have a winner. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Apr 25, 2012 6:04 pm Post subject: |
Just to elaborate a little. The rubber flex lines are a laminated hose. With age they can start to come apart internally and you can't see anything wrong.
Sometimes they allow brake pressure to go out to the wheel cylinder but they won't allow that pressure to return to the master cylinder when you take your foot off the pedal. So the brake continues to drag.
This is the most likely problem.
But, it you haven't taken the drum off, you may want to do that and check to make sure the spring clip on the adjuster is still in place. It's not common, but sometimes the spring clip will get broken off and that allows the adjuster to tighten itself up.
But I vote for the rubber lines too! _________________ Mother Nature is a Mean Evil Bitch! |
